07-08-2016, 07:05 PM | #1 |
283 and a Slight Hop Up
I have a nice little 283 from a '65 with powerpack heads that I'll be dropping in my '64 C10 to replace the tired I6. I'm keeping it factory looking under the hood as much as possible, but would like some suggestions on some minor hop ups for this engine since I'll be doing a refresh and may as well make it suitable for the purpose of the truck.
I would like to replace the cam with something a little bit more lumpy, but would still be okay for some towing (worst case a car on a trailer). Nothing too rowdy, but adds a little something. Anyone have a suggestion on cam kit? I have a TH400 to back it all up as well. I'm replacing the 2bbl stock intake with a 4bbl intake (nothing fancy) and would like to get a carb that's correct or correct looking for a late 60's build. I'll make some mods to adapt the air cleaner so it looks correct. Carter? Holley? Something else? Last, I need a dizzy for the engine. Was thinking just stock with a good coil. Is there anything else I should consider? A later distributor? I definitely don't want HEI. In case it matters for the sake of discussion, the feel I'm going for with the truck is something that might be seen in the parking lot of a high school in the late 60's/early 70's that some kid lowered and hot rodded just a bit. Mostly stock looking, but with a great stance, and with the right exhaust sounds a little nasty. Thanks for any suggestion guys! S
scootermcrad.blogspot.com |
07-08-2016, 07:54 PM | #2 |
Re: 283 and a Slight Hop Up
Great engine. I have one in my 67 impala ss. If you run the exhaust out the back glasspacks would sound great and have that 60s sound.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
07-08-2016, 08:13 PM | #3 |
Definitely!
07-08-2016, 09:59 PM | #4 |
FWIW, i would lose the power pack heads, get a set of 80-85 305 heads, 80-86 aluminum intake, do a HEI module UNDER the stock 283 distributor, XE256 Comp Cam
07-09-2016, 12:36 AM | #5 |
60-66 Nut
This \/ \/
You do not want a lumpy cam if you are going to be doing any towing, especially with a 283.
07-09-2016, 09:13 AM | #6 |
07-09-2016, 09:53 AM | #7 |
A 500cfm Edelbrock carb should work pretty good right out of the box.
07-09-2016, 10:58 AM | #8 |
I've got a 283 in my 65 Sub and it's all stock looking as well. I put an Ignitor kit under my stock dist. cap about 20 years ago, and its still going strong.
I'm debating whether to have my 283 rebuilt again, or get a 350. |
07-09-2016, 09:03 PM | #9 |
http://67-72chevytrucks.com/vboard/s...d.php?t=580055 this was a good discussion from a while back
07-09-2016, 09:08 PM | #10 | |
I called Comp and Summit and asked for some suggestions as well, and the XE256 was one that was suggested as well as the next step up, which had a slight bit more lift. https://www.summitracing.com/parts/cca-k12-239-3 The limiting factor is going to be the budget. I can't let this escalate out of control or the truck will never see the road in a reasonable time frame. Love the HEI under the cap idea. Is this the Ignitor module mentioned by 65chevysub? I'll check that out. Is there a thread on here regarding that conversion? In all reality, I'll probably rarely pull something as heavy as a car on a trailer. Once a year, maybe? And it would probably be a small car (model A or similar sized hot rod). More likely would be a small single axle trailer for a lumber or gravel load, or maybe a small "canned ham" travel trailer on occasion, if we get one. Nothing serious here, folks. I've always liked that Edelbrock carb. Nice setup. I have one on a 350 and has always been dependable. Might be a bit too spiffy looking for the underhood appearance I'm after, but maybe I can tone it down a bit. What about a QuadraJet from this era? Are they still affordable and easy to rebuild? I need to see what 4bbl manifold I have for this thing. Thanks for all the input guys! Super, super helpful! Hopefully I don't sound too picky. Concerned about budget. I still have to get the rest of the truck together and go through the TH400 also. This truck needs a lot, top to bottom. I want to do the engine right, but I don't want to go down the SBC slippery slope. There's a ton available for these little small blocks and it's super easy to go nuts and replace about everything on them. Just want a good reliable engine I can depend on and have a fun little truck I can drive to work everyday. The era correctness appearance is important to me also, though.
07-09-2016, 09:09 PM | #11 | |
07-10-2016, 12:24 AM | #12 |
60-66 Nut
In a 350 it is not, but in a 283 it will idle and run differently.
07-10-2016, 01:42 AM | #13 |
Keep us updated. I'm interested and wish you well.
07-10-2016, 10:51 AM | #14 |
you could use most of this if you can get it for 150 or less
https://charlotte.craigslist.org/pts/5645165451.html |
07-10-2016, 10:57 AM | #15 | |
07-11-2016, 08:27 AM | #16 |
Bumping this back up for some carb talk. I think tossing a little Edelbrock 500 on there is probably the easiest solution and I think I may even have a line on one for super cheap (maybe free?).
What 4bbls would have been used by Chevy from 64 to 70 (ish)? Did all the GM standard carbs in this time frame have the same mounting pattern?
07-11-2016, 10:03 AM | #17 |
I use the 500 cfm Eddy (1404) on my 283. It's jetted for performance and dual quad applications out of the box. I had to lean mine out 2 stages in the cruise mode to get it optimized for my motor. Around town throttle response is crisp and smooth, but I had to use an insulating type base gasket because it would "percolate" after shutting down on hot days.
07-11-2016, 03:33 PM | #18 |
I ran a 283 bored .030 in high school, screamin little engine! This is the recipe:
.030 over 1957 block 1966 power pack heads hp std flow oil pump old Vette double point distributor (remember this was 1969) Later changed to a Sanderson mag 350 cube 350 hp L82 GM cam p/n 3896962 (best little cam EVER for a 283!) flat top pistons / two valve reliefs old style Rochester 4-jet carb for a 327 set of Headman full length headers I raced this car HARD & never blew it! I later changed to a two four setup w/ double hump heads & lost all of the low end power, keep the power packs! Cam will give a slight "lumpy" idle, not bad like the old 327 / 350 hp "151" cam will. |
07-12-2016, 12:11 AM | #19 | |
I second & third This...... This is sound advice....... . . . . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
07-12-2016, 08:53 AM | #20 | |
07-12-2016, 10:56 AM | #21 |
Finally got a chance to look at that GM intake I have. It is a 283/327 4bbl manifold for 62-63 Corvette. Is this a standard bore and pattern size? Seems narrow, but might be an optical illusion.
The manifold is just like this one http://i.ebayimg.com/images/g/KCsAAO...OP/s-l1600.jpg I'm going to have to ditch this thing, aren't I? Looking like I'll have to run an adapter. I hate adapters. If so, any recommendations on a nice dual-plane intake to run with a Edelbrock 1403 with either of the cams we talked about above?
scootermcrad.blogspot.com Last edited by scootermcrad; 07-12-2016 at 11:05 AM. |
07-12-2016, 11:18 AM | #22 |
scooter...
Consider the Summit 1101 or 1102 cam if you are sticking with the power pack heads. Anything larger than these two will kill your bottom end torque. If you want to stick to a 60's theme, find some camel hump heads with 1.94 intake valves, utilize an older edelbrock or offenhauser 360 type manifold with a holley or edelbrock 500 or 600 CFM carb with vacuum secondary's. What is the rear end ratio? 3.55 and above? I ask this because 283's like to rev, making power higher up the RPM range. I had a nearly stock 283 in a 57 chevy with a 2 speed powerglide. Only mods were an offy 360 manifold and 500 cfm edlebrock carb, with electronic ignition module, and dual exhaust...no headers. It was enough to bark the tires at full throttle shifts between 1st and 2nd. Add headers if the budget allows...best mod you can make for mouse motors, stock or otherwise. |
07-12-2016, 11:47 AM | #23 | |
And do some research on the 305 heads. Some came with pretty small chambers and OK valves sizes for a 283. .
65 C20 292 4spd 4:56 Eaton HO52 |
07-12-2016, 01:01 PM | #24 | |
The rear is stock '64 C10, so whatever is out back. I have some Corvette rams horns for the engine, but thought later I would swap for headers.
07-12-2016, 01:02 PM | #25 |
I'm starting do think more about the 305 heads. There are a couple complete 305's for sale locally for pretty cheap. I have to have the heads gone through anyway, so if I can find some heads cheap around here, I'll probably go for it.
