Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-07-2016, 09:44 PM   #1
pwdcougar
pwdcougar's Avatar
Air compressor: rebuild or replace pump?
I have an upright Craftsman air compressor that doesn't build pressure as quickly as it used to. Thought it was the filter but swapping in a new one didn't change the recovery time. I used to be able to run my whiz tool (die grinder) or my sandblaster and it would run, build up pressure and shut off. Now the sandblaster and the whiz tool lose power and the compressor runs constantly and doesn't catch up.
I can get a complete brand new pump for about $190 or a ring and seal kit for about $90. It just doesn't seem right to spend the extra 100 bucks but considering I would get the whole pump.............
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
Last edited by pwdcougar; 10-07-2016 at 09:52 PM. Reason: spelled something wrong!
pwdcougar is offline   Reply With Quote
Old 10-07-2016, 10:59 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Air compressor: rebuild or replace pump?
picture of compressor, please
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-07-2016, 11:08 PM   #3
franken
Model number?
I'd say why not rebuild since chances are the new pump is from Asia.
My opinion after 4 compressors is if it isn't an 80 gallon Quincy or Saylor-Beall, why bother.
Old 10-07-2016, 11:12 PM   #4
pwdcougar
pwdcougar's Avatar
Not much to see I had to mount it facing the wall for clearance. It is a 60 gallon Craftsman, oil lubricated, single stage with a 3.7hp motor. 10 cfm @ 90psi. Two cylinders. Probably about 5 years old. Research says it is a Sanborn 165
Paul
Old 10-08-2016, 12:03 AM   #5
Warrens69GMC
Its what i wanted to see. Looks to be a aluminum head chinese pump
can get a replacement at harbor freight
http://www.harborfreight.com/145-psi...ump-67697.html
A quality replacement pump may cost a little more
http://www.ebay.com/itm/Kellogg-Amer...4AAOSwoydWp9pR
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-08-2016, 02:00 PM   #6
pwdcougar
pwdcougar's Avatar
Wow that's quite a difference! Thanks Warren!
Old 10-08-2016, 05:05 PM   #7
_Ogre
_Ogre's Avatar
i have a 18 yr old craftsman 10 cfm @90psi with a 7 hp motor that i never turn off unless i go on vacation
my neighbor has the same compressor as you have with the 3.7 hp motor and about the same age
it has the same problem where it won't build pressure
i think craftsman just used a cheap pump on them
i'd buy a new pump before wasting $90 on rebuilding a cheap pump
either way you'll still have a cheap pump
shop air compressor timer
Old 10-08-2016, 05:52 PM   #8
pwdcougar
pwdcougar's Avatar
Thanks Ogre
Think I'll spring for the new Harbor Fright pump that Warren provided a link for. At work we have a couple nice older IR compressors that run what's left of our pneumatic thermostat system. Next summer they are scheduled to be removed and the system upgraded to electric controls. I'll pick one of them up and rebuild it. The HF pump should last a year!
Thanks again guys
Paul
Old 10-20-2016, 08:42 PM   #9
pwdcougar
pwdcougar's Avatar
Hey Warren
Looks like I won't be able to score the one from work next year after all. They took the conversion out of the budget. I did a search on Ebay for 3hp pumps and came up with this one.
http://www.ebay.com/itm/EMAX-3-HP-Si...8AAOSwSclXK6WM
Is this one better than the Harbor Freight pump?
Paul
Old 10-20-2016, 08:51 PM   #10
pwdcougar
pwdcougar's Avatar
Or how about this one
http://www.ebay.com/itm/Powermate-3-...MAAOSwLqFV8hOc
Old 10-21-2016, 01:11 AM   #11
Warrens69GMC
Something like this:
http://www.ebay.com/itm/Champion-VP1...gAAOSwOdpX1wpK
or this
http://www.ebay.com/itm/Schulz-Singl...0AAOSwx~JWFA~V
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-21-2016, 08:48 PM   #12
pwdcougar
pwdcougar's Avatar
Thanks for the links Warren. Did you check out the ones in my links? They seem to have better CFM numbers but are they cheap sh*t?
Paul
Old 10-21-2016, 09:27 PM   #13
Warrens69GMC
They seem decent enough. I linked to more widely known quality compressors.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-21-2016, 09:34 PM   #14
pwdcougar
pwdcougar's Avatar
Ok great!
Thanks again Warren
Old 10-21-2016, 09:55 PM   #15
pwdcougar
pwdcougar's Avatar
Sorry for being a pain. I've been comparing the photos in both of your links and I believe they are the same brand of pump. The Champion pump shows a picture with a Shultz data plate!
Paul
Old 10-23-2016, 02:20 PM   #16
pwdcougar
pwdcougar's Avatar
Warren
Made an offer on the Champion pump and will get it for $200 shipped. Thanks again.
Paul
Old 10-23-2016, 11:12 PM   #17
Warrens69GMC
Awesome!! should last for many years!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-27-2016, 08:38 PM   #18
pwdcougar
pwdcougar's Avatar
The new pump came in and now I've got another problem. The original chinese pump has two things going into the pump head. One is the the supply to the tank and the other goes into the pressure shut off. The new pump doesn't have the tapped fitting for the pressure switch line. Any ideas on how to plumb this?
Paul
Old 10-28-2016, 07:57 AM   #19
truckdude239
truckdude239's Avatar
My champion pumps at work the pressure cut off is pumbled to the tank
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-28-2016, 12:49 PM   #20
pwdcougar
pwdcougar's Avatar
Thanks David. I'm not sure the tank wall is going to be thick enough to drill and tap though. I'll have to look and see if there is a good location to do it.
Paul
Old 10-28-2016, 03:07 PM   #21
Marv D
Registered Truck Offender
Marv D's Avatar
Why not just use a T fitting at the tank and read PSI off the pressure line from the compressor?????
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-28-2016, 04:33 PM   #22
truckdude239
yea you really dont wanna drill the tank ours are made that way with a place welded in
David fuller
2000 Tahoe 5.3l 378
Old 10-28-2016, 06:01 PM   #23
pwdcougar
pwdcougar's Avatar
I think the small line feeds the gauge and pressure switch. The T fitting at the tank should work.
Thanks Marv
Paul
Old 10-29-2016, 12:56 AM   #24
Warrens69GMC
Some of the compressors use a t fitting at the inlet
http://2.bp.blogspot.com/-ynDHNO_Klr...422_094716.jpg
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 11-04-2016, 10:54 PM   #25
Rannoch
Paul
Is the pressure switch also plumbed to the tank?
The 1/4" line is probably for the unloader valve, it empties the pressurized air out of the cylinders/line so the compressor starts easily and doesn't damage the motor.
Rannoch is offline   Reply With Quote
