Old 11-05-2016, 01:28 PM   #1
FAKKY
57 Panel "FAKMLC" build
It begins
Bought the truck a few months back - planned to drive to work for fun before tearing down and doing a restomod. Well the rear gears whining, no AC and just a bumpy ride had me park the truck and today I'm starting teardown.
57 Chevy Panel 3100. Paid $8250. Had less rust than other trucks I had seen and my wife loves "hearses" so this was a good blend of the apache look at front to hearse at rear with the ability to have the dogs and/or sleep in rear on trips in the future.
Plans.
Dakota IFS front suspension and power steering from Industrial Chassis.
8.8 Rearend from mustang/explorer.
LS swap. Shooting for a 6.0 but might be a 4.8 or 5.3 and turbo it later.
New side windows and air vent windows, new door latches.
AC.
My background. My name is John. Work in IT. 5 years ago bought a 2001 diesel truck. By the time I got it home had a fuel supply issue that killed the IP so a bill for $3k finally got me in learning to turn a wrench. However NEVER done anything like this. Have replaced injectors, turbo kit (bolt in mostly), suspension kits and replaced transmission with a friend - but I find once you've done it once ...... its not that bad ..... just takes me 4x as long as most people
Looking forward to building this and appreciate in advance all the people that have helped me so far with ideas and info and will be helping ,me on this and other forums. You guys make the difference in getting things like this done. kudos.
As I bought it.
FAKKY is offline   Reply With Quote
Old 11-05-2016, 01:34 PM   #2
FAKKY
Re: 57 Panel "FAKMLC" build
Old 11-05-2016, 07:43 PM   #3
Kim57
Kim57's Avatar
Sounds like a nice build.
Good looking truck to start with.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-06-2016, 02:01 AM   #4
Nut Case
Nut Case's Avatar
FAKKY
You need to add one more statement to the "takes 4X's longer" just include that sometimes you need 3 do overs.....
Fun project, don't know what custom level your shooting for, but consider chopping the top 1-1 1/2 inches just enough to have some folks scratching there heads trying to figure out what makes it look so good.
Just puttin it out there...
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 11-06-2016, 10:58 AM   #5
yossarian19
Subscribed.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 11-06-2016, 02:32 PM   #6
FAKKY
Thanks guys.
Got the front clip off and the side panels. Lots more sheet metal clips than my old truck.
Tip for others.
Consider removing wheels and placing on Jacks to make getting to the 8+ bolts in the fender wheel part easy and quick to remove. Other tip .. you literally have to remove every bolt you can see including all those by front clip and support at rear near door hinges reverse side.
Old 11-06-2016, 02:36 PM   #7
FAKKY
Worst part so far....... came across more rust damage than I was hoping at point where front fender panel connects to firewall/main body section ..... right where the lower door hinges are. Lots of damaged metal and soft metal here so I'm curious to hear on what options to fix when I eventually put back together
Old 11-06-2016, 04:14 PM   #8
FAKKY
Old 11-06-2016, 07:44 PM   #9
FAKKY
Wonder if that rusted part is is piece #11 in the lmc catalog here.
Called hinge pillar.
Not sure if that's the only part might call lmc tomorrow.
Old 11-07-2016, 09:11 AM   #10
Kim57
Kim57's Avatar
I think #11 is the outer piece and #12 is the inner piece.
Kinda hard to tell from the grainy catalog page.
Kim
My build thread
Old 11-07-2016, 09:20 AM   #11
Advanced Design
Advanced Design's Avatar
Nice looking panel John. I will be tagging along.
Advanced Design is offline   Reply With Quote
Old 11-07-2016, 11:26 AM   #12
svr
svr's Avatar
Hard to tell for sure but looks to me like parts 11 and 12 might need replaceing, I just did #12 on both sides of mine, 11 was ok.
svr is offline   Reply With Quote
Old 11-07-2016, 02:15 PM   #13
FAKKY
Not sure how to edit the original #9 posting ..... cant see an edit button.
Old 11-07-2016, 09:39 PM   #14
Kim57
Kim57's Avatar
Looks like #12 is the inner piece by their description. I would replace both just to be safe.
Kim
My build thread
Old 11-10-2016, 01:37 AM   #15
Techie79
Nice looking project you have there. I'm glad to see that I'm not the only IT guy crazy enough to tear into a project like this.
Im dealing with the same rust problem on mine. That is definitely #12 with the big rust hole in it. You will probably wat to take a good look at 10, 11, and 14 while you are in there.
____________________
My Build Thread - 1958 GMC 100 Stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=683165
Techie79 is offline   Reply With Quote
Old 11-10-2016, 08:58 AM   #16
FAKKY
Thanks guys.
Haven't done anything last couple days with elections, work and other stuff. Going to be a way for a week sunday as well. If I can get to it will pull linkage and have engine ready to pull and do a compression and leakdown test on existing engine.
Made my own leakdown tester ........
Old 11-10-2016, 10:18 AM   #17
northern 85
northern 85's Avatar
Very cool truck!!!!!!
northern 85 is offline   Reply With Quote
Old 11-10-2016, 02:26 PM   #18
YahamaR1
YahamaR1's Avatar
Nice panel..
Looks good
Good luck with your build,
And post a lot of pictures
YahamaR1 is offline   Reply With Quote
Old 11-12-2016, 11:44 AM   #19
FAKKY
Did a compression test completely cold engine had sat for over 2 weeks.
But basically pulled plugs and disabled distributor and coils
Cold motor and didn't touch throttle open
119-122 across all 6 cylinders.
Looks pretty good
Probably going to do leakdown just because I made my own gauge for when I go buy an engine.
Then pull linkages rest of today ...... away for a week tomorrow but engine out next Monday?
Old 11-12-2016, 01:57 PM   #20
FAKKY
Looks like only real way to turn motor manually is via removal of starter and flywheel teeth.
Crank pulley looks like it's pressed on.
Alternator just spins the belt.
Old 11-12-2016, 02:41 PM   #21
yossarian19
Pressed on or not, I can't imagine there aren't at least threads in the snout of the crank to work with. Right? LS motors have a tapered / press fit crank pulley, but forgodsake they have a bolt in there as well.
"Over my head"
Old 11-12-2016, 03:18 PM   #22
FAKKY
Yep beat me 2 it ....... two bolts threaded in front I can turn with a small pry
Bow gave to work out how to get base of manual transmission shift stick off ...... doest look like a press and turn or a slip coupling ..... not sure yet
T5
Update.....
1.45 into this video .... God bless youtube
https://youtu.be/5VHU6eHDPrE
Old 11-12-2016, 03:24 PM   #23
FAKKY
1st cylinder took up to 70 psi and measure 61 on leakdown side.
Damn hard to hold crank with 1 hand at 70 psi lol
Old 11-12-2016, 03:59 PM   #24
FAKKY
Leakdown results
#1 70/61
#2 80/70
#3 70/66
#4 70/63
#5 70/65
#6 80/70
Only reason for 80 rather than 70 2 times was trying to hold Guage and crank and hit in off at same time ......no helper today
For an unknown history engine.... seems decent.
Old 11-24-2016, 03:17 PM   #25
FAKKY
So been tied up last 2 weeks but have some time over Thanksgiving. Tried pulling engine and transmission together today and don't think I can due to a winged bottom of t5 transmission.... about an inch to little clearance through crossmember. So going to pull separately tomorrow.
Question on disconnecting manual transmission from engine. Do I do it at the four or five bolts that join the main transmission (silver) to bellhousing.... this will leave clutch and bellhousing on engine. Or do I remove at bellhousing .... I can only see two top bolts here ???
Also anything need to be disengaged .... I think she's in neutral but hard to tell now shifter is out.
