Old 09-06-2016, 05:09 AM   #1
gmc 2500 4x4
WTB lower Radiator Retainers 4core
i need a pair of nice lower radiator retainers for the 4 core setup, not sure fitment years but its for my 69 gmc. thanx, paul
gmc 2500 4x4 is offline   Reply With Quote
Old 09-06-2016, 09:07 AM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB lower Radiator Retainers 4core
Can't help with a pair as only have one, driver's side with good rubber cushion. Passenger (battery) side was rusted out badly. Can do pics if interested, $8 shipped for the single I have. Maybe someone else has a single to make a pair for you? LMK if any interest.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 09-06-2016, 10:57 AM   #3
gmc 2500 4x4
Pics please pm sent
Old 09-06-2016, 02:10 PM   #4
Ironhorse
Ironhorse's Avatar
Lower radiator support mount. Hard to show detail of black items. Some rust pitting beneath cushion as usual but cleaned up well with bead blast, prime and paint. $8 shipped, don't have Paypal, money order or $$. Thanks,
Wellington, Ks
Old 09-06-2016, 03:16 PM   #5
gmc 2500 4x4
How long is the retainer
Old 09-06-2016, 03:40 PM   #6
Ironhorse
Ironhorse's Avatar
Metal retainer measures 4 3/16'' outside edge to outside edge. I know it to be a true 4 row lower radiator mount, NOT for the smaller 2 or 3 row radiators. LMK, thanks.
Wellington, Ks
Old 09-06-2016, 03:44 PM   #7
gmc 2500 4x4
I'm at work. I want to measure before I commit. Sounds like I have shorter ones. I let u no in a few hours
Old 09-06-2016, 05:35 PM   #8
Ironhorse
Ironhorse's Avatar
That measurement is just the lower retainer or saddle the radiator mounts into sitting on the rubber cushion. The upper mounts are different with the same type of retainer or mount spot welded to the upper mount. Measure your saddle or retainer mounts you have now. Are you swapping over to a larger 4 row radiator?
Wellington, Ks
Old 09-06-2016, 07:55 PM   #9
gmc 2500 4x4
this is where im at now, upper retainers sit bout an inch high for some reason. but the radiator hasnt been tightened down yet. got me worried. uppers fit top of rad fine.
Old 09-06-2016, 09:07 PM   #10
Ironhorse
Ironhorse's Avatar
Paul, are you working with a true GM 67-72 truck radiator or is it possibly an aftermarket replacement? Do the tank ridges line up with the bracket mount spacing correctly? The second pic looks to be the 4 row uppers. What do the brackets measure from front to back? What do your lower retainers or mounts look like now? " If " you are changing from a 2 or 3 row radiator and up-grading to a 4 row the lower radiator support channel needs a "relief" cut on the rear ward (engine side ) edge of the support channel. I had to do that to mine when I swapped from a 3 row to a 4 row as the 4 row lower mount hit against the channel. Not a BIG cut but just a small one to let the retainer set flat against the lower support channel. I fastened my lowers in with a couple sheet metal screws and then the rubber cushion, no problemo after doing that. Also, are you using new rubber cushions that have not been subjected to many years of being tightened? Hope this all helps, good luck.
Wellington, Ks
Old 09-07-2016, 05:23 AM   #11
w314speed
Paul- I have a pair of NOS lower retainers and rubbers. I will send pics tonight or in the AM. Don't know if new rubbers would make it sit even higher? Is the lower radiator seating deep enough in the rubbers and are they hard as a brick? Like Ironhorse stated about the size of the radiator, measure the old one to see if same. It should have 1/2 to 3/4 clearance to insure adequate pressure on the radiator at all times. If it laid flat and no pressure it would be loose when the rubber conforms and settles! Thanks, Dan
w314speed is offline   Reply With Quote
Old 09-07-2016, 05:31 AM   #12
gmc 2500 4x4
hey dan, i read some other folks had this delema, and im sure it just needs to be tightened down, rad measurements are correct. what is yur price? i have gm rubbers if you separate...paul
Old 09-07-2016, 07:06 PM   #13
otsenre
otsenre's Avatar
found it, here is what I got
otsenre is offline   Reply With Quote
Old 09-07-2016, 07:07 PM   #14
w314speed
Paul- I would like to sell as a package 2 lower radiator supports and 4 upper and lower rubbers, all NOS w/o packages. If someone wants the 4 rubbers and you the steel supports, we can split the package. $110 shipped for all $45 steels and $65 rubbers. Here are some pics of the steels! LMK, Thanks, Dan
Old 09-07-2016, 07:16 PM   #15
gmc 2500 4x4
otsenre whats yur price? them rivets should pop out
Old 09-07-2016, 07:18 PM   #16
gmc 2500 4x4
dan i need to purchase somthing now, i have rubbers, i need to get this motor goin. great price
Old 09-07-2016, 07:22 PM   #17
otsenre
otsenre's Avatar
Ill get them cleaned up tommorrow and show you pics after work
Old 09-07-2016, 07:32 PM   #18
gmc 2500 4x4
ok thanx, dan we'll play it by ear.
Old 09-08-2016, 04:12 PM   #19
w314speed
Paul- As good as they look before clean-up they should be as good as NOS. Thanks, Dan
Old 09-08-2016, 06:18 PM   #20
otsenre
otsenre's Avatar
Here you go Ill do 30 shipped if you like
Old 09-08-2016, 06:45 PM   #21
w314speed
If Paul passes! I'll take them!!!! Great parts out of CO! Dan
Old 09-09-2016, 08:35 PM   #22
gmc 2500 4x4
i'll take those sir!!!! how do you want paid
Old 09-09-2016, 09:12 PM   #23
w314speed
Great buy for you Paul!! Good luck on your build! Dan
Old 09-09-2016, 09:41 PM   #24
jr1000yarder
Can you do any better on all of it, I'm very interested. Thanks
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 09-11-2016, 11:08 AM   #25
gmc 2500 4x4
i need these asap!!!!
