04-03-2016, 01:58 AM | #1 |
Post your need to get and to do list
04-03-2016, 03:11 AM | #2 |
Re: Post your need to get and to do list
Mine is not that lengthy yet very expensive.
04-03-2016, 06:42 AM | #3 |
As I walk out to my truck things start churning on all the things I should be doing to it whether it's needed or just things I would like to do. Then that darned little devil on the right shoulder says, it can wait, and I jump in and head down the road with a big smile and tell myself, "good choice Joe, good choice".
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 04-03-2016 at 08:19 AM. |
04-03-2016, 07:42 AM | #4 |
Ole Blu
Complete rebuild of suspension Fuel pump kill switch in cigarette lighter/ distributor kill switch/ CarDefender Dome light fixed. Inside and outside. Door locks Reverse lights in bumper Windshield washer fluid pump Cigar lighter fixed Replace window rollers/Guides Lug nuts Weather stripping HEI distributor Window tint? Bed rails Mat under the hood Paint engine bay Tool box Part Number # 555-51137
1969 GMC C/1500 LWB Wideside 355 SBC/TH400/3.73 posi-traction Daily Driver. Carburetors, because I don't care to consort with that of the robot race. |
04-03-2016, 09:25 AM | #5 | |
72 Cheyenne k/20, Custom Camper 72 Cheyenne k/20 71 blazer K/5 2WD 454, 6 sp. 67 Chevy Napco c30 Dump 56 GMC Napco 4x4 short step 66 Chevy K10 68 Chevy C/30 4x4 |
04-03-2016, 09:55 AM | #6 |
Needs List:
_________ 1- shop space 2- money 3- time To Do List: _________ 1- make money 2- build shop 3- make time The rest is easy
04-03-2016, 10:05 AM | #7 |
my need to get list would be a 25 year old sugar momma that likes hot rods
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
04-03-2016, 11:09 AM | #8 |
You have a better way with words than me. That's what I was trying to say
04-03-2016, 11:21 AM | #9 |
I've got mine in 4 lists - 1 for each vehicle and then a misc list. Under C10 I have "everything". Pretty much knocked out Buick and Mustang lists though.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
04-03-2016, 02:43 PM | #10 |
70+ ( Old Skool Club )
Here is mine. I may never get it all done but can drive and enjoy the truck as I go. I like original trucks so even if I get the wish list all done the truck will still look stock/original.
Interior 1. Radio Conversion 2. Install Tach Dash 2012 3. Replace Carpet 4.Install Rear Speaker Mounts 2011 5.Install Bow Tie Sill Plates 6.Fix Light on HVAC Controls 7.Install LeCarra Steering Wheel 2006/05 8.Get Tilt Wheel 9.Install Lower Door Carpet 2010/10 10.Install Kick Panel Carpet 2010/10 11.Install Bowtie Sill Plates 12.Bought Buckets/Console 2015/Dec 13.Get and Install Headliner Exterior 1. Rear Mount Gas Tank 2003/08 2. Hidden Hitch 3.Replace Windshield 4. Carb Rebuild 5. Install 700R4 6. Install Pertronix Distributor 2015/08 7.Replace Ring and Pinion 8. Replace Spark Plugs & Wires 9.Install LED Taillights 2015/06 10. Install Taillight Mouldings 2015/08 11.Replace Upper Tailgate Moulding 12. Get Exhaust Redone 2015/07/20 13. Check Front End 2015/07/20 14. Headlight Wiring Harness 2015/03 15. Install Window Visors 16.Install new ground strap kit 2012/04 17.Fix Back-Up Lights 18.Get Stake Holes Filled 19. Get Box Cover 20. Install 1 1/4 Front Sway Bar 21. Install Rear Sway Bar 22. Replace Shocks 23. Paint around Headlight Doors 24. Install New Headlights 25. Replace Vent Window 2015/12 26. Install Fuel Filter 27. Front & Rear Main Seals 28. Valve Cover Gaskets 29.Wheel Alignment 30.Redo Tailgate Lettering 31. Install 7 inch rims 2015/10 2015/10/02 32.Hood Hinges Rebuilt. 2016/01
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-03-2016, 05:51 PM | #11 | |
04-03-2016, 11:23 PM | #12 |
currently...
install the new passenger window regulator i bought adjust the vent windows (hard to open/close & wind noise) wire an electric windshield washer pump fix the gas gauge (stuck on E) change differential oil texas speed 224r cam PAC 1218 valve springs hardened pushrods timing chain and gaskets yank truck thruster 2600 stall corvette servo for my 4l60e b&m trans cooler wheel adapters c5 z06 wheels pypes violator mufflers or keep my old flowmasters and run e-cutouts look into new seat cover |
04-04-2016, 12:25 AM | #13 |
Needs List:
Buy a new SWB 4x4 To do list: Many, many hours of craigslist Shouldn't have sold my last truck. Oh well. Hard to find a truck as a Canadian. I have people even from Washington and Montana turn me down after agreeing on price upon finding out I am from Canada. Rough life. |
04-04-2016, 08:56 AM | #14 |
Too much to list!
04-04-2016, 09:40 AM | #15 |
I try to keep my list down to a couple things at a time, otherwise it gets overwhelming. Currently swapping heater core, which led to swapping the radiator, and figuring out why someone did a cheesy bypass for the transmission cooler. Also swapping steering gear box, which led to power steering pump, and column bearings. Oh yeah, while the wheels were off I noticed the ball joints are bad and that the axle shaft seals are leaking. So I guess I'll be doing ball joints, bearings, bearing and axle shaft seals, which of course means getting into the front diff, which means who knows what the heck I'll find...
I meant to do something simple, and instead I've got a truck on jack stands that won't be able to drive for a couple more weeks at least. See what I mean? Keep the list to a thing or two at a time. Because each one will lead to another five...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
04-04-2016, 10:07 AM | #16 |
Not enough paper in the notebook for my list !
2016 Silverado2005 GMC Sierra 2002 Chevy Slverado Extra Cab (youngest sons) 2009 GMC Denali (oldest sons) 2015 Lexus 250i (wifes) 1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY" http://www.louisianaclassictruckclub.com |
04-04-2016, 11:30 AM | #17 |
Great thread!
1). Clean up a bit around radiator core support frame bushings. 2). Install bushings. 3). Reinstall fuel pump. 4). Put carburetor back on. 5). Make and install hard line from pump to carb. 6). Clean up windshield washer jets. 7). Replace rubber hose for windshield washer. 8). Remove paint overspray on washer bottle. 9). Rebuild heater box and reinstall. 10). Get cowl blasted and epoxy primed. 11). Get cowl and outer fender painted. 12). Put radiator core support on (put the replacement one on). 13). Undercoat replacement inner fender. 14). Reinstall inner and outer fender. 15). Replace wiring. 16). Put front grill, headlights, radiator, etc. back on. 17). Put cowl back on. 18). Replace front end rubber pieces. 19). Redo fuel line cut off valve. (All that work and I still have to redo it). 20). Install new battery. 21). Drain brake system. 22). Replace brake fluid. 23). Bleed brake lines. 24). Repair stuck parking brake. 25). Prime oil pump (manually). 26). Put distributor back in. 27). Set points. 28). Pray it all works. 29). Stand by with C02 extinguisher as someone turns the key! Once truck can move about, get shipping container delivered and blocked up. Move all gear out of garage. Tear down ceiling and all wiring. Clean up attic (had birds up there for a summer, yuck!) Paint garage walls, repair cracks. Rewire garage. Getting 220 installed for a welder! Floor attic. Build shelves. Put all junk back in and get container picked up. Truck goes back into garage but it will run by then so I can get it licensed and actually have a truck! Last edited by In The Ten Ring; 04-04-2016 at 06:26 PM. |
04-04-2016, 11:57 AM | #18 |
What I have done so far...replaced radio with an aftermarket era correct am fm cd player...fixed the washer nozzels...fixed the reverse lights...fixed the license plate lights...dome light...replaced the ignition...but in a 59 Impala steering wheel...moved the reverse linkage so it engages in the correct position...put racing pedals on...new gear shift knob...new 4 wheel shift knob...really all I have left to do is put door panel sound proofing in and switch out the door locks so one key works for doors and ignition...did quite a bit of cosmetic chores to the truck...put in some colored under dash lights...new saddle blanket seat cover...some wire wraps for under the hood etc...kind of hard really to remember all the things...ummm oh, put in a red optima battery too...fire extinguisher...flash light holder...correct 4 wheel drive instruction decals...some rear window decals...rattle canned the rocker panel area...new tach..Marla
04-04-2016, 02:04 PM | #19 |
Sweet truck! Hadn't seen that one yet, nice work!
04-04-2016, 02:39 PM | #20 |
If I could find a sack full of cash to build a new shop and a contractor to give me a bid everything else would just fall into place .
04-04-2016, 05:35 PM | #21 |
Front bumper . Ecklers show quality Complete 4/2015
Mini Starter ...Chip White Complete 3/2015 Valve job..#1 burnt exhaust valve Complete 06/2013 New rear main seal Complete 06/2013 New one piece oil pan seal. Complete 06/2013 New tail lights Complete 08/2013 Alignment Complete 2/2014 Determine stud size of lifters 5/8 nut, Stud 3/8" Determine ratio of lifters Lifters not marked, stock ratio 1:5 Determine if lifters are solid. Not...they are Hydralic New Headers ?? Not now. New Tires: 275/60/15 rear, 235/70/15 front...BFG Complete 2/2014 New refurbished Rally Wheels-15x8 & 15x6.5 Complete 2/2014 New America Racing TTII Wheels 15" Complete 2014 Adjust tranny kick down linkage Cable changed 5/2013 Buy MSD HEI Distributor 8365 No..bought Skip White unit Add air conditoning VA Surefit Complete 1/2015 Install rear pan, notched No Polish Wheels Complete 06/2013 New Torque Converter...stall speed . 2300-2700?? Complete 05/2013...2400 stall Hidden tailgate latch & support bars( remove chains) Maybe Installed Transgo 350-1&2 Shift kit & change filter Complete 3/2014 Installed Stage 8 locking header bolts Complete 3/2014 Rear Disc Brake Conversion (eBay) No...new Drums Complete 1/2015 Painted header white with HTY Ceramic Panit Complete 3/2014 Installed Fuel Vapor lines and canister Complete 3/2014 Check and adjust timing Complete 05/2013 Adjust valves / rockers Complete 06/2013 and 5/2015 Floor Mats (Ecklers) Complete 2014 Buy K&N Type Air Cleaner Complete 06/2013 New Valve Covers Proform 141-925 Complete 09/2013 Proform Valve Cover Mini bolts Complete 06/2013 Billet Breather Cap Complete 07/2013 Taylor Spark Plug Wires 73451 Yellow Complete 07/2013 Perform Leak Down Test Complete 06/2013 Valve Job..yes, #1 burnt exh valve. Complete 06/2013 Engine Block # 3970020, 307 CI used in 69-73 cars & trucks Other engine block marking..front left side of block = V1118TAK Head Casting Number = 3927185, GM9-drivers side, GM59 Passenger Side. Used on 307, 327 and 350 engines. 1969 thru 1976. 70CC chambers Compression test results. Test cold, WOT, oil in #1 no Change, tested 6/6/2013 Cylinder # Cylinder # 8 160 7 140 6 165 5 155 4 165 3 132 2 152 1 75 Buy SS diff bolts Cancelled Rear brakes, clean, adjust or replace Complete 01/2013 Sway bars front. (used from ECE via the gearbox garage) Complete 01/2013 Emergency Brake pedal adjust/repair Complete 01/2013 Emergency Brakes adjusted Complete 01/2013 Take out radio and speakers Complete 01/2013 Chrome Diff cover Complete 01/2013 Change differential oil ( Royal Purple) Complete 01/2013 Rebuild heater control panel Complete 01/2013 New rear springs (4" drop) CPP Complete 02/2013 Change rear lowering blocks to 1.5" Complete 02/2013 New shocks f&r Complete 02/2013 New motor mounts (Prothane) Complete 02/2013 Lower front spindles (2.5") CPP Complete 02/2013 Re-Dye carpet black Complete 02/2013 Shifter gear selector repair Complete 03/2013 New steering wheel (used from Forum) Complete 03/2013 Sway bars rear. CPP bar through Ecklers Complete 03/2013 Change interior door panel screws Complete 03/2013 New tachometer and Temp Gauge Complete 03/2013 Adjust door closure and locks Complete 03/2013 New door seals..GMC Pauls Complete 03/2013 Rebuild steering column Complete 03/2013 Install sound deadener...FatMat Complete 03/2013 New Side Mirrors...check for backing plate Complete 03/2013 Install Extended PanBar (the Gear Box Garage) Complete 03/2013 New front springs (CPPP 2" lower) Complete 11/2012 New oak wood bed (MAR-K via Ecklers) Complete 12/2012 Tailgate Trunnions (poly) Complete 12/2012 Change door latch screws Complete 12/2012 Pressure wash rear frame and paint Complete 12/2012 Distributor....electronic or points HEI Chip White distributor Fix bench seat adjuster In process 2/2013 Buy one piece floor mat Returned 3/2013 Floor Shifter or stay with column shift? Stay Column
1970 C10 Short Stepper with 71/72 front clip. |
04-04-2016, 06:24 PM | #22 | |
04-04-2016, 06:44 PM | #23 |
because they may not want to deal with the export process?
or you show up with the agreed price in CAD? lol |
04-04-2016, 07:27 PM | #24 |
"List???? I don't need no stinking list!"
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-04-2016, 07:59 PM | #25 |
Too long. I've removed about 35% of the truck and my "manual" is currently 22 pages long. Once everything is removed, my "list for what's left" will be over 50 pages, and excludes refinishing parts.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
