Old 04-04-2017, 01:20 PM   #1
The Swed
The Swed's Avatar
Strange vibration at 60 MPH and above.
Some facts, my truck has a rebuilt 350 and rebuilt TH350, rims are straight and balanced both brake drums in front are new/replaced. The vibration starts at 60 MPH and the tac reads 3000 RPM and 3500 at 70 MPH. I have disengaged the transmission at 70 and the vibration is still there I also put the transmission in 1st and ran it all the way to 4000 RPM with no vibration so I believe it’s mostly likely the drive train? So U joints, drive shafts, or that axle bearing? What are your thoughts? Thanks in advance for your inputs!
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 04-04-2017, 01:29 PM   #2
MARKDTN
Re: Strange vibration at 60 MPH and above.
Sounds like driveshaft.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-04-2017, 01:54 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Put it on a lift -- have someone in the driver's seat start it, put it in gear, and gradually increase speed while you eyeball the ujoints & bearing.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-04-2017, 11:00 PM   #4
yuccales
yuccales's Avatar
Don't forget to check all four of your tires. I had a shake up front, turned out to be a big bulge on the inside of a front tire.
yuccales is offline   Reply With Quote
Old 04-05-2017, 10:45 AM   #5
weq92f
weq92f's Avatar
My guesses in order:
Carrier bearing
U-joints
shaft balance
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-05-2017, 11:42 AM   #6
demian5
demian5's Avatar
Do you feel it in the steering wheel/feet or the seat?
Steering Wheel/feet = Front end.
Seat = Anything rearward of the front end.
I tested it just like you. I aligned mine and it made a huge difference. I do have a bad upper ball joint I need to replace that i imagine makes it a little floppy still. But the alignment and front wheel balance and its a new truck.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-05-2017, 12:11 PM   #7
Orange67
Orange67's Avatar
Hey man, got your pm. I will text you later, been out of work sick.
I would start by grabbing the driveshaft (either side of the carrier bearing) and push it side to side, or up and down. You should have VERY little movement if any at all. I would watch the bearing closely, if it is worn out, you will see it.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 04-05-2017, 12:22 PM   #8
davepl
davepl's Avatar
In these trucks the carrier bearing is a normal wear and service item and needs to be replaced. How often I don't know, but if you haven't done it on that truck, odds are that's the culprit.
After that the normal suspects of driveshaft, u-joints, wheels, etc...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-05-2017, 06:03 PM   #9
The Swed
The Swed's Avatar
In the seat!
BTW that bearing may have a 136,000+ miles on it
Old 04-05-2017, 08:07 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
I have never seen a carrier bearing cause a vibration until its coming apart. The rubber that holds the bearing is relativly soft and allows some movement of the shaft and dampens driveline vibrations, ifthe rubber is loose that would be a sign of a vibration. Check for lateral play in te slip and stub, check for play in the ujoints, make sure the shaft is in phase the way it was balanced, make sure the trans yoke has just a little lateral play.
If the front shaft is out of balance it can cause an uneven wear pattern around the tranny yoke.
brad_man_72 is offline   Reply With Quote
Old 04-13-2017, 03:35 PM   #11
The Swed
The Swed's Avatar
Well it's not the carrier bearing... took it to the shop that rebuilt the engine and they can't figure it out. I can' t effort to just throw money at it until it's fixed so it's going into to the garage to be stored. Thanks for all the input.
Old 04-13-2017, 07:11 PM   #12
brad_man_72
the boat guy
I doubt the shop that built the engine knows anything about driveshafts much less has a $60k driveshaft balancer. You wouldn't believe the wrecks that professional mechanics bring me to fix.
I've seen shops that couldn't diagnose an out of round tire. Hell its hard to find a mechanic these days in a world full of parts swappers and hammer pilots.
Old 04-14-2017, 03:41 PM   #13
The Swed
The Swed's Avatar
Well the local six state driveline mechanic in Ogden, Utah is now working for the place that rebuilt my motor which restores vehicles from the ground up and everything in between so in my mind that gave them more credibility in the driveline area. They did find that the drive shaft was clocked wrong and fixed it but the vibration still remains. BTW the vibration feels more like a hopping up and down and I've never felt that in vehicle before accept at the drive in movies. I must admit I had to rework work performed on my newer vehicles that I paid top dollar for at a dealership that was so screwed up so I hear you brad_man_72. I refuse to replace parts hoping I luck out and get it right. There has to be a way to isolate the problem.
Old 05-02-2017, 01:02 PM   #14
The Swed
The Swed's Avatar
Update,
I'm driving the truck daily putting 70 miles a day in and 95% of the time the truck doesn't have an issue. Does anyone have any other ideas what this may be? The fact that it comes and goes should be a clue and point to something.
Old 05-02-2017, 01:31 PM   #15
demian5
demian5's Avatar
Originally Posted by The Swed View Post
Update
I'm driving the daily putting 70 miles a day in and 95% of the time the truck doesn't have an issue... and more idea what this may be?
Old truck?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-02-2017, 01:44 PM   #16
davepl
davepl's Avatar
I had a REALLY strange one (bad shudder under light accel from a stop). After trying just about everything and giving up, I took the driveshafts to a local specialty shop. They found wear in the splined section.
I couldn't feel it, and honestly thought I was being scammed, but I was desperate and so I relented and let them replace the whole splined section. They did that and it solved the problem.
Lesson learned: there's a lot about driveshafts that I don't know, and I was surprised at the weird problems they can solve/cause.
If you have a friend or some other access to a 2-piece driveshaft, it'd be a cheap test if you could swap to see if the problem transfers over or goes away.
Old 05-02-2017, 04:40 PM   #17
DBK81
DBK81's Avatar
It's 100% in your driveshaft area, but the million dollar question is where? What if anything did you do to your drive line just before these issues appeared? Might help diagnose the cause.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 05-02-2017, 04:50 PM   #18
demian5
demian5's Avatar
Or if the engine rebuild has something to do with it like the wrong flex plate or balancer for the engine.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-02-2017, 11:21 PM   #19
Metaldoc
Metaldoc's Avatar
I had a bent axle in an older car that did that. May have have been a pot hole or curb that bent it, but only out a bit.
Metaldoc is offline   Reply With Quote
Old 05-03-2017, 12:10 AM   #20
The Swed
The Swed's Avatar
It started vibrating again so I took it up to 85 mph and the tach was over 4ooo rpm and it smoothed out. Im trying to break it now so know what to fix. I may end up a stain on the wall but at my age I just don't care.
Old 05-03-2017, 07:50 AM   #21
Grumpy old man
Grumpy old man's Avatar
From the looks of the picture you posted of the drive shaft it hasn't seen any grease in years . Rebuild your drive shaft and check the spline play while it's apart . These old trucks require regular servicing and that includes a liberal amount of grease . Running it up to 85 to see what lets go may just be a really bad idea ? It's almost 50 years old show it some love ...
Old 05-03-2017, 08:10 AM   #22
weq92f
weq92f's Avatar
It started vibrating again so I took it up to 85 mph and the tach was over 4ooo rpm and it smoothed out. Im trying to break it now...
Good luck. These old trucks are tough.
Can't tell you how much time I've spend at ~4000 RPM going down the highway as fast as it would go ( 68 short step 350/350 3.73 ). I broke mine once following a semi trailer real close to try to save gas. The tranny got too hot and ate itself.
-klb
Old 05-03-2017, 08:12 AM   #23
Shinysideup
Shinysideup's Avatar
Re-balance the tires. Its classic symtom of that. Smooth to 65ish,shakes like heck at 70ish, then smooths back out at 80. Hmmm.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 05-03-2017, 08:26 AM   #24
WorkinLonghorn
WorkinLonghorn's Avatar
Yeah, and find a place that can do it while on the vehicle. There's a device with an electric motor and a small rubber wheel that contacts the tire and spins it up.
Are your wheel bearings in good shape and adjusted to spec?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-03-2017, 02:07 PM   #25
cleszkie
cleszkie's Avatar
I had belts in my tires creep one time. The tires would balance out just fine, but were basically out of round. Caused a vibration around 70 mph and no other time. Took me a long time to figure it out. Belt creep caused by rotating tires to opposite side of truck and reversing the rolling direction. They were an old set of BFG KO A/Ts. Replaced the tires - smooth as glass now. Now I rotate front to back to keep rolling direction the same. Just something to consider.
cleszkie is offline   Reply With Quote
