Re: Finishing Bed Wood with oil: Does it last, Let's just see
I've got an old farm trailer that I used oak in the floor to refurbish it about 20 years ago. I used motor oil thinned with diesel to treat it originally and have used vegetable oil thinned with gasoline once. It has had the vegi treatment once and the used oil twice. It's not pretty, but there is NO signs of decay. I'd forego the vegi oil, honestly. It works well but will be rather sticky for a few weeks. Long story short, I used vegi oil/gasoline as an alternative fuel for an old Mercedes for many years and had some extra oil that need to be used up. This trailer sets outside 100%. Oil treatment is my preferred method for outdoor wood. Clearcoats can make a fantastic show car, but just don't last on daily driver.
My 72 has had the Penofin oil/stain on the exposed portions with the POR-15 on the underside and will hit the streets this year...time will tell, but I'm betting on it to be worth it. I will likely hit it with another light coat of Penofin as it has been a few years since it's original treatment. Thanks for your thread Jeffahart!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
I just sold a 6.5x16 tandem axle trailer last month that was my father in laws. He had redone the floor in it about 15-20 years ago in did the same treatment as Sick472 mentioned. This trailer had sat in the edge of the woods for at least the last 10 years and the leaves and pine needles were about 6" deep all over the bed. I just knew it would be rotted out when I pushed all that stuff off but surprisingly, it was in pretty good shape.
I use the same method on my wood fence around my pool. Keep all my used oil and mix it with diesel. Makes it a dark brown and after a few days the smell goes away but it will sure repel water like no other. I was paying over $200 every other year to treat it and this only cost me about $30 in diesel as I have plenty of used oil around as I change my own and have four vehicles to service.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
The Por-15 is just their standard "Rust Preventive Coating" in a gloss black. IIRC, I put two or three consecutive coats on per the instructions. It is pretty thin and needs to soak in and build up. If you let a coat dry out, then you have to sand/scuff it before adding the next coat.
As far as the Penofin treatment mine got, the truck hit the road April 2021 and I gave it a quick re-treatment shortly after. The truck has 2000 miles on it now with several washings and several rains, but it is kept garaged otherwise and not used for much hauling. It shows no signs of age aside from a small split or two which is going to happen with wood regardless.
#4 | ||
"I ain't nobody, dork."
Still looks Good!
![]() Gary
I am following your process and have gotten to coats 3 and 4. I heavily coated the sides, ends, and bottoms of the boards and let them sit in the sun yesterday. The problem I now have is oil seeped out of the top of the boards and dried leaving many shiny spots on the tops of the boards. I'm not sure if I need to sand them down again or if there's another method that can knock those spots down. I tried fine sandpaper and scrubbing away with some turpentine on a green scrubby. I can see a little progress but the shiny spots remain. Any tips for dealing with these or do I need to aggressively sand the tops down again?
#6 | |
![]() Join Date: May 2012
j
White K20 |
#7 | |
Some of the recent shiny spots are wet and able to be wiped away but others have dried to some extent and cannot. Some of the thicker spots produce a waxy residue if I scratch them with a putty knife but most of the shiny spots are just shiny without any topography. I assume these are bleed out spots that I didn't wipe down in time and they have dried into a thin shiny film atop the wood. I found a lot of woodworking forum posts describing tung oil bleed out especially in woods like red oak which is what I am using. I will be more diligent about keeping an eye on the bleed out from here on out but I'm not sure how to fix the spots I have already. |
#8 | |
j j
White K20 |
![]() ![]() Join Date: Jul 2002
This was on my old 81 stepside, but same thing applies. I used Danish oil. Bed was white oak. The first time I did it was 6 or so years after the wood was put in (prior owner). The guy I got the truck from did the bed about 5-6 years ago. It stayed in a garage mostly until I got it. I drove it a lot more, and it sat out in the sun a lot more because of that. A friend who has wood working business recommended this Danish oil. I used a scotchbrite to scuff up the wood and used a microfiber rag to wipe the oil on. I put 4 (maybe 5 I forgot) coats with 24+ hrs in between coats. Before the last coat I did a 1000 grit lite sanding, then rubbed in the last coat. I was told to do it until it looked like the wood was not sucking in any more. Since the bottom doesn't get (or abuse by me), my friend said I really didn't need to worry about that as much. I was told with the way I was driving it, maybe every other year do the same thing. It probably wouldn't need as many coats.
Did some maintenance on my bed wood last week, so I thought I would follow through with an update.
This time I decided to spend a bit more time to clean things up. I am really happy with my decision to oil the wood. With a bit of extra effort it looks really nice… even after seven years of abuse, I think it even looks better. What I did. I hosed off the wood and used a mouse sander with a green pad and got all the embedded dirt and grime off. I hit all the wood with 220 grit sandpaper and some spots with 120. It created a white film on the wood. Then the magic happened… as I wiped the wood clean with a cloth, the white film disappeared and turned into a polished sheen. At this point there’s enough hardened oil on the wood that it can be fine sanded and polished. Wow, imagine if I decided to do some #0000 steel wool! I put a fine coat of oil on the wood anyway and gave it a fairly good rubbing. I also took some white rustoleum and touched up the strips. If you look at the after pic in post #69, you see the wood looks decent but the bed strips and tailgate look beat up. So I decided to take a bit more time on the maintenance this year. At this point I am very happy. All in, my maintenance and touch up took me about three hours. My bed has turned out to be everything I wanted in a wood truck bed. It is all truck, I love it! I use the crap out of it and I can spend a couple hours to make it look decent. The tung oil experiment is turning out to be a win for me. ![]() j
White K20 |
Looks incredible!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
![]() Join Date: Mar 2009
Thanks jeffahart for making, and especially for updating, this post! I've used Danish oil on furniture (our dining room table) and wooden steering wheels I've restored and plan to do the same on the wood in my truck when the time comes. I consider where you live and how you use the truck be a torture test compared to the mild climate we have here on Vancouver Island BC and although my truck will likely sit outside most of the time, it will probably get babied at least a bit.
One of the great things about the oils is they show off the character of the wood while still protecting it.
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
#13 | |
White K20 |
Thanks! I love my wood bed. Just basic southern yellow pine and I'm happy!
![]() j
White K20 |
#15 |
![]() Join Date: Jun 2022
It's good to get a rec from someone in the know, because there are lots of "oil" or "danish oil" products that contain little or no oil. These aren't necessarily bad products, because BLO and Tung don't wear well, but it's good to know what you're using and how long to expect it to survive in the wild
#16 | |
J ![]() https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
White K20 |
#17 |
Its a Truck Thing......
I am going to oil my bed on my stepper. Used a marine product and it didn't even last 6 months up here in the Vista outside. I have used Tung Oil on my house door and I like how it turned out. What are your thoughts on applying it without thinning?
Thanks Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#18 | |
![]() j
White K20 |
#19 |
I will pull the bed, strips and re-sand my boards then re-start the process. The bottom of the boards still look great with the Gleam 2.0 on it...Top sides, not so much.
Smitty
#20 |
This might be common knowledge, but you can add a product called "Japan Drier" to oil finishes and it will speed up the cure time. It's a catalyst, so also forces a cure throughout the film(otherwise it's from the surface in due to air contact, which can particularly suck with porous woods like oak)
"Japanning" is an old term for lacquer, btw, ICYGAS
1970 C10 Custom longbed 350/350 |
