Old 03-04-2018, 09:05 PM   #1
Curtb1971
Curtb1971's Avatar
Restored 67 gauge cluster and glove box set
Up for grabs is a restored 1967 only 7-hole cluster and glove box door package. Gauging if the is a interest for others as well on these. Here's the details of the work done using all oem parts
Cluster
-Tin's bead blasted and painted
-Gauges cleaned and needles painted
-Lens polished
-Gauges and lights tested for proper function
-67' only bezel restored and painted to OEM colors
-Speedo set to 6.7 miles
-oem hardware acid cleaned, painted and new stainless hardware for circuit board.
Glove box door
-Professionally dip stripped to bare metal, sealed, primed and painted to match the gauge cluster
-oem hardware acid cleaned and painted
-Latch polished to shine and greased
-Hinge and 67' only stop bead blasted and painted (also have 68+ stops with the rubber bumper if wanted)
$500 shipped/insured conus
Also can build this cluster with an oem V8 tach for an additional $200
Let me know any questions
Thanks, Curt
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 03-04-2018, 09:13 PM   #2
Curtb1971
Curtb1971's Avatar
Re: Restored 67 gauge cluster and glove box set
Cluster pics
Old 03-04-2018, 09:19 PM   #3
Curtb1971
Curtb1971's Avatar
Glove box door pic
Old 03-04-2018, 09:41 PM   #4
nds1968
nds1968's Avatar
Very nice, I'll have to keep you in mind...
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 03-04-2018, 10:02 PM   #5
countr
countr's Avatar
Curt, that is sweet!!!!! I can not wait to see the one you did for my 67 4x4!
Russ
countr is offline   Reply With Quote
Old 03-04-2018, 10:10 PM   #6
Curtb1971
Curtb1971's Avatar
Thanks man
Russ
Thanks Russ, got yours and a glove box door tucked away in your stash!
Old 03-04-2018, 10:32 PM   #7
jocko
jocko's Avatar
Good luck on your sale - that is a beautiful combo that you don't see restored very often.
Old 03-04-2018, 10:33 PM   #8
Njeiv
“On The Hunt”
Njeiv's Avatar
I’ll take it
Njeiv is offline   Reply With Quote
Old 03-04-2018, 10:55 PM   #9
Curtb1971
Curtb1971's Avatar
Originally Posted by Njeiv View Post
I’ll take it
PM with payment info sent for the setup with an oem V8 tach and 80lbs oil gauge. I'll post up some pics when I get it done this week. Thanks, Curt
Old 03-04-2018, 11:03 PM   #10
Curtb1971
Curtb1971's Avatar
Thanks Jocko I figured I'd better do glove box doors to match the clusters I've been restoring for the 67 guys.
Old 03-05-2018, 08:10 AM   #11
dec010974
dec010974's Avatar
Is this a weld on part or can this unit be bolted on? I Didn't know that dash, glove box cap comes off. I may be Interested in one of these later on in my build.
dec010974 is offline   Reply With Quote
Old 03-05-2018, 08:53 AM   #12
Curtb1971
Curtb1971's Avatar
If your talking about the dash assembly (yellow part) then this part is spot welded at the lower half of the windshield and also bolted at the A pillars. I used this just to take pictures for the gauge cluster and glove box door but never intended it to be part of the sale. All the other components are bolt on. Hope that answered your question
Old 03-05-2018, 10:02 PM   #13
Rods
Rods's Avatar
Hey Curt do you have anymore of these available ?
Rods is offline   Reply With Quote
Old 03-06-2018, 08:20 AM   #14
35boulder
35boulder's Avatar
Nice looking combo. Nice work.
35boulder is offline   Reply With Quote
Old 03-06-2018, 11:02 AM   #15
Curtb1971
Curtb1971's Avatar
Rod, I have a (2) extra glove box doors completed with the run I did and an assortment of 3 & 7 hole 67 bezels that need completed to make a cluster set. Can build pretty much any variation of a cluster
Thanks man, these are a blast fixing up
Old 03-06-2018, 11:21 AM   #16
projectking
projectking's Avatar
How much to restore if I sent you the cluster and door? I want to retain the original SPID.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 03-06-2018, 11:39 AM   #17
Curtb1971
Curtb1971's Avatar
You know this question has come up before and it would be risky for the both of us as in the shipping process. I wouldn't want your original spid being lost in the mail going to or from. Clusters and parts are replaceable but OE spids arent. It's do able as far as the work but there is that risk involved. I've done a couple of these where guys just retain their original door and use the ones I provided in their truck.
Old 03-06-2018, 06:23 PM   #18
Rods
Rods's Avatar
Curt I’m in for two 7 hole with tach and the glove box doors.....
Old 03-07-2018, 01:13 AM   #19
Curtb1971
Curtb1971's Avatar
I'm completing the one for Njeiv soon then I'll start working on other bezels I have and will keep you posted. Pm sent Thanks, Curt
Old 03-07-2018, 04:27 PM   #20
projectking
Pm sent
67 Chevy C10 LWB
90 Mustang Gt
Old 03-18-2018, 10:18 PM   #21
Curtb1971
Curtb1971's Avatar
Ok Njeiv, got the 4x4 stickers for your door and placed in the original location thanks to member countr for sending me his original glove box door 67' tach cluster with 80lbs oil gauge is completed. I'll test/calibrate the tach tomorrow then it will be headed your way. Thanks, Curt
Old 03-19-2018, 04:30 AM   #22
Njeiv
“On The Hunt”
Njeiv's Avatar
Lookin great! Thanks for the update, can hardly wait to receive it.
Old 04-11-2018, 10:57 AM   #23
philB
the tach to use with HEI dist. is differant or can that be added to 7 gauge cluster.
philB is offline   Reply With Quote
Old 04-11-2018, 09:10 PM   #24
Curtb1971
Curtb1971's Avatar
You can use a oem tachometer running a HEI distributor or the original ignition coil. The only difference is the connectors on the tach harness. A tach cluster is a whole different animal vs a regular gauge setup because the tins, lens and circuit board a different, plus the tach. Hope that answered your question
Old 04-11-2018, 10:23 PM   #25
arcticman
arcticman's Avatar
I would be interested in a set for my 67 GMC k1500 I have a good glove box door all my gauges work but PO overtightened the screws on the bezel. can you repair that? no missing pieces just cracked.
PROJECTKING asked how much if parts were sent ?
I have a GMC and they did not use SPID label in 1967 so that's not an issue.
they look nice.
what is your turn around time not inc. shipping?
Thanks,
arcticman is offline   Reply With Quote
