Re: 57 Short Box 235 5sp C4
When i did my Black Diesel 1 piece window mod i evidently got the window channels to far back and the latches would not fit flat like they should have. So i had to drill out the channel to relieve the knobs on the back of the latch.
Passenger door fit good, drivers not so much, outside profile not right.
Door had been damaged at some point in its life, inside wasnt right either
trucks looking great!
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
Build looks great! Really like the suspension! I’m not looking forward to the bodywork/sanding either
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
![]() Join Date: Mar 2009
Did you decide on spring rates for your front coilovers? I've seen that guys have been using 400# springs with the sbc TF trucks. Been researching it for mine, calculator seems to come up 400-450 depending on where I estimate the front unsprung weight will be.
https://www.ridetech.com/info/tech/s...te-calculator/
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
#7 | |
Ok its been awhile since an update, been a busy yr plus all the Covid crap.
Lots of sand, prime, block when time allowed. Finally declared it good enough for driver quality, i suck at body work so it was never going to be show quality but i wanted what ever it turned out to be to be mine. I built a temporary paint booth inside my shop covered in plastic with box fan and furnace filter ventilation. |
Base coat/clearcoat was the plan in pieces
The wood i used is called brown maple, i milled it on my table saw and fit it. I found that wood would not take stain even no matter what i tried, was about to make fire wood out of it or leave it natural color when i read about spraying it with clear coat. Ok what would happen if i mixed the stain with the clear coat? After a couple experiments to get the color clearcoat and hardener i went for it and after 3 coats am pretty happy.
![]() ![]() Join Date: Nov 2008
Interesting color combo. Is it light and dark gray? The lighter color seems to have a touch of green on my monitor. Loving your thread!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
![]() Join Date: Mar 2011
Very nice...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Wow! Driver? Mine must be wrecking yard! LOL
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Dont get to close, it defiantly a 30/30, 30ft or 30mph, LOL
#15 |
I really like the 2 tone paint. Where did you make the cut line on the bed? The fender bead?
#16 |
Yes on the fender bead, about 3.5” below the body line.
#17 |
Can’t wait to see a full side shot of that. Thx.
#18 |
Lots of bolts to put together bed wood, strips and inner and outer fenders, but they are all in.
#19 |
Doing all the fun stuff now. Looking very nice. Steve
#20 |
Looking sweet...Jim
#21 |
Its outside and mobil, needs alignment before any very long runs, carb linkage needs some adjustment, choke stepup keeps kicking in. Sunvisors and inside roof panel sometime. Need more than a trip around the bock now.
#22 |
WOW! Just wow! My favorite truck ever.
#23 |
Very nice, enjoy...Jim
#24 |
Wow, that came together nicely. Great work! I'll be very interested to hear how it rides and drives with the 30-year suspension upgrade.
#25 |
![]() Join Date: Apr 2016
Beautiful truck. Enjoy driving it.
