Old 07-25-2017, 04:01 PM   #1
robertsjm711
robertsjm711's Avatar
'53 3100
Well guess it is time to create a build thread for my '53. I purchased a 1953 3100 last fall and have been wrenching on it ever since. It came with a S10 frame and some 283 engine parts and an old cast powerglide. After some debate and research I decided to go with a 5.3l and a Muncie M20. I tried to get it as low as I could without compromising drivability and sheet metal. It has an older passenger car 12 bolt rear with 2.73 gears that I do intend to change. I took some pictures along the way and will post them in this thread.
I know I have a lot of things to work out and build, but that is the "fun" part. and suggestions, resources or if you see something funky please don't hesitate to mention it. I'm here to learn and maybe help someone else.
Note: sorry about the random up-side-down pics, I haven't found a solution that works yet.
robertsjm711 is offline   Reply With Quote
Old 07-25-2017, 04:25 PM   #2
robertsjm711
Re: '53 3100
Parts and pieces
August 20, 2016
Old 07-25-2017, 04:26 PM   #3
robertsjm711
Re: '53 3100
Cab placement
September 24, 2016
Old 07-25-2017, 04:29 PM   #4
robertsjm711
Re: '53 3100
Junk yard shopping, All American Classics, Vancouver, Wa
October 14, 2016
Old 07-25-2017, 04:31 PM   #5
robertsjm711
Re: '53 3100
Preliminary radiator placement measuring
October 30, 2016
Old 07-25-2017, 04:32 PM   #6
robertsjm711
Re: '53 3100
Preliminary sheet metal placement
October 30, 2016
Old 07-25-2017, 04:33 PM   #7
robertsjm711
Re: '53 3100
Grill cleanup (and surprise layered paint)
January 2, 2017
Old 07-25-2017, 04:35 PM   #8
robertsjm711
Re: '53 3100
Interior and tailgate install
Jan 2, 2017
Old 07-25-2017, 04:37 PM   #9
robertsjm711
Re: '53 3100
Do not use spray foam as a sealer.
March 17-20
Old 07-25-2017, 04:40 PM   #10
robertsjm711
Re: '53 3100
Rims & tires! First time truck was mobile, no engine/trans so it sits a little high
June 5, 2017
Old 07-25-2017, 04:42 PM   #11
robertsjm711
Re: '53 3100
Misc interior & bed/ rear end
June 5, 2017
Old 07-25-2017, 04:43 PM   #12
robertsjm711
Re: '53 3100
2002(?) 5.3l w/ Muncie M20
Old 07-25-2017, 04:46 PM   #13
robertsjm711
Re: '53 3100
Engine placement and with headers
July 16/22, 2017
Old 07-25-2017, 05:21 PM   #14
mongocanfly
mongocanfly's Avatar
Re: '53 3100
nice work
Old 07-25-2017, 08:30 PM   #15
MIKESAD50
Re: '53 3100
Looking good
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 07-25-2017, 11:20 PM   #16
oldman3
oldman3's Avatar
Re: '53 3100
Looks good, I'll tag along...Jim
oldman3 is offline   Reply With Quote
Old 07-26-2017, 02:57 PM   #17
gigamanx
Re: '53 3100
July 16/22, 2017
What headers and engine mounts did you use? Looks like the same engine I'm putting in mine. I have a 5.3L TBI from 1996. Converting it back to carbureted. Sheet metal looks good! Lots of work ahead still
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 07-26-2017, 03:38 PM   #18
robertsjm711
Re: '53 3100
I used some S10 swap headers by Racing Innovation Supply. Not bad for $175 shipped.
http://www.ebay.com/itm/1982-04-Chev...72.m2749.l2649
As for motor mounts I made them. The ones mounted to the frame are common SBC mounts, think I got them from Rockauto. I had originally planned on a 283 so I had bought some S10 swap mounts, but the holes are different on the LS engine. I used them as a template, bought some 3/8 plate steel from my local salvage yard and went to town.
I will mention I have the engine lower than other builds I have seen, I really wanted to reduce or eliminate the hump on the floorboard. I also have the cab mounted pretty low so I had some room to adjust there, too. I do have an issue with my oil pan sitting too low (~3-4" below front cross member) but I plan on changing pans and making a skid plate. I also had to take into consideration the inclination angle and I have it to about 3-5 degrees, should be more to the 3 degrees when I get radiator, coolant, front clip, etc. mounted.
Old 07-26-2017, 10:28 PM   #19
gigamanx
Re: '53 3100
great! Thanks for the info. I happen to be on that part of my build right now
Old 07-30-2017, 09:39 PM   #20
OutlawDrifter
Re: '53 3100
Cool project, dig the 4-speed Muncie.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-24-2017, 08:50 PM   #21
robertsjm711
Re: '53 3100
Worked on some wiring last couple weeks. I am beginning to understand why harnesses are so expensive...
Old 08-24-2017, 08:55 PM   #22
robertsjm711
Re: '53 3100
Radiator mount.
August 2017
Old 08-24-2017, 09:15 PM   #23
NorCalGal
NorCalGal's Avatar
Smile Re: '53 3100
Man you're moving right along. If I moved as fast as you I'd had 4 trucks done by now. looks good I'm in
Jan's 53
NorCalGal is offline   Reply With Quote
Old 08-24-2017, 10:05 PM   #24
gigamanx
Re: '53 3100
That's a novel idea. I like it! Seems like a bit less work than some of the other core support brackets
Old 08-24-2017, 10:08 PM   #25
robertsjm711
Re: '53 3100
Thanks, I work from home and take regular "go work on the truck" breaks.
I want to keep things as simple as possible - less to go wrong and so far it seems less expensive...
