07-20-2018, 11:09 AM | #1 |
Post Your Wheel and Tire Combo
I have been looking around this forum for a while and there are so many great trucks, with so many different wheel are tire combos, so I thought it would be nice to have a thread to contain it all.
Can you please provide a picture of your truck, what wheel/tire combo you are running, and a brief overview of ride height and/or suspension set up. I figure this could give a lot of us new builders an idea of what we are looking for. |
07-20-2018, 03:26 PM | #2 |
Re: Post Your Wheel and Tire Combo
I guess I'll be first.
16X7 TT2's with 4" backspace, 215/60/16 tires with MII front suspension, 2" drop spindles with coil overs, disc brakes, have 4-1/2" ground clearance at front crossmember. 17X8 TT2's with 3-1/2" backspace, 235/55/17 tires with Nova rear axle on leaf springs. Here's a pic...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-20-2018, 05:21 PM | #3 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
07-20-2018, 05:21 PM | #4 |
Went with smoothies. 16x8 235/60-16 all around. Mustang II IFS and stock in the rear.
07-20-2018, 05:22 PM | #5 | |
Brian
07-20-2018, 07:35 PM | #6 |
Nice classic look!
Romans 10:9 - The Truth |
07-20-2018, 11:19 PM | #7 |
Brian, thanks for the compliment. My rear springs are the stock rear springs from my 1994 S-10 blazer. I put 3" lower springs on my blazer and used the old springs on my truck. Since these are wider that the stock truck springs, I had to change the front and rear hangers. Truck rides nice. I know there are several vendor that sell complete kit to change to the wider springs, which require you to cut the old rivets from hanges and bolt in the new hangers. Oh, and I'm running a 2" lowering block...Jim
07-21-2018, 12:10 PM | #8 | |
Brian
07-21-2018, 02:45 PM | #9 |
07-21-2018, 09:43 PM | #10 |
I have recently changed out the wheels and tires on mine.
Fronts are 215/70-15's 4.25" backspacing Rears are 255/60/15's 4.25" backspacing all suspension is 2nd gen Camaro, 10" diff. Front suspension I put on 2" lowering spindles, rear has 4 leafs/side with 1" lowering blocks. Also running a Gen VI big block for power. A Big block vs a small block will affect your stance.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 07-24-2018 at 10:15 PM. |
07-22-2018, 05:11 PM | #11 |
What are these "wheels" you speak of? Are they something like rims?
Signed, Every Car Enthusiast In The World Under 40 Years Old Last edited by Jesse Z; 07-22-2018 at 05:27 PM. |
07-22-2018, 05:23 PM | #12 |
I stuck with a 15" tire and wheel combo: 205-70 on 7's front, 225-70 on 8's rear. Why? Because simplicity, practicality and economy are the goal of this build. As soon as you jump up to the performance tire and wheel sizes the cost increases exponentially. Yeah, it might look more trendy with "conestoga" wheels, but the cost just ain't worth it, and I'm not into wowing a bunch of Millennials.
Simple, cheap, readily available:
1951 Chevy Panel Truck |
07-22-2018, 05:26 PM | #13 |
195-60 14 on 7 inch rims on the front 255 -60 15 on 15x8 rims on the back. That is the setup I ran for years. wheels are Enkie 32. Pretty well obsolete now.
This go around it is getting 225 15 white walls on 7 inch wheels with hubcaps. Whole different look getting away from the street rod look.
07-23-2018, 08:11 AM | #14 |
Thank you all for the posts so far, some great info here.
07-23-2018, 04:22 PM | #15 |
Here's my truck just as it came out of the paint booth at my son's shop. Some assembly required obviously, but shows the stance. It has a Scott's front suspension and TCI rear leaf spring lowering kit. Tires are 235/75/15 on eight inch Corvette rally wheels. This tire and wheel combo is probably a little to old fashioned for some but I like it.
07-23-2018, 06:16 PM | #16 |
I think it's awesome Russell, all I can add is to DRIVE IT! Drive the frigging wheels of it with a smile on your face.
Brian
07-23-2018, 06:29 PM | #17 | |
07-23-2018, 06:56 PM | #18 |
16 x 8 with 5" backspacing/+13mm offset (https://www.summitracing.com/parts/brw-997683450)
S10 frame, stock spindles with 2.5" spacers in front Homemade body mounts Mid 60's 12 bolt passenger rear stock width Venezia Crusade SXT 225/60 R16 https://www.youtube.com/watch?v=61BLek1f5Fk
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
07-23-2018, 08:47 PM | #19 |
These are what came on it when I traded for it.
Fronts: 215 60R14 Cooper Cobra's on Crager's Rears: 225 70R14 Cooper Cobra's on Crager's Thinking on swapping the fronts for taller 225 70R14's to improve the ride. |
07-24-2018, 07:09 AM | #20 | |
07-24-2018, 01:44 PM | #21 |
The day we brought it home (1 year ago) |
07-24-2018, 10:16 PM | #22 |
wheels or rims are the same thing
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
07-26-2018, 01:56 AM | #23 |
07-26-2018, 10:18 AM | #24 | |
Maybe just post your wheel/ tire combo or move on. I'm 40 so I guess I can call them wheels. Here's mine: Wheels: 20x8.5 Tires: 245/35/20 Front suspension: Mustang II w/ QA1 coilovers Rear Suspension: Trailing arms with QA1 coilovers and Ford 8.8 axle
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
07-26-2018, 09:58 PM | #25 |
235/70R15 on 15x7's
