![]() Join Date: Sep 2016
How should I fill firewall holes
Did a little searching and can't seem to find a good answer. I'd like to start filling some of the firewall holes I know I won't need on the cab. I've started marking the ones that can go. What is a good method of getting pieces to fill the holes? For the smaller screw type holes, I tried welding one and just made it bigger by melting the edge of the hole, so that's obviously not the way to do it haha. I don't want to replace the metal with a single sheet since I like the curves and bumps of the original one.
Would love to hear experiences and tips on smoothing things out!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
Re: How should I fill firewall holes
try
https://www.welderseries.com/ on line for some sheet metal plugs for cheap, or shop locally. clean the area well first, then if you grab a cheap stepped drill from harbor freight or whatever you can get a bunch of plugs the same size then drill the cab hole to fit the plug. that way the hole is nice and clean for welding. you can use a copper plate behind so if you have a little burn through it will stay put (weld doesn't stick to the copper). do a series of tacks around the plug, say 2 or 3, then carry on to the next plug because if you weld the whole thing at once you will warp the firewall or wherever you are welding. tack then move on, come back and extend the tack, then move on to allow cooling. soon the plug will be done. you can wipe with a wet rag to help cool and shrink the area so it doesn't warp too bad. |
I just cut out slightly over-sized sheet metal circles, cleaned surfaces/edges, placed on the inside of firewall (helper to hold tight against), and welded from outside. With that thin a gauge, not too much filler required. As I recall, filled around 45 of them.
Cheers, Jim |
#4 | ||
![]() Quote:
https://www.welderseries.com/Unholes-p50202282
if you need a hand to hold the plug, and you have a few extra minutes to spare for fabbing up a quick tool, you can make a magnetic plug holder from a C clamp. just get a cheap steel C clamp and cut the very bottom off, like the bottom of the C part, so you have a vertical portion left there plus the top part of the C with the screw down part still intact. now drill up into the vertical section and run some threads into it. find a round magnet that sticks well and has a hole in the middle and is also smaller in diameter than the distance over to the threaded part of the C clamp. some dollar stores will have everything you need, the clamp and the magnet. the magnets sometimes are sold with a hook on them that is bolted on through a hole in the middle, perfect. toss the hook in the junk bin. bolt the magnet onto the bottom of the C clamp so it will hold the clamp vertical. now you can magnet the clamp onto the back side of the firewall and then screw the threaded part down so it sits level with the sheet metal and holds the plug in place. the clamp comes in handy for other stuff too.
or just use a magnet to hold the plug but then the magnetics will deform the mig welder and cause spatter. of you are torch welding then it won't matter, haha. I think I spend more time making tools than I do working on the truck. dough head alert. |
#6 | |
![]() ![]() Join Date: Nov 2008
Came out good and I had wondered if it would repair decently.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Well, Yesterday I would’ve said to do exactly what dsraven said.. but now I’m wondering if Jim and Dan’s method isn’t the way to go.
I may be picking up a new-to-me ‘51, and noticed it has quite the shotgun scatter of holes. Only thing different I was thinking was to zap a mig wire to it as a handle so I wouldn’t need magnets and cut off C clamps etc. |
this is what I did. 16ga. totally flat now.
the rest of the story. cut it out so it will fit over the envoy donor
the rest of the story. it became a donor for the envoy frame swap. really not that much more work to replace the whole thing though compared to plugging and finishing all the holes. especially if the floor is also rotten. the point is not my swap, it is the work involved to just replace the whole thing. wasn't that much really once I figured out how big to make the recess. need to remember to leave room for the gas pedal though. some guys just do a square recess so that would be easier.
The advice I was given was to find a flat washer that fit the hole, weld it in, and the weld up the small hole in the washer.
Wow! Dsraven that extended cab rig is amazing.
Now I’m off to see if there’s a build thread on that. Awesome truck |
I suppose someone should mention one other alternative:
Aftermarket suppliers use to make a fiberglas sheet that covered the stock firewall and it had a recess in the center too. It simply bolted in behind the hood hinges and the top was shaped exactly to fit under/up against the factory pinch weld. I don't see it offered on the one site I knew used to sell them: No Limit Engineering CORRECTION: Gibbons lists a part number CH523 Smooth Firewall Cover. Maybe it's this part. No pics on their site.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 10-04-2017 at 12:38 AM. |
![]() Join Date: Aug 2012
With all the craftsmanship, i'm a bit embarrassed to say I used various sizes of fender washers.
![]() For the big holes cut out filler out of 18g sheet metal and tack/stitch welded. You can see the results below. http://67-72chevytrucks.com/vboard/s...3&postcount=97 |
#15 |
I cut all mine the same size with a throatless shear and a disc grinder.
#16 |
![]() Join Date: Jan 2016
I went to the local machine shop and they gave me a coffee can full of the drops from there punch press,all different sizes
#17 |
This is only for the small holes up to a half inch but a great trick I learned years ago from a Ron Covell basic metal working VHS tape, yes a VHS tape, that's how long ago we are talking.
![]() What you use is the metal you punch out of a hole using a Roper Whitney punch like this, the XX. ![]() Or this one, but the holes are much smaller, the "jr." ![]() I have to say, if you are doing a fair amount of fab work, these tools are a MUST HAVE. But in this case, you are just punching a hole in a piece of scrap metal. The piece of metal you punch out has a big dent in the middle, the piece is stretched up a little bit. You then take a hole you want to fill and you open it up using a variable bit or step bit until the hole barely fits the piece you punched out of the scrap metal. You put that piece in the hole and then with a dolly on the back you tape the piece with a flat body hammer and the piece gets larger because of the dent sticking up is now pressing into that piece and spreading it. The piece now fills the hole and stays there! A tiny bead around the edge and wham, no more hole. Oh, and that punch, you can get dies to punch square holes and oblong holes and many others, I use them all the time! Awesome tools to have in your box. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#18 | |
So far, various sized washers or just going to the local metal shop for some scraps seems to be the way to go. I like all these genius little tools made from things laying around. I'm new to welding, so my mind doesn't wrap around the idea that I can build all manner of little dohickies for the garage.
#19 |
That's a great idea!
#20 |
for any hole .5'' or under i just welded them closed while holding a piece of brass on the back side
weld won't stick to the brass and the brass acts as a heat sink to prevent weld blow out a piece of flattened copper pipe works well too, it just gets really hot quickly for bigger holes i just welded scrap 16 ga squares, carpet covers them well ![]() i shaved the firewall flange while i was at it
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#21 |
Someone prior owner filled all the holes in my firewall, but I can't figure out how. There appear to be plugs inserted in every hole that fit so perfectly without ever being welded that it literally requires a magnifying glass to see them - primer would no doubt cover them completely. Anyone know how this was done?
#22 |
#23 |
I filled over 65 in mine and almost every one was a factory hole!
#24 |
![]() Join Date: Mar 2014
#25 |
Psh....NO reason to be embarassed. You did the work and if you're pleased with it that's all that matters. Be proud!
