Old 12-15-2016, 12:23 AM   #1
uxdesigner
UXDesigner's 1967 C10 - The Keeper
Well folks, it took only 7 months after selling my previous build to get back in the game. I'm more motivated than ever and looking forward to building a truck that's a "keeper" based on what I learned from the previous build and all of you! A bit delayed on the progress so I'll start with a quick summary to get us to where the build stands to date.
July 15th, 2016
uxdesigner is offline   Reply With Quote
Old 12-15-2016, 12:37 AM   #2
uxdesigner
Re: UXDesigner's 1967 C10 - The Keeper
Researched many color combos for hours but ultimately decided on a pearl red and pearl white two tone. Its a classic paint scheme but I wanted to mix it up a bit with the pearl white as the accent and no white top.
Old 12-15-2016, 12:42 AM   #3
uxdesigner
2006 5.3 w/ 4L60e
September 2, 2016
Old 12-15-2016, 12:50 AM   #4
uxdesigner
Shoes must go on first!
Foose Legend
Front - 20x8.5 (255/35/20)
Rear - 20x10 (275/35/20)
Old 12-15-2016, 09:28 AM   #5
solidaxel
solidaxel's Avatar
Good Choice !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-15-2016, 06:48 PM   #6
uxdesigner
I had great success with the CPP's products on my last build so I went ahead and used the same. I upgraded to the headers instead of the TBSS manifolds and I'm really happy I did. Clearance is excellent and the sliders make the install super simple with the 4L60e.
Doug Thorley Headers (THY-322Y-C)
CPP Tubular Motor Mount Perches (6372MP-SM)
CPP Tubular Transmission Crossmember (CP9427)
Poly Tranny Pad (3-1108G)
Poly Motor (3-1114G x2)
Old 12-15-2016, 06:59 PM   #7
uxdesigner
For the fuel system I decided on the Aeromotive 18688 Phantom 340 Fuel Pump System. It's a bit more expensive than the typical external pump setup but the amount of time I saved alone was worth it. The truck already had the aluminum fuel tank relocated to the rear so it was as simple as cutting the hole (template provided) dropping it in and running the wires and fuel lines. For the fuel lines I kept it simple. I once again used the Russel Pro Classic braided fuel line, AN fittings at every connection and a stock fuel filter on the frame rail.
Old 12-15-2016, 07:28 PM   #8
uxdesigner
The fuel pedal was a challenge, the engine I picked up did not come with the TAC or the fuel pedal so I searched around and ended up finding one on ebay. The listing even included the bracket which made the really easy. If you plan on doing a DBW fuel pedal, make sure you get the bracket. Only requires a simple bend on the lower tab of the bracket to match the cab floor angle, a few spacers (i used screw nuts) and drilling the new holes in the firewall and floor.
Old 12-15-2016, 07:46 PM   #9
uxdesigner
The truck came with a very nice Flaming River tilt column and the power steering conversion was complete and fully functional. I didn't want to mess with converting to a column shift so I went with a new short 4L60e shifter kit and I'm really happy with it. I still need to weld up the hole for the aftermarket emergency brake that I don't plan on using.
Old 12-15-2016, 07:50 PM   #10
uxdesigner
First Start: October 1, 2016
Old 12-15-2016, 10:35 PM   #11
solidaxel
solidaxel's Avatar
I did not think the LS would run that smooth without the MAF hooked up.
Did you have the O2 hooked up?
Aluminum heads heat up pertty fast, did you have any water in the block?
LS 3 4L70E
Old 12-16-2016, 10:38 AM   #12
Hart_Rod
Hart_Rod's Avatar
Looks like a great start.
Hart_Rod is offline   Reply With Quote
Old 12-16-2016, 01:05 PM   #13
uxdesigner
I was also surprised how smooth it ran, I did have the O2's hooked up so that certainly helped. Good call on the temp, I only ran it for a bit but you are correct.
Old 12-16-2016, 01:50 PM   #14
RRR18
RRR18's Avatar
I'm watchin.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 12-19-2016, 12:52 PM   #15
uxdesigner
Received all new Mar-K chrome trim this weekend, well packaged and quality is excellent.
Old 12-19-2016, 01:02 PM   #16
uxdesigner
Stock auto transmission cooling lines snap right into the radiator with these adapters, Simple install, lines only needed a couple of bends.
Old 12-19-2016, 04:34 PM   #17
RRR18
RRR18's Avatar
Mar-K gotta be one of the best places I've ever talked to and/or ordered from.
'67 BAD IDEA
Ryan
Old 12-20-2016, 08:13 AM   #18
solidaxel
solidaxel's Avatar
Mar-K has a lot of my money !!
LS 3 4L70E
Old 06-06-2017, 11:40 PM   #19
uxdesigner
The long process of sanding, welding and body work begins. Looks like the PO sprayed paint directly on new reproduction metal without primer. Paint literally peeled off in chunks with compressed air.
April 22, 2017
June 3, 2017
Old 06-07-2017, 05:04 AM   #20
GR8-68
GR8-68's Avatar
Awesome build !!! Look forward to more updates and I love the color scheme and choice
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-07-2017, 09:18 AM   #21
Smittee
Like Larry said, looks like a great project! It is better the second time around, isn't it?
I thought I had heard of Rocklin; I have family in Roseville! Rode the motorcycle out there two years ago. Plan to do that same trip in the '68 when I get it done. Hopefully August 2018 will be the time frame. When I get out that way maybe I can catch you at a cruise in.
Subscribing to your thread to watch and maybe learn something from you. The more ideas the merrier.
Smittee is offline   Reply With Quote
Old 06-11-2017, 01:03 PM   #22
NewType72
NewType72's Avatar
Well the good thing about that kind of peel is that it's less troublesome on the sanding joints lol
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-11-2017, 01:18 PM   #23
darkhorse970
darkhorse970's Avatar
I like the plan, subscribed.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 06-24-2017, 11:21 AM   #24
uxdesigner
Started cleaning up the firewall and front frame. Worked on getting the wire fuel pedal grommet hole correctly sized. Plan on epoxy priming the firewall soon to get the engine back in and space back in the garage to get paint started.
Old 06-25-2017, 04:56 PM   #25
uxdesigner
Managed to get the firewall and front end frame epoxy primed.
