Old 04-29-2017, 11:14 PM   #1
SLDPULR
SLDPULR's Avatar
My 1980 Silverado build thread
Hey guys and gals. Just wanted to start a build thread for my 1980 short bed. So here is the history.
The truck is a 1980 Short bed Silverado 2WD that I bought from my Father in-law. The truck had been stored in is shop for the past 10 years. It has 80,000 miles and was pretty much bone stock minus the .243 bullet hole in the floor. It still has the functional 8-track player .
So far I have pulled out the blown 305 and installed the motor I originally built for my 69 C10. I do need some help with the motor but ill get that in a later post.
Here is the stats so far.
SBC 383
BORE: 4.030
STROKE: 3.750
DECK HEIGHT: .025
CYLINDER HEAD VOLUME: 72CC
HEADS: 190CC RUNNERS
HEAD MATERIAL: ALUMINUM
GASKET THICKNESS: .032
COMPRESSION RATIO: 10.03:1
PISTON: FLAT TOP SINGLE VALVE RELIEF
CAM: COMP CAM XE294H
TIMING CHAIN: DOUBLE ROLLER
ROCKER ARMS: ALUMINUM 1.5
DIST: MSD PRO BILLET/MSD 6AL
INTAKE: RPM AIR GAP
CARB: 750 HOLLEY DP MANUAL CHOKE
TRANS:TH350C
CONVERTER:3000 STALL
HEADERS: 1 5/8 LONG TUBE
EXAHUST: 3" WITH X-PIPE
MUFFLERS: 3" BORLA OFFSET/OFFSET
GEARS: 3.08:1 (I think)
Here is my 69 going to a new home.
Day I brought it home.
Old 305.
Interior.
How i found it.
Getting the motor ready.
Motor going in.
My helper.
Motor in and all cleaned up.
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES)
SLDPULR is offline   Reply With Quote
Old 04-29-2017, 11:24 PM   #2
SLDPULR
SLDPULR's Avatar
Re: My 1980 Silverado build thread
My plans as of right now....
3/5 drop
Weld S71-B wheels
Detroit true trac
3.73:1 Gears
Fi-tech 600hp Power adder EFI
Change to a smoother idle cam.
Replace the front windshield.
Change to blue and white paint scheme.
1980 TURBO C10
Old 04-30-2017, 10:49 AM   #3
SLDPULR
SLDPULR's Avatar
Video of idle.
https://youtu.be/-jhMZ86fIG8
Old 05-01-2017, 04:21 PM   #4
Smniekamp
Smniekamp's Avatar
What a find! Looks like a great truck. Nice job on the engine bay clean up.
Smniekamp is offline   Reply With Quote
Old 09-15-2017, 09:36 AM   #5
SLDPULR
SLDPULR's Avatar
Time for an update......
Eaton truetrac installed, 3.73:1 gears installed, Disc brake conversion done, 4" drop on the rear done, 3.5" drop on the front done. 3" x-pipe with Borla mufflers installed. Weld wheels on the front (been waiting on the rear wheels since June.... Weld is slow) Fi Tech 600hp Power adder is going on this weekend. So hopefully she will be screaming down the road soon....
1980 TURBO C10
Old 09-18-2017, 07:06 AM   #6
LT7A
That thing's gonna be squirrelly. Nice truck!
Old 09-18-2017, 09:19 AM   #7
SLDPULR
SLDPULR's Avatar
Its all over the road with the factory tires on the back. I have M/T tires for the back but no wheels to put them on. I've been waiting since June for Weld to build them for me.
1980 TURBO C10
Old 09-18-2017, 10:41 AM   #8
DBLSPRT68
DBLSPRT68's Avatar
VERY NICE!!!! I've always loved the 1980
What rear disc brake kit did you use? Parking brake or no? Do you know what the rotors are from, for replacement?
That 383 is going to be awesome!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 09-18-2017, 11:03 AM   #9
SLDPULR
SLDPULR's Avatar
Caliper brackets are from Speedway, Calipers are D52 from a 1980 c10, Rotors are 1999 AWD Astro rotors, break lines are front lines from a 1980 c10 as well.
Check out this link
http://67-72chevytrucks.com/vboard/s...d.php?t=746646
1980 TURBO C10
Old 03-09-2018, 04:35 PM   #10
66chevy43
66chevy43's Avatar
Looking good, did you get your Weld wheels in the rear?
66chevy43 is offline   Reply With Quote
Old 02-26-2019, 06:19 AM   #11
z71se
Any updates?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 04-10-2019, 01:08 PM   #12
SLDPULR
SLDPULR's Avatar
Well I guess I should do an update on the truck. I have been spending most of my time over on the turbo forum trying to get all the bugs worked out and the truck is pretty much done now.
So I blew the 383 to pieces one day. (long story about FiTech that I wont go into)
Found me a 6.0 LQ4 out of a 2006 Yukon Denali. Yanked out the old 383 and started getting the motor ready for paint.
1980 TURBO C10
Old 04-10-2019, 01:12 PM   #13
SLDPULR
SLDPULR's Avatar
Fast forward a few months and I installed a LJMS stage 2 turbo cam package with push rods and valve spring, Got some up and forward turbo headers and built my hot side and exhaust.
Edit: Sorry for the sideways pictures. Just pick your monitor up and turn it sideways for the full effect.
I will fix the sideways pictures tonight on my laptop. My work computer wont let me turn them to the correct orientation.
1980 TURBO C10
Old 04-10-2019, 01:18 PM   #14
SLDPULR
SLDPULR's Avatar
Next up was the cold side.
1980 TURBO C10
Old 04-10-2019, 01:21 PM   #15
SLDPULR
SLDPULR's Avatar
Next was a holley High Ram, Deka 80lb injectors, Dual 400lph pumps, Holley HP EFI system, 4" down pipe, fender exit exhaust, and other odds and ends.
1980 TURBO C10
Old 04-10-2019, 01:22 PM   #16
darkhorse970
darkhorse970's Avatar
Nice ride, I will follow along.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 04-10-2019, 01:26 PM   #17
SLDPULR
SLDPULR's Avatar
Over the past few weeks everything has really started to come together. I have the truck tuned and driving awesome. I relocated the coils and have started cleaning up the engine bay. I have the truck entered at the C10 Nationals at Texas motor speedway in may so its been a mad dash to clean it all up.
This has all been a learning experience for me and I have had a ton of help from other forums and friends.
If anyone has any questions or wants other pictures let me know and I will post them.
Thanks for following along.
1980 TURBO C10
Old 04-10-2019, 01:34 PM   #18
SLDPULR
SLDPULR's Avatar
Here is a video of the idle.
https://youtu.be/41-6FEIMi4s
1980 TURBO C10
Old 04-10-2019, 01:47 PM   #19
808_67C10
808_67C10's Avatar
dayummmm
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 04-10-2019, 02:35 PM   #20
z71se
Looks good man. Why Holley EFI vs GM PCM and HPT?
Old 04-10-2019, 04:02 PM   #21
SLDPULR
SLDPULR's Avatar
I really liked the user interface of the Holley and the built in digital dash. I have a Megasquirt system on my wife's car and tuner studio was ok.
Ive never messed with HP tuners but I do know they offer a very nice system but I guess the main reason I went with holley was the harness. I think they had the nicest quality harness. Plus all of the built in ICF's are a huge time saver.
1980 TURBO C10
Old 04-27-2019, 05:13 PM   #22
Tsoptich83
Tsoptich83's Avatar
Amazing.
Thomas
Retired Marine, OIF & OEF Vet.
My Project: http://67-72chevytrucks.com/vboard/s...d.php?t=771429
Tsoptich83 is offline   Reply With Quote
Old 04-30-2019, 12:23 AM   #23
PAWS 72
PAWS 72's Avatar
Talk about a full house. That engine compartment is full. Looks nice.
PAWS 72 is offline   Reply With Quote
Old 05-01-2019, 01:29 PM   #24
tremman78
tremman78's Avatar
ill keep an eye out for it at the show!
tremman78 is offline   Reply With Quote
Old 05-01-2019, 02:45 PM   #25
82Diesel
Wow That is a Mint V22 Option 1980 truck! There are LESS & Less around.
1979 Pontiac LeMans 231/Th350
1982 Chevrolet Silverado K10 6.2 Diesel/700r4
1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare)
1991 Chevrolet Silverado K2500 5.7/700r4
1999 Chevrolet Base LS K2500 6.5TD/4L80e
82Diesel is offline   Reply With Quote
