Old 10-13-2018, 09:32 AM   #1
MattG
Junior Member
MattG's Avatar
Relocating coolant overflow
Looking for ideas and pics of coolant overflow tanks located inside the engine bay. Right now mine is between the radiator core support and grill. I just completed installation of a new aluminum radiator and would like to install the filler plates between the grill and core support. Not sure a good location for the overflow tank. Plenty of folks on this forum with good ideas so hoping for a brilliant resolution.
Matt
_____________
1967 C20
283 CID
MattG is offline   Reply With Quote
Old 10-13-2018, 12:23 PM   #2
sick472
sick472's Avatar
Re: Relocating coolant overflow
I bought these for a build and they work very nice. I got one for the radiator over flow and one for the windshield washer fluid...
https://www.speedwaymotors.com/Speed...Tank,7302.html
I did not get them from speedway, ebay I think, but you get the idea. One of these might open up some other possibilities. They come in alot of sizes.
I love the look of your engine bay btw!
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 10-13-2018, 12:34 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Relocating coolant overflow
I'm with you man. I have mine in the same spot and want to use the core filler also. I thought about cutting a hole in the cover to reach it. Just haven't done it yet.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-13-2018, 12:54 PM   #4
MattG
Junior Member
MattG's Avatar
Thanks it passes the 20ft test! I have seen those styles in the various catalogs. May be an option
Matt
_____________
1967 C20
283 CID
Old 10-13-2018, 12:55 PM   #5
MattG
Junior Member
MattG's Avatar
Had the same idea about cutting a hole, just not thrilled about cutting up th filler panels, especially if my hole ends up off a bit
Matt
_____________
1967 C20
283 CID
Old 10-13-2018, 01:17 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have a cheap aftermarket tank mounted on the back side of the core support above the horns. It's been there since before I bought the truck 41 years ago. There's a clear plastic line from the radiator cap nipple, under the shroud (one clip at the bottom center of the shroud), and up to the nipple on the bottom of the tank. Doesn't look like much but it's been working nicely for decades.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-13-2018, 01:20 PM   #7
Overdriven
If you’re concerned about the hole lining up here’s a tip, drill the hole first, mount the tank in the correct position relative to the hole. You can mount the panel, put a piece of clay on the cap of the reservoir and push it into the panel from below. The clay will leave a smudge and you’ll know where to drill the hole. Drill the hole, mount the reservoir so the cap is centered in the hole.
Me personally, I don’t mind having a tank hanging out in the engine bay as long as it isn’t plastic. So I’m eventually going to use something like the 68-72 corvette expansion tanks mounted on the fender behind the battery. I’m sure there’s a cheaper alternative out there though.
https://www.speedwaymotors.com/DeWit...te,357037.html
Overdriven is offline   Reply With Quote
Old 10-13-2018, 02:04 PM   #8
HO455
HO455's Avatar
I used a s10 tank and made a bracket to hang it off the battery tray. (More information on page 7 of the WMB thread below). However after I did mine I found out about using a G-body tank which needs no bracket. See 2nd photo.
RIP Bob Parks.
Old 10-13-2018, 02:24 PM   #9
weq92f
weq92f's Avatar
Those tall skinny tanks work well as they don't take up much space and can reside right next to the radiator on the engine side of the core support.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-13-2018, 02:44 PM   #10
Andy4639
Old member
Andy4639's Avatar
Well you got me going. I went out and cut it and made it fit. This is on the old ratty Ramp truck so it don't matter as far as looks go! It should be fine!
These where old ones I made a long time ago for the 71. They have been butchered since then.
Old 10-13-2018, 03:04 PM   #11
MattG
Junior Member
MattG's Avatar
Hey HO455 I like that G body tank. For the uneducated what years are G body?
Matt
_____________
1967 C20
283 CID
Old 10-13-2018, 03:30 PM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Relocating coolant overflow
Those are off the old model Monte Carlo's. and such. I installed one years ago in my 71. Probably the first to do it on here.
Just like the windsheild electric washer jug and nozzles.
Old 10-13-2018, 04:16 PM   #13
HO455
HO455's Avatar
They are found 80's vintage Monte Carlos, Regals, Cutless and Grand Prix.
https://en.m.wikipedia.org/wiki/GM_G_platform_(1969)
RIP Bob Parks.
Old 10-13-2018, 10:50 PM   #14
ratty69
Another option is the -94 Astro van tank. It fits in the corner between the fender and the battery box, and hangs low and out of sight except for the top.
I don't have a good pic because my inner fenders are out right now.
ratty69 is offline   Reply With Quote
Old 10-14-2018, 11:50 AM   #15
NorCalC20LWB
Bought this kit from Pickmup who sells on this site.
NorCalC20LWB is offline   Reply With Quote
Old 10-14-2018, 12:20 PM   #16
ZEKE68
ZEKE68's Avatar
Ran across a tank from a mid nineties Mitsubishi Turbo Eclipse and mounted between the battery and the fender. Bad thing is that they don't make this tank anymore, so if it starts to leak I will have to do something different. Been there six years so far.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 10-14-2018, 12:39 PM   #17
garyd1961
I used an overflow jug out of a 1987 S10. I had to remove my washer jug to install it but I wasn't using the washer jug anyhow. It almost looks factory as it is in the place the washer jug would have been. I had to run a long overflow hose to the other side of the radiator but haven't had any problems with it.
garyd1961 is offline   Reply With Quote
Old 10-14-2018, 07:50 PM   #18
MattG
Junior Member
MattG's Avatar
You guys are “cool” the ingenuity is impressive. Wished we still had bone yards we could still walk here like when I was a teen.
Matt
_____________
1967 C20
283 CID
Old 10-14-2018, 09:52 PM   #19
custom10nut
custom10nut's Avatar
I put mine under the battery. I did it long ago so I can’t exactly remember how I did it. When I get back home I’ll take a picture of it
custom10nut is offline   Reply With Quote
Old 01-10-2019, 07:58 PM   #20
External
External's Avatar
Thumbs down Re: Relocating coolant overflow
Please take a picture!! I have my battery out trying to mount a tank. Having a glorious time.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 01-11-2019, 01:11 PM   #21
In The Ten Ring
I'm keeping mine stock. Refill the thing when it runs low and besides, there are too many stay dogs and cats running around anyway.
JUST KIDDING. At some point I'll put in a puke tank but I had planned to mount it between grill and core support like you have. It works, why change it?
In The Ten Ring is offline   Reply With Quote
Old 01-11-2019, 04:18 PM   #22
RichardJ
75 - 79 Chevy Nova tank will sit completely out of the way under the fender with only the cap exposed for checking/filling.
Most locations in front of the core support will be in the way of a AC condenser.
2nd picture is of a Nova tank in a Camaro from the web.
3rd picture shows it tucked in behind my multi-use battery junction block. The tank lays against the inner fender with one bolt on the fender lip.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-11-2019, 08:33 PM   #23
External
External's Avatar
Thank you for the replies, I will post a picture when I finally get mine installed.
Old 01-12-2019, 09:50 AM   #24
Andy4639
Old member
Andy4639's Avatar
Question Re: Relocating coolant overflow
That has to be a ***** to fill up. The angle is impossible to use without a funnel and you can't see the level at which to fill to in my opinion.
Old 01-14-2019, 10:32 PM   #25
68 P.O.S.
The original dealership option put it on the rad support right above the horn. Might be a good place to swap yours to so it's out of the way. Just need longer hose to run it under the shroud.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
