Old 04-19-2016, 09:22 AM   #1
Hellbent
Don't blame the messenger
Hellbent's Avatar
Custom Seat - Install 2010 Dodge Ram Seat
I have been asked to post how I modified these 2010 Dodge Ram Seats to fit my 69 C-10. Hopefully this will help someone out there. I picked the seats up from the local pick a part. $35 for the set, the covers were trashed. Neglected to take before pics, wish now I would have. The seats had head rests which I removed while recovering them. I purchased the leather hide from Kyson Leather- Labeled as Modern Black. It had the flat black sheen I was searching for. Patterned the flames off the valve covers and transferred the pattern to the leather. Hand stitched the flame pattern on to 1/2" sew foam. The center console lid was done with a foam overlay. This is the result after about 30 hrs.
On the Level
Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525
"Some drink from the fountain of knowledge while others just gargle."
Hellbent is offline   Reply With Quote
Old 04-19-2016, 09:32 AM   #2
Hellbent
Hellbent's Avatar
Re: Custom Seat - Install 2010 Dodge Ram Seat
Seat Frame Modification:
I utilized the factory seat mounting locations already on the floor board. To do this, I cut off the dodge seat mounting tabs and placed the frame work in the truck. I used 2" flat bar to span between the adjustment rails of the frame. Measured and cut the flat bar, then located the mounting holes on the floor board, marked the flat bar and pre-drilled the hole. Bolted the flat bar to the floor and lined the frame work to the flat bar. I did this for both sides, aligned everything and then welded the flat bar to the seat frame with everything in place.
On the Level
Old 04-19-2016, 09:39 AM   #3
Hellbent
Hellbent's Avatar
The actual frame modification took just a few hours to do. Here is the mounted results.
On the Level
Old 04-19-2016, 09:42 AM   #4
flashed
That looks as good as BuddyBuckets and probably sits better ,very nice seats and your custom upholstery is killer.
flashed is offline   Reply With Quote
Old 04-19-2016, 09:51 AM   #5
Hellbent
Hellbent's Avatar
I think they are a comfortable alternative. Thanks for the compliment.
On the Level
Old 04-19-2016, 10:09 AM   #6
Hart_Rod
Hart_Rod's Avatar
How much do a set of those run?
Hart_Rod is offline   Reply With Quote
Old 04-19-2016, 10:49 AM   #7
XwalkerX
these look really REALLY good
XwalkerX is offline   Reply With Quote
Old 04-19-2016, 10:58 AM   #8
NoNeck
NoNeck's Avatar
Nice... they look right at home in there. I like them A LOT. Does the console have the 12V power source and MP3 outlets inside?
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 04-19-2016, 11:01 AM   #9
projectking
projectking's Avatar
I have the same seats, pm me the cost for a set of covers minus the flame stitching. Thank you.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 04-19-2016, 11:05 AM   #10
sduckworth13
sduckworth13's Avatar
Wow! Your seats turned out excellent.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-19-2016, 11:37 AM   #11
Hellbent
Hellbent's Avatar
Seats cost $35. Upholstery materials about $400.
POP
Yes they have the 12V power supply but do not have MP3.
Sorry, I'm not looking for projects.
On the Level
Old 04-19-2016, 01:33 PM   #12
Steve Cole
Those look amazing! Excellent work! I have two questions for you. Is the seat cushion roughly the same height from the floor as original seats? (Is the ride height the same) and did you have to cut down the backrest to get it below the window?
Thanks!
Steve Cole is offline   Reply With Quote
Old 04-19-2016, 02:38 PM   #13
sierragrande71
sierragrande71's Avatar
Definitely better than spending 500 plus bucks factory buddy buckets!!
sierragrande71 is offline   Reply With Quote
Old 04-19-2016, 02:42 PM   #14
R.S.S.
R.S.S.'s Avatar
Awesome!
R.S.S. is offline   Reply With Quote
Old 04-19-2016, 03:14 PM   #15
Steve Cole
Looks like you ditched the plastic cover pieces on the side as well.
Old 04-19-2016, 03:32 PM   #16
Hellbent
Hellbent's Avatar
Thanks!
1. Sorry, I do not have the dimensions from the original seat. I rid of it years ago. Front of this seat ride height is 11".
2. That's what I love about this seat. I didn't have to make any major modifications. I only removed the head rest and filled the holes.
My thoughts exactly. However, if this was an original build, factory buddies would be the way to go. This truck never had a chance at originality.
Actually no, this model seat did not have the plastic but rather a cardboard covered curtain that hides the tracks. (I should add that I intentionally chose this seat because of simplicity, no electronics or controls that I didn't need) I do plan to fabricate something to conceal the tracks- but that will be down the road during finishing.
On the Level
Old 04-19-2016, 05:49 PM   #17
jeffahart
jeffahart's Avatar
Nice, I love the storage too. You get the armrest with storage and you can lift it for a center seat. Does the center seat lift for more storage too. The last two Rams I owned you could lift the center seat for storage also.
Tempting to get rid of the bench. But my junkie old bench is surprisingly comfortable. I put new upholstery on top of old junk springs and stuffing. Comfortable believe it or not.
But those look real nice!
White K20
jeffahart is offline   Reply With Quote
Old 04-19-2016, 06:01 PM   #18
Hellbent
Hellbent's Avatar
No, there is no additional storage with the center seat. That would have been nice though. Thanks for the compliment.
On the Level
Old 04-19-2016, 06:37 PM   #19
Steve Cole
Does the center seat have a seatbelt as well? Does the center belt attach to the frame or the cab floor?
Thanks.
Old 04-19-2016, 08:41 PM   #20
Hellbent
Hellbent's Avatar
Thanks.
Yes, it has an adjustable lap belt. The belt and receivers attach to the seat framework.
I'm actually in the middle of designing a way to secure those belt points from the frame of the seat to the floor board. Just for peace of mind.
On the Level
Old 04-20-2016, 07:57 AM   #21
Steve Cole
Custom dash, suicide doors, this truck is going to be amazing! Show us more pics when you can!
Old 04-20-2016, 08:27 AM   #22
Steve Cole
I just read your entire build thread, you do excellent work! I have never met anyone who was good at upholstery and welding!
Old 04-20-2016, 06:37 PM   #23
Hellbent
Hellbent's Avatar
Hey Thanks Steve-
On the Level
Old 04-20-2016, 08:44 PM   #24
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
03 and 06's have the under storage under the center console. I have the 06 in my burb.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 04-22-2016, 02:12 AM   #25
iregalado
iregalado's Avatar
Thank you vet much awesome work and great write up, really appreciate the time you put into showing us your work and skills.
iregalado is offline   Reply With Quote
