Old 10-14-2017, 12:31 PM   #1
Risky
Risky's Avatar
Whats for me ? Towing advice
Hello guys. I need some advice for towing my car to the drag strip. I'm looking into a square body pickup.
Trailer and car is roughly 5300 pounds or so. Car roughly 3400 lbs.
So I have some simple questions....
How much better will a 3/4 tow over a half ton?
What automatic transmission will hold up to towing my car?
Just how much motor (hp/tq) do i need to tow at 60 mph consistency?
Any real advantages of going with a LS motor over a traditional small block? As in like 5.3 vs 350 vs 6.0 etc
Just how effective is the rear gear ratio when towing?
Did all 3/4 ton square bodies come long wheel base?
Only way I would ever consider a long wheel base if it's a 3/4 ton. I'm not a big fan of a lwb 2 wheel drive.
I know big blocks are nice but I'll like to stay with a small block and stay away from diesels.
Thanks for the help guys.
Risky is offline   Reply With Quote
Old 10-14-2017, 04:48 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Whats for me ? Towing advice
I predict you will get as many opinions as you do responses.
(...maybe more opinions than responses).
Here's mine:
I think it depends on how far and how often you are going to be towing.
If you are going to live on the road, or going (fairly) locally every single weekend then that would be different than going somewhere nearby a half dozen times a year.
I pulled all over the US with this rig for many, many years. Car is around 3600 lbs and trailer is 1000 lbs. Truck is a V6, manual (overdrive) with 3.73 gears. The only time I ever wished I had a bit more motor/gear was launching on a steep hill. Trailer has 4 drum surge brakes from a couple donor '55 Chevy sedans (never had any trouble stopping).
You'll want to understand your state's requirement for trailer brakes (one axle vs two axle). I would also recommend electric trailer brakes if you can manage it.
Since the truck was primarily my daily driver then I gravitated toward "smaller" in terms of tow vehicle. If the vehicle was going to be used for towing only then I would gravitate bigger, or when I started going long distances every month I bumped up to an enclosed trailer and 2500HD pickup.
The other end of the spectrum would be the guy that buys a crew cab dually to pull a pop-up camper twice a year. When I was at the GM Milford Proving Ground my officemate was the fleet coordinator for Truck Engineering. We would occasionally field questions about that kind of scenario, and would try to persuade the buyer to lower his sights a bit.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-14-2017, 05:01 PM   #3
Keith Seymore
Sidebar: I just realized that trailer is 50 years old.
Dad and I built that trailer to haul the GTO back in 1967. He laid out some chalk lines on the garage floor and welded it up. Cost us $50 for the steel as I recall.
I still have it and used it as recently as yesterday. It's hauled doll houses, playscapes, go carts, Model A Fords, cars worth more than my house and (remnants of) cars not worth the dirt in their frame rails.
K
1979-1986
1986 - 2019
Old 10-14-2017, 06:02 PM   #4
Risky
Risky's Avatar
Thanks for a response.
I will be towing once a year to bowling green which is 5 hours away. Then to Memphis which is a hour away.
I can't afford a brand new truck from the dealership. They just cost too much money. I rather invest it into my car. So a square body will have to do the trick for me. I want to own a truck that I can depend on because there's nothing like begging and asking people to come get you from the track.
What motor you running Keith since at times you wish you had more on the hills?
Would it help alot towing wise if I put disc brakes on each corner?
Old 10-15-2017, 10:37 AM   #5
abig84
abig84's Avatar
a half ton should probably be ok if youre doing it once a year. i tow my offroad truck and trailer with a 1990 half ton (about 5000lbs). 3.43 gears, 305 and 225,000 miles. tows just fine just a little slow getting up to 60mph on the highway.
not sure if the square bodies would be the same way but my biggest issue with my half ton was the soft springs in the back. had to buy a set of helper air bags due to the truck almost bottoming out in the back if i hit a big dip in the highway. other then that really no complaints as i dont tow too often
abig84 is offline   Reply With Quote
Old 10-15-2017, 11:44 AM   #6
mongocanfly
mongocanfly's Avatar
a 1/2t should do all you need..you may want to ad some helper springs or airbag levelers...as Keith said make sure you use trailer brakes...
as for engine choice ill say you won't regret a LS swap...but its all in what you want..
I pulled my racecar all over with a 86 with a 305 sm465 and 2.73s..I'm out of racing now but regularly pull a tractor all over..
I pulled a 7k loaded trailer with my 99 z71 5.3 3.73s...pulled it just fine..I upgraded tractors and now my loaded trailer tops out at 9500lb..I now have a 81 c30...the 350 and sm465 were pitiful. ..I dove head first into a LS swap..dropped in a lq9 nv4500 with 4.10s..all I can say is wow...no regrets...
Old 10-15-2017, 11:55 AM   #7
Risky
Risky's Avatar
Do you have a picture of your C30? Is that the 3/4 ton. I would love to see a pic of the truck.
Old 10-15-2017, 12:11 PM   #8
mongocanfly
c30 is a 1ton....c20 is 3/4ton....c10 is half ton
Old 10-15-2017, 12:20 PM   #9
Risky
Risky's Avatar
Some reason your pic didn't load. Shoot me a pic.... 6623171968. I really want to see your trucks.
Old 10-15-2017, 12:21 PM   #10
Risky
Risky's Avatar
Sweet dually!! What's in the 3/4 ton ?
Old 10-15-2017, 12:26 PM   #11
mongocanfly
its a 1ton...had 20200 miles on it when I got it...came from a local fire dept...
for some reason I'm having trouble loading pics...
I don't have a 3/4 ton running...its sitting out back with no engine..
Old 10-15-2017, 12:45 PM   #12
mongocanfly
underhood...
Old 10-15-2017, 01:04 PM   #13
csdineley
csdineley's Avatar
I agree if your only towing a couple times a year a 1/2 ton will do you just fine.
How much better will a 3/4 tow over a half ton? A 3/4 ton will ride better and squat less while towing. Unloaded they can be a little rough.
What automatic transmission will hold up to towing my car? Short answer any but a th400 would be recommend
Did all 3/4 ton square bodies come long wheel base? Yes
As for engines a lot of people are going to recommend an LS engine. For my 3/4 ton 2wd I went with a crate vortec 350 from the 96-99 trucks. With a sm465 and 3.42 gears it tows my 6k pound camper great. Even in the mountains. Even better then my 92 suburban 2500 with a 454.
Trailer brakes are a must. As for 4 wheel disc brakes, sounds nice but the stock 3/4 ton disc and drums work great so I don't see a reason to mess with them.
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's
csdineley is offline   Reply With Quote
Old 10-15-2017, 01:08 PM   #14
Risky
Risky's Avatar
Thanks for the info. Very very helpful. I'm taking notes.
Old 10-15-2017, 01:09 PM   #15
Risky
Risky's Avatar
Originally Posted by mongocanfly View Post
underhood...
What a beautiful motor you have there!!
Old 10-15-2017, 01:18 PM   #16
Dead Parrot
For your occasional usage, a stock 350/TH350 combo into a 3.73 rear end should be fine. Since stopping your rig while going down the steep hill is also important, find a truck with the heavy duty brakes(J7?) vs the lighter duty(J5?). Maybe someone will chime in the the RPO codes for the SPID sticker.
Probably want one with the 7 leaf + overload rear springs.
You will want to check the GVWR and the tow rating before purchasing. There were a lot of different setups sold to meet cost points and in some cases, to avoid the need for certain emissions equipment. Not all C10s are equal.
Dead Parrot is offline   Reply With Quote
Old 10-15-2017, 01:21 PM   #17
csdineley
csdineley's Avatar
Rpo codes would be jb5 and jb7
Old 10-15-2017, 01:27 PM   #18
Risky
Risky's Avatar
Thanks for posting that. However I'm on the hunt for a solid roller. 3/4 tons keep cathchin my eyes.
Old 10-15-2017, 01:59 PM   #19
csdineley
csdineley's Avatar
They apply for 3/4 ton as well. There was also a light duty and heavy duty 3/4 tons rpo c6p.
Old 10-15-2017, 02:15 PM   #20
Risky
Risky's Avatar
Thanks. I'll write this info down.
On the other hand Hot Rod Magazine took a 6.0 and added bolt one.
Simple and easy. 408hp and 440 tq at the crank was produced with headers, mufflers and a tune.
Old 10-15-2017, 02:33 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
I didnt see you say what trailer your using. If its a flat bed, you fine. If its enclosed your going to want as much truck as you can afford due to wind resistance.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-15-2017, 03:45 PM   #22
Risky
Risky's Avatar
Open 18 ft trailer...
Old 10-15-2017, 10:52 PM   #23
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
A 1/2 ton would do the job, I would lean towards a long bed for the wheelbase advantage. (I do tow with my 84 SWB, but it isn’t for everyone).
However, 3/4 tons can be often had cheaper (for square bodies), so I would go with a C20 to get the larger brakes, axle, etc. for less money.
An auto will hold up fine, just put a good cooler on it and drive realistically (not 80mph uphill). A trans temp gauge can also help ensure you don’t do any damage. If you get a 3/4 ton it should have the TH400, which won’t mind towing all day every day.
A stock 350 will tow at 60 all day as well. No need to go crazy, but an LS swap is always nice but not necessary. People have been towing for 50 years with small block chevys and they hold up fine. Not a modern 1000lb*ft diesel, but fine within expectations.
A deeper (higher numberically) rear axle helps in towing. I would recommend 3.73s for your purposes, as you’re not towing a ton of weight, but it’ll help off the line and still keep the rpms reasonable at highway speeds.
All 3/4 ton squares are long wheel base, and the wheelbase helps when towing. If you’re not a C20 LWB fan, K20s can still be had for a reasonable price.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 10-15-2017, 11:13 PM   #24
Risky
Risky's Avatar
Thanks. I'm really digging the look of a 3/4 ton 4 wheel drive. A decent pair of 6x9 speakers behind the seat would do the trick for me cruising at 60 mph with ease.
Old 10-15-2017, 11:19 PM   #25
Risky
Risky's Avatar
