Old 01-05-2018, 04:44 PM   #1
RedRider
RedRider's Avatar
Measuring for a new driveshaft - does this make sense?
Just finished a lwb to swb conversion and I'm looking to replace my two piece driveshaft with a one piece. I need a measurement for the driveline shop.
A couple questions for the drive shaft pros here:
To get the best measurement, I was hoping to measure from u-joint to u-joint. I pulled the slip yolk off the old shaft and pressed it all the way into the transmission. Then I slid a rigid piece of cardboard through the middle of front yolk:
Moving back to the rear, I made a measurement from the base where the u-joint rides (bottom of the laser measure):
Three measurements from three spots on the cardboard were all the same; about 60 inches:
Does this approach makes sense? Is there a better way to measure what I need?
Second question, how does this measurement compare to those running a 1-piece drive shaft? This is a 1970 C-10 w/ a 350 and 350 tranny. Also, what diameter shaft should I expect?
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 01-05-2018, 05:01 PM   #2
geezer#99
geezer#99's Avatar
Re: Measuring for a new driveshaft - does this make sense?
You need to pull the slip yoke out of the tranny about 1 inch and then measure from Center to Center on the u-joints.
You should also have your pinion angle set correctly to get an accurate measurement.
Old 01-05-2018, 05:43 PM   #3
WB72
Before and After
WB72's Avatar
agreed with the 1" slip yolk measurement. my driveshaft place told me 3/4", but what is 1/4" between friends?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-05-2018, 05:57 PM   #4
bs46488
My shop said pull the yoke out 3/4"
If I remember correctly it was around 58 3/4", but I have a TH400 trans in mine.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 01-05-2018, 11:06 PM   #5
Rufas
Rufas's Avatar
Just ask the shop that is going to shorten your driveshaft and use their directions. Don't try to second guess.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 01-05-2018, 11:42 PM   #6
boynton
boynton's Avatar
2nd
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 01-06-2018, 12:33 AM   #7
NoNeck
NoNeck's Avatar
3/4" works well. Make sure the measurements are taken at ride height.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 01-06-2018, 11:41 AM   #8
Jrainman
Jrainman's Avatar
Agree ask your drive line shop they all have there own beliefs, my shop uses 5/8 as play , And remember as No neck stated Take mesurement at ride height , My drive line shop tells me this is the Number one mistake made , you can not take your mesurement with the truck on jack stands it MUST BE ON THE GROUND . and the 60'' sounds to long , TH 350 and th 400 and 200 4 r trans from my experience were all under 60 inches.
Jrainman is offline   Reply With Quote
Old 01-06-2018, 01:58 PM   #9
RedRider
RedRider's Avatar
How about ride weight? Should I wait until the bed is on before I take measurements?
Old 01-06-2018, 02:05 PM   #10
RedRider
RedRider's Avatar
Old 01-06-2018, 03:47 PM   #11
geezer#99
geezer#99's Avatar
Yes. Or add the same amount of weight over the axle. Barbell weights work good.
Old 01-06-2018, 04:09 PM   #12
spoon3210
I pulled my yoke out 3/4 measured from center of u joint to center of u joint and went to the wrecking yard. They usually have a huge pile of drive shafts. I found one in excellent condition. I painted it and put new u joints in it and for 80 bucks I was back in business. There is a u joint that uses early model chevy caps and later model chevy caps so everything fits perfectly. The newer caps are a little bigger.
spoon3210 is offline   Reply With Quote
Old 01-06-2018, 07:11 PM   #13
Lee H
Lee H's Avatar
Most drive line shops have a tutorial on how to measure with a downloadable form to put all the measurements on.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-06-2018, 08:12 PM   #14
Keith Seymore
Keith Seymore's Avatar
This.
I was a driveline development engineer for GM Truck, and my shop still sent me back to do the measurements "their way".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-06-2018, 09:08 PM   #15
70STOVEBOLT
70STOVEBOLT's Avatar
59.5 for my 70 C/10 with 402/TH400
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-08-2018, 02:40 PM   #16
Kuzican
Kuzican's Avatar
https://www.southwestspeed.com/?sec=...hafts&ssub=!!2 1/2" Steel Driveshafts
Kuzican is offline   Reply With Quote
Old 01-08-2018, 03:37 PM   #17
RedRider
RedRider's Avatar
Originally Posted by Kuzican View Post
Cool! That's a lot cheaper than the $350 I was quoted. It seems like I'm doing all the technical work and carrying all the liability for a wrong measurement, so why not get one off the internet?
Old 01-08-2018, 06:13 PM   #18
bs46488
I bought my driveshaft from Tatton's in Utah off the internet.
Great customer service, fast turnaround and I think I paid around $250 for it to be shipped to my door.
Old 02-01-2018, 04:09 PM   #19
RedRider
RedRider's Avatar
Had an interesting discussion with Southwest Speed trying to order my driveshaft. Nice guys but communication was sort of a challenge. Nevertheless, I gave them a rear pinion flange to transmission seal measurement (62") and they're sending me at 3" diameter, 59" driveshaft.
So if I was measuring 60" u-joint to u-joint and they're accounting for 1" of slip, then 59" should be correct right???
Old 02-01-2018, 04:29 PM   #20
Kuzican
Kuzican's Avatar
That's how I measured to, don't remember the numbers, didn't even ask them what size they were sending me, guess I trust people to much, it fit perfect.
Old 02-01-2018, 05:11 PM   #21
RedRider
RedRider's Avatar
That’s reassuring, fingers crossed.
Old 02-01-2018, 07:03 PM   #22
fotyfobravo
fotyfobravo's Avatar
My 70 GMC short bed had the 2 piece with a bearing at the joint. I replaced with a well balanced one piece and it made a huge difference. Much smoother.
fotyfobravo is offline   Reply With Quote
Old 02-03-2018, 09:58 AM   #23
truckdude239
truckdude239's Avatar
When i had mine cut down i was told from the hard part of the seal to the center of the ujoint
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-05-2018, 10:46 AM   #24
Sleipnir
Guys I have a question about the Southwest speed drive shafts. Could I buy two of them to make a two piece drive shaft? The size I would need for a one piece is about 69 inches long and they dont make one that long.
67 C10 "Big Red"
Sleipnir is offline   Reply With Quote
Old 02-05-2018, 12:43 PM   #25
RedRider
RedRider's Avatar
They can build whatever you want but they're only responsible for the build, not the application.
