01-11-2018, 11:03 AM | #1 |
K5 Shock choice
my 72 has a 3/4 ton 4" spring lift (Skyjacker) and I think it's time for new shocks. I'm partial to KYB's, but I'm not against anything. Cheaper is nice, but better is, well, better. What part #'s should I be looking for? Thanks in advance for any input.
'72 K5, known as 'the Fox.' |
01-11-2018, 11:13 AM | #2 |
Re: K5 Shock choice
Could always order a set of FOX 2.0s off of BDS website. Spendy but id be willing to bet they are the best out there. If not those id run Bilsteins. im sure with some quick searching you can find the part numbers that will fit your application
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
01-11-2018, 11:30 AM | #3 |
Re: K5 Shock choice
X2 on the Bilsteins.
-Bruce 1971 K5 Blazer 4WD |
01-11-2018, 11:46 AM | #4 |
Re: K5 Shock choice
you would think so but most of my searching pulled up dropped trucks. A 4" lift seem fairly common, and I was hoping folks would chime in with what they used.
01-11-2018, 12:14 PM | #5 |
Re: K5 Shock choice
I'm interested myself. I'd say fox or bilsteins 5100 series since it seems to be the choice people reply with. My eye is on this thread..
01-11-2018, 12:15 PM | #6 |
Re: K5 Shock choice
WHICH Bilstein 5100? Yes, they do seem to be the most preferred...
01-11-2018, 12:45 PM | #7 |
Re: K5 Shock choice
That's what I would like to find out. I see them in pics and recommendations but no one seems to either remember part numbers or where they got them.
01-11-2018, 02:54 PM | #8 |
Re: K5 Shock choice
I have a 4" lift with a 1" Off road design add a leaf.
I have Bilsteins on my rolling chassis. I will take pics of the part numbers tonight. You can also look at offroad design's website, they lay out the shock sizing. You will be looking for a 5125 series shock for all 4 corners and a 5100 series shock for the stabalizer if you choose to replace that as well. I found a pic of my stabalizer part number. The 5125 serise shock will require you to measure your length from frame mount to axle mount. You buy them based upon travel length. I think the ORD website tells you what you should have for travel. Hope this helps. I paid mid $70 range per shock from Amazon.
Full top blazer or bust.... |
01-11-2018, 03:45 PM | #9 |
Re: K5 Shock choice
all four corners are the same?
that part #, 33-170794, is the stabilizer. ...patiently waiting on your pix tonite...
'72 K5, known as 'the Fox.' Last edited by mister.freeze; 01-11-2018 at 04:09 PM. |
01-11-2018, 04:58 PM | #10 | |
Re: K5 Shock choice
I should be home around 7 or so. Sorry, late night.
01-11-2018, 05:05 PM | #11 |
Re: K5 Shock choice
You can make out the front numbers, but I need to get you a better pic of the rear shock. That is all I have on my phone.
Talk at you soon.
01-11-2018, 11:18 PM | #12 |
Re: K5 Shock choice
Rear shock is the top picture. 33-104652...
Front shock is the lower picture with the Weiand box in the background. 33-186542 Just Google search the part number and the shocks should come up. I found them easily on Summit & Amazon. These fellas have a nice website for sizing as well. http://offroaddesign.com/catalog.htm Also note, you can mount these shocks normal or upside down. I decided to mount upside down since I liked the look better. Let me know what you end up doing. - Post pics!
Full top blazer or bust.... Last edited by Spf79; 01-11-2018 at 11:31 PM. |
01-12-2018, 08:13 AM | #13 |
Re: K5 Shock choice
Yes! Good info. Thanks!
01-12-2018, 09:51 AM | #14 |
Re: K5 Shock choice
Upside down? But the printing is right-side-up!
Upside down means less reciprocating mass, faster response. Right-side-up means lower center of gravity. Not a big difference on these trucks, but there's the info if anybody cares.
01-12-2018, 05:27 PM | #15 |
Re: K5 Shock choice
More specifically...
http://offroaddesign.com/catalog/Bilstein%205125.htm
01-19-2018, 12:39 PM | #16 |
Re: K5 Shock choice
If you go onto bilsteins website they show https://us.bilstein.com/en/product-s...70794323576229 to be the shock for the front of these trucks with a 3"-4" lift.. Is there a difference in the 5100 to the 5125, does anyone know?
01-19-2018, 06:03 PM | #17 | |
Re: K5 Shock choice
This was the best answer I could find. Since I have the extra inch in lift, I had to work with 5125's since they come in variable lengths for lifts above 4". I hope this helps.
01-22-2018, 10:22 PM | #18 |
Re: K5 Shock choice
Hey Spf79, that sway bar on your blazer looks great! Is it a 73-87 blazer bar? Did you just use the spring plates from the square body blazer? Can you show me how you mounted it to the crossmember? Also, did you do a rear sway bar as well? Thank you
01-22-2018, 11:40 PM | #19 | |
Re: K5 Shock choice
The bar is a 73+ bar, the PO installed it with the front cross member out of a 73+ truck as well. The spring plates are 73 as far as I can tell. The crossmember bolts right in, I shimmed it with some thick washers so that it fit tight where the old crossmember was at. The rear is an addco swaybar. I can't remember the part number. It was listed as fitting a 2wd or 4wd truck. With a lift you have make mounts that fit on the rear axle plates that raise the sway bar up so that it is level... otherwise it binds when the axle springs compress. Oh, and if you have the original rear spring square U-bolt set up you will have to change that to a round U-bolt and top plate.
01-23-2018, 01:59 AM | #20 |
Re: K5 Shock choice
Great info, thank you!!
01-23-2018, 11:29 AM | #21 |
Vintage Evil
Re: K5 Shock choice
I would say Fox 2.0 or Bilsteins ... I have the 2.0s on my 3/4 diesel and they were a nice ride improvement... i also have them on by 72 c10... but no ride time with those yet... Lots of guys swear by the bilsteins too... so also a good option
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
03-02-2018, 04:43 PM | #22 |
Re: K5 Shock choice
for my 72 with 4" lift:
Fronts- Rancho RS55001, RS7112, RS999001 ($50, $80, $90) Bilstein 33-186542, 24-187077 ($70, $80) Rear- Rancho RS55112, RS7402, RS999112 ($50, $80, $90) Bilstein 33-104652, 24-187084 ($70, $80)
03-02-2018, 09:58 PM | #23 |
Re: K5 Shock choice
ProComp 16715’s (321502) for the front, 16712 (322500) in the rear are on there now.
'72 K5, known as 'the Fox.' Last edited by mister.freeze; 03-03-2018 at 06:08 PM. |
03-03-2018, 05:48 PM | #24 |
Re: K5 Shock choice
which bilstein model numbers for a 72 with no lift?
03-30-2018, 11:50 PM | #25 | |
Re: K5 Shock choice
Tags |
4x4, lift, shocks |
