Old 03-13-2017, 08:34 PM   #1
farmfieldfinds
White Lightning - 68 C10 Shortbed Stepside
After viewing the boards the past few months, I decided that I should create a build thread for my latest project.
I found this 68 in a construction company's storage lot in San Antonio. Fortunately some hundred dollar bills and a flatbed was all that we needed to bring it home. Based on a teal paint job, I'm guessing the truck was restored in the mid 90's as I can't imagine anyone picking that paint color anytime in the past 20 years. Original color was light blue. I'm calling this truck White Lightning because of 2 reasons:
1. I'm painting the truck Gloss White
2. I have a brand new 350 with close to 400 horsepower so the truck should haul!
I'll try and post pics every few days. I'm hoping to have this truck ready for eBay in a few weeks.
Ben
I dig through fields and trailer parks for cars and trucks to flip or restore.
farmfieldfinds is offline   Reply With Quote
Old 03-13-2017, 08:40 PM   #2
farmfieldfinds
Re: White Lightning - 68 C10 Shortbed Stepside
Removed the rusted out radiator support (darn battery acid) and started getting the engine ready for removal!
Ben
Old 03-13-2017, 08:41 PM   #3
flashed
It looks pretty solid .
flashed is offline   Reply With Quote
Old 03-13-2017, 08:45 PM   #4
farmfieldfinds
Pulled this nasty old master cylinder and ordered the CPP 12" Disc Brake conversion kit with 2.5" drop spindles and new master cylinder. Of course I had to get the red Wilwood calipers and a new 9" booster. Power brakes here I come!!!!
Ben
Old 03-14-2017, 06:38 AM   #5
GR8-68
GR8-68's Avatar
Looks like a great project, look forward to the updates on it
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-15-2017, 11:19 AM   #6
farmfieldfinds
With a little bit of tugging and a lot of pulling, the engine popped out! Managed to get $175 on Craigslist for the engine minus the power steering pump and flex plate.
Ben
Old 03-16-2017, 03:10 PM   #7
farmfieldfinds
Starting to grind the engine bay and front end in preparation for painting and new drop spindles.
Ben
Old 03-21-2017, 10:18 AM   #8
farmfieldfinds
Drop spindles are in! On the driver's side I had to literally beat the original in order to get it apart. I did find out that the Advanced Auto spring compressor that I bought wasn't up to the task. I ended up renting (free rentals) from O'Reilly.
Ben
Old 03-23-2017, 02:36 PM   #9
farmfieldfinds
Wow, the picture doesn't do these calipers and rotors justice!!! I can't believe how easy they were to install. I replaced the hard lines as well with the ones from Advanced Auto. Super easy to bend around the engine compartment! The hardest part was finding the adapter from the back of the proportioning valve to the rear brake line. I had to stop by 3 stores.
Ben
Old 03-27-2017, 12:32 PM   #10
farmfieldfinds
Radiator support is in! Kind of like a puzzle stacking the metal washers, shims, and rubber washers that hold the support in.
Ben
Old 03-30-2017, 10:39 PM   #11
farmfieldfinds
There is a 350-400 horse present under this wrapping paper!!!
Ben
Old 03-30-2017, 10:40 PM   #12
farmfieldfinds
Why would anyone put this ugly bumper on a C10????
Ben
Old 03-31-2017, 03:39 PM   #13
farmfieldfinds
Fun times replacing the passenger side rocker!
Ben
Old 04-02-2017, 09:18 PM   #14
farmfieldfinds
I finished the inner floor piece, mocked up the rocker, mounted the door to check alignment, and welded in the rocker. Turned out pretty good. Now for the driver's side!
Ben
Old 04-03-2017, 07:24 PM   #15
farmfieldfinds
Not having the bedwood in is very convenient having all this natural light shining under the bottom of the truck!
Ben
Old 04-05-2017, 08:16 AM   #16
farmfieldfinds
Yeah, I guess I'll be ordering a new sending unit!!!!! To clean out the gas tank, here is what I did:
1. I drained the tank and let it dry for a few days.
2. Knocked the tank around a bit to get any rust chunks out.
3. Dumped in a quart of acetone and swished it around a bit. After around 30 minutes, I drained the tank and let it dry for a few days.
4. After drying, the last few bits and pieces of rust came out.
Under the cab I added a see through fuel filter. The filter did turn a little brown but I didn't see any bits of rust in the filter so my steps worked!
Ben
Old 04-11-2017, 04:50 PM   #17
farmfieldfinds
Almost like Christmas came early. What could be hiding under that wrapping paper? Could it be a brand new 350 with somewhere between 350-400 horsepower?!?!?!
Ben
Old 04-11-2017, 04:53 PM   #18
farmfieldfinds
Starting to add all of the front components. I tried to piece this together from random parts places. I should have just bought a complete set from March or Summit that includes all of the billet brackets and all of the accessories.
Ben
Old 04-12-2017, 03:22 PM   #19
farmfieldfinds
Radiator is in and truck is heading to the mechanic shop to have the engine installed!
Ben
Old 04-12-2017, 04:11 PM   #20
Phill0406
Phill0406's Avatar
Great work so far! I'm glad to see that ugly bumper going away haha.
Keep us updated
Phill
68 Anniversary build - LS swap & Porterbuilt
Instagram @fourdoorphill
Phill0406 is offline   Reply With Quote
Old 04-17-2017, 03:30 PM   #21
farmfieldfinds
Engine is installed and turned out to be a beast! Truck runs great and sounds incredible!!!
Ben
Old 04-17-2017, 03:36 PM   #22
farmfieldfinds
Engine running video: https://youtu.be/jFNRKXTCgXs
Ben
Old 04-17-2017, 05:21 PM   #23
flashed
Looks and sounds great .
Old 04-18-2017, 03:37 PM   #24
farmfieldfinds
Something interesting about this truck....notice how the front frame cross member has the 1/4 circle cut out of it. I can't figure out why someone would do that. The truck had an inline 6 in it but there was plenty of clearance. Obviously there is still plenty of clearance even after I put in a 350. Maybe someone had a big block in this truck sometime in the past? But why would you pull a big block and install an inline 6? I always find something weird done to these old trucks.
What's the weirdest thing you've discovered in a build???
Ben
Old 04-20-2017, 06:07 PM   #25
farmfieldfinds
Drivers side rocker is in and all floor repair is complete!
Ben
