10-12-2016, 10:14 PM | #1 |
Front sway bar diameter
Is a factory front sway bar for our trucks 1 1/4 inch? I need to replace my bushings, so I need the right size.
10-12-2016, 11:01 PM | #2 |
the boat guy
Re: Front sway bar diameter
They didn't have factory sway bars 67-72. 73-87 had a couple of different sizes. Measure yours.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
10-13-2016, 03:00 AM | #3 |
Well, my 69 GMC has a factory sway bar. It is mentioned on the SPID. I've been under the truck, and seen it for myself. I will try to find time to put a caliper on it tomorrow to give you the exact OD of this piece, but the rain is coming down pretty heavy right now, so don't hold me to the time.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
10-13-2016, 05:19 AM | #4 |
Pretty sure the factory bars on 1/2 tons were 1 1/8, mine is from a 80s 1 ton 2wd is 1 1/4
10-13-2016, 11:01 AM | #5 |
Mine did come from a 70, I just have to measure it with my calipers. I was just hoping someone would know offhand.
10-13-2016, 01:07 PM | #6 |
It depends. Stock 1/2 tons were 1-1/8" while the 3/4+ ton trucks were 1-1/4". The majority of aftermarket bars are the larger 1-1/4"...
I would measure just to be sure. The 67-72's absolutely had optional factory sway bars... GM didn't drill holes in the A arms and frame that are a perfect match for sway bar mounting brackets for nothing...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-13-2016, 01:23 PM | #7 |
OEM that ive seen for our era. starts at 7/8"
ive pulled em off square bodys. and they come up to 1 1/4" and they fit just fine
1967custom |
10-13-2016, 01:35 PM | #8 |
My 67 is a 7/8" stock with a 327 engine.
10-13-2016, 02:54 PM | #9 |
Wow, I didn't remember them being that small (mine has the aftermarket 1-1/4").
That's what makes this forum great.
10-13-2016, 03:42 PM | #10 | ||
"I ain't nobody, dork."
My 1972 GMC C1500 has a factory sway bar that is 1 1/16".
Gary
10-13-2016, 08:03 PM | #11 |
i replaced mine from summit racing. just entered year make and model and there they where from moog. i used the rubber ones. think they where 1 1/16? and they only had them in blue. perfect fit
10-13-2016, 08:08 PM | #12 |
Were the Suburban sway bars the same size as the 1/2 ton C10s? I took one off a 1970 Suburban and put it on my 1970 1/2 ton C10.
10-13-2016, 11:58 PM | #13 |
the boat guy
Oooh I learned something.
10-14-2016, 12:49 AM | #14 |
I have a 1 1/16" front bar from a 68 C10 CST. I just got these from eBay, they fit perfect.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
10-14-2016, 01:00 AM | #15 |
I think if it got power steering it got an antisway bar.
Not saying if it didn't have power steering it couldn't have an antisway bar. |
10-14-2016, 02:15 AM | #16 |
Yep, my 69 does NOT have power steering, and it DOES have the anti sway bar.
10-14-2016, 11:18 AM | #17 |
My 71 has power steering and no sway bar
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
10-14-2016, 06:59 PM | #18 |
I thought the CST and Cheyenne got a sway bar. I know my Cheyenne Super had one.
10-14-2016, 07:55 PM | #19 |
Mystery solved. I got down an measured. Mine is 1 1/8 inch type. I have the new bushings ready to put in.
Does anyone know if there is a rear sway bar.for a C-10 with the trailing arm suspension? The Panhard Bar sort does the same thing, but I've have been told there are sway bars made, which I think would be an improvement |
09-08-2024, 11:15 PM | #20 |
I need a 1-1/4 for my 67 GMC. So I read I have to drill the locating holes. After driving this truck over 1000mi this year, I can feel the sway, a sway bar and GV overdrive, this truck is ready for winding roads, and long trips.
09-08-2024, 11:55 PM | #21 |
hi guys, my gmc didnt come with a front bar. I found a 7/8 at the wrecking yard and put it on. it was better. then I found a 1.250 at the yard and put it on. big difference. btw my a arms were drilled.
09-09-2024, 07:36 AM | #22 |
I guess I need to go junk yard crawling. Had 2 guys locally looking for sway bar set-up, found nothing.
09-09-2024, 07:54 AM | #23 |
I have a spare sway bar that was on my '67 c10 when I bought it. It was on the SPID so I'm sure it was factory.
I just went to the garage and measured it. It measures 1-1/16" diameter and has the brackets that bolt directly to the lower A-arms, no links like the aftermarket ones.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-09-2024, 08:22 AM | #24 | |
I wonder if angle from frame to A Frame is different? |
01-20-2025, 07:53 PM | #25 |
What fasteners are used on the A-Frames, std bolts. Or special.
