Old 12-20-2022, 06:41 PM   #1
gferris5
gferris5's Avatar
Re: What did you do to your truck today.The 3rd chapter
Finally finished my internally regulated alternator swap! I put a bus bar on the core support and ran an 8ga cable to the other junction, cleaned out a bunch of old bad wiring, then redid a bunch of grounds and added a better thicker ground cable from the block to the frame. Now even though the battery is in the bed, it has 14.4 volts with lights and wipers on and the battery ammeter still works. Maybe not a big deal for many folks, but this was a victory for me! So stoked!
Have mercy, I'm recovering from my 4x4 addiction.
gferris5 is offline   Reply With Quote
Old 12-26-2022, 04:21 PM   #2
68bowtie
68bowtie's Avatar
Finally finished my red interior conversion…
Old 12-26-2022, 06:50 PM   #3
best view
That’s a hard combo to beat
best view is offline   Reply With Quote
Old 12-26-2022, 08:34 PM   #4
pjmoreland
pjmoreland's Avatar
Wow!!
pjmoreland is offline   Reply With Quote
Old 12-26-2022, 10:35 PM   #5
68bowtie
68bowtie's Avatar
Originally Posted by pjmoreland View Post
Wow!!
I just wish the body was nice enough to match it
Old 12-27-2022, 12:04 AM   #6
allchevy58
allchevy58's Avatar
Attachment 2243354
Sharp! Good work.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-29-2022, 11:25 AM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Attachment 2243354
I love it!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-30-2022, 12:57 AM   #8
Sheepdip
Sheepdip's Avatar
Attachment 2243354
That's way, way too purdy to sit in, let alone spill beer on!
Sheepdip is offline   Reply With Quote
Old 12-30-2022, 02:30 PM   #9
tdangle
tdangle's Avatar
Got some color on the roof, and installed new glass. Still a lot to do
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 12-28-2022, 01:37 AM   #10
pjmoreland
pjmoreland's Avatar
I've been working on improving the u-joint angles on my two-piece driveshaft. I discovered that the center support was quite loose, despite the fact that it is only about a year old and has just a couple thousand miles on it. A local driveline shop rebuilt the driveshaft and installed a new center support. I'm not sure what the brand is of that one, but I ended up replacing it with a Federal Mogul/Bower/BCA unit that was made in the USA. Here's a video that compares the two center supports.
https://youtu.be/f6VOjeShS-A
Old 12-28-2022, 11:26 PM   #11
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
removed the matching numbers 44k original mile 350 from the 72, full tear down and inspected the entire engine...bearings good and resuable, new oil pump, timing chain, Comp Cam 268, Lunati cam saver lifters, all new gaskets, seals, 1 piece oil pan gasket.
cleaned and sprayed epoxy primer on the engine, followed by single stage hugger orange color...think it turned out good....engine is back in the truck and running well now. Cant wait to put some miles on the ol girl.
towbar is offline   Reply With Quote
Old 12-29-2022, 07:57 AM   #12
K10-Kansas
K10-Kansas's Avatar
I pulled the remaining wires. Cut the new firewall bulkhead hole, and mounted the bulkhead. Today, I'll start running new wires.
K10-Kansas is offline   Reply With Quote
Old 12-31-2022, 05:41 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
New delco for old delco plug wires.
Amazing the difference.
Always thought that old blue just hated the rain, turns out just the wires didn't.
New truck
Old 01-02-2023, 05:54 PM   #14
72c20customcamper
72c20customcamper's Avatar
Took out the 72 to get some diesel for the Kubota. Nice day and we had rain last few days so whatever salt was in the road was washed away . But because we’re in the NYC reservoir watershed they can’t use much salt on the road .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-03-2023, 10:06 PM   #15
Johnl48
Did some wet sanding and polishing today
Old 01-03-2023, 10:58 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Sweet!
~Steven
Simi Valley, CA
Old 01-05-2023, 08:28 PM   #17
Fastgramps
Added some bling (bumper guards) to my front bumper🤙
Fastgramps is offline   Reply With Quote
Old 01-05-2023, 08:30 PM   #18
Fastgramps
Forgot to add the pic☺️
Old 01-06-2023, 12:51 AM   #19
Sheepdip
Sheepdip's Avatar
Nice looking DRW Flatbed Fastgramps.
Old 01-08-2023, 09:16 PM   #20
zicc1835
zicc1835's Avatar
love the color.....
zicc1835 is offline   Reply With Quote
Old 01-08-2023, 04:07 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
2 gallons of 15-40 rotella
And one wix 51794
A fresh tube of grease thru the zerks.
Should be good for another year.
11 miles a week ads up.
Old 01-08-2023, 09:21 PM   #22
zicc1835
zicc1835's Avatar
delete.........finished getting those secured
Old 01-10-2023, 04:59 PM   #23
Johnl48
Got my hood on finally
Old 01-10-2023, 06:21 PM   #24
Trio
Trio's Avatar
sanded and spray painted the spare wheel, before getting a pizza cutter installed on it this weekend.
Trio
1971 C20 350/700R4
Trio is offline   Reply With Quote
Old 01-11-2023, 09:06 PM   #25
Grumpy old man
Grumpy old man's Avatar
I had a new driveshaft made for the 67 . 083 tube x 3.5" spicer joints . One more bite off the elephant .
