Old 07-01-2020, 01:27 AM   #1
Scurry67
Re: 67 SWB First Build
quick update-
finished cleaning up the front bed panel the other day with a hammer/dolley. Then i cut out the rust in the flange and a few spots that rusted through on the top rail. I ran a punch across the top to make sure there weren’t any additional soft spots i’d have to worry about in the future. Next, I cleaned out the top rail the best I could with a scraper and compressed air. I poured some POR15 in the top rail. It seemed to get pretty good coverage. After some primer and some body filler I swapped it on the bed. It definitely fits much better than the reproduction panel just a little filler left to sand.
I’ll shoot to finish installing the remainder of the bed bolts and get the tubs installed. I’ll also get the rear fender welded to the floor and rear cross sill. i’ll throw some body work on the hood in the mix too
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 07-01-2020, 09:45 AM   #2
TA_C10
TA_C10's Avatar
Lot of work pounding all that out and then filling with POR and fitting fitting fitting. Looking good man.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-07-2020, 01:07 AM   #3
Scurry67
Aint that the truth! It has definitely helped i think using all OEM panels. Only had to use a reproduction floor and tailgate
67 SWB First Build
Old 07-07-2020, 01:21 AM   #4
Scurry67
update.
pretty minor but exciting update for me. i’ve been talking about spraying feather fill for the last yr and i was finally able to get a couple of coats down on the bedsides. I can already tell i still have lots of sanding in my future
Bed is completely bolted together. I only needed to slot a couple holes with the new floor.
I used this 3m strip caulk for the seam between the bed and tubs. It seemed to work pretty solid and from the description it seemed like a good material for the job.
Attachment 2030710
Feather fill sprayed on pretty good for my first time. Looking forward to getting everything else in the near future
Lastly, I finished seam sealing the bed. Very tedious work with all the taping for clean lines.
67 SWB First Build
Old 07-07-2020, 09:20 AM   #5
Kronald_70GMC
Kronald_70GMC's Avatar
Looking good!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 07-10-2020, 02:21 AM   #6
Scurry67
Originally Posted by Kronald_70GMC View Post
Looking good!
hey thanks man! trying to stay on it as much i can these days.
67 SWB First Build
Old 07-10-2020, 10:08 AM   #7
TA_C10
TA_C10's Avatar
Sweet! Nice progress man. And great idea on the tailgate letters I may use that method too.
"It's only money".
Old 07-23-2020, 12:43 AM   #8
Scurry67
thanks much. the tape should save some time from unneeded sanding. I know i’ll have plenty of that in my future.
67 SWB First Build
Old 07-23-2020, 12:56 AM   #9
Scurry67
I finished spraying the feather fill over a week ago and then jumped into sanding mode. i’ve been trying to get a panel/area done a night. Just a few areas so far that will require some glaze. Hopefully in the near future my updates will include some urethane primer
67 SWB First Build
Old 07-23-2020, 09:34 AM   #10
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Looking good. Jelly arms when you are done.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 08-16-2020, 02:28 AM   #11
Scurry67
That’s for sure. Lots to go, still!
67 SWB First Build
Old 08-16-2020, 02:45 AM   #12
Scurry67
Small update -
I’ve been spending an hour here and there in the shop when it’s not too hot out. Mainly been working on the hood. It had a lot of flimsiness to it from the rotting hood brace pads. I did a pretty thorough search on here with minimal luck on what to replace it with. Tried using the foam pads but they didn’t work too swell. So I talked to a fella who restores cars for a living and he said i would Be better off using some 1 part sealer every 6” or so. Seemed to make the hood more solid. Hopefully it holds up too well and the hood doesn’t move too much with the fluctuating temps... time will tell.
Test fit with the new hinges I’ve had for awhile. They seem to be a nice piece. The manufacturer forgot a couple pieces so i couldn’t hook the gas struts up yet. Hopefully i receive them in the next week or so.
Tonight i was able to get the hood in feather fill. Back to sanding
67 SWB First Build
Old 08-16-2020, 09:41 AM   #13
Getter-Done
Getter-Done's Avatar
Great progress.
I like those hinges.
Here is an interesting thread about the hood{ link below}.
Link:https://67-72chevytrucks.com/vboard/...+dampening+pad
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 08-17-2020, 02:06 PM   #14
TA_C10
TA_C10's Avatar
Very nice. And I was thinking about using some of my leftover KILLMAT sound proofing between the hood skin and support rails. You guys think this will work ok? Might have to layer it 2-3 layers it's so thin but I was thinking seam sealer might shrink over time or get too hard with the heat over the years?
"It's only money".
Old 08-19-2020, 02:13 AM   #15
Scurry67
Originally Posted by Getter-Done View Post
Great progress.
That was one of the threads i looked into. I had purchased some of the flexible foam stuff and i did a little trial run with it. The foam definitely expands great but i was worried it would push the hood sheet metal outward too much. The guy i talked to does this stuff for a living and seems pretty reputable, so hopefully his method works.
I think 1k seam sealer I’m using should have enough flex in it and be pretty durable. I just used a dab of it about every 6 inches. Definitely got rid of the vibrating/popping sheet metal. We shall see how it holds up...
I think your idea could work. I think the key is making sure they can move independent of each other. The hood in my opinion is the most finicky panel for body work.
67 SWB First Build
Old 08-22-2020, 04:15 PM   #16
Scurry67
The missing parts for my hinges arrived this morning. Pretty happy with Summit’s customer service. Once they got ahold of the manufacturer, the parts were over nighted which i was not expecting
Anyways, spent 30 minutes piecing it together and doing a rough alignment of the hood. These hinges are pretty sweet and seem to allow for a tad more adjustment than the original hinges which is nice. They weren’t cheap but i think the money was worth it
67 SWB First Build
Old 08-22-2020, 07:31 PM   #17
Kronald_70GMC
Looking very good 👍
Kyle
IG: kyle_ronald
Old 08-22-2020, 08:30 PM   #18
TA_C10
TA_C10's Avatar
Very nice
"It's only money".
Old 08-24-2020, 12:44 AM   #19
Scurry67
Looking very good 👍
Very nice
Thanks. I think I’ll like them
67 SWB First Build
Old 08-24-2020, 01:03 AM   #20
Scurry67
Last update for the weekend. Before i blow the pickup apart again for the urethane primer and final sanding, i only have a few items left i need to do. One of those items was locating my mirrors. Had my bro over to hold them in place until i liked the location. I used threaded rivnuts to hold the mount in place.
I know these mirrors aren’t for everyone, but they seem to function well and i think they’ll look pretty good when the rest of the pickup is painted. The mirrors came from Ring Brothers, same manufacturer as my hood hinges.
Thanks to board member Siggy, the other item on the agenda was not originally planned, but I couldn’t resist I had been looking into the Altman Easy Latch Kit for our doors, and after seeing his posts about them, i pulled the trigger. Looking forward to getting those installed in the near future.
67 SWB First Build
Old 08-29-2020, 03:10 AM   #21
Scurry67
Coolest update I’ve had to date....
My wife gave delivery to our first kid earlier this week, a healthy baby boy. It’s been quite the adjustment, but digging every moment of it so far. Progress is definitely going to be slowing down a bit which is unfortunate, but I’ll still try to sneak up to the shop when time permits.
In the meantime, I’ll continue to look at the build threads to help keep the motivation going and update when i can
67 SWB First Build
Old 08-29-2020, 06:37 AM   #22
TA_C10
TA_C10's Avatar
Congrats to you sir!
"It's only money".
Old 08-29-2020, 07:10 PM   #23
Kronald_70GMC
Congrats man!
Kyle
IG: kyle_ronald
Old 08-29-2020, 08:43 PM   #24
sfont66
sfont66's Avatar
Congratulations... you should be very proud! A handsome baby boy!
Family comes first, the first years are very precious, and you can’t get them back,
Enjoy your young family now, the truck will get done in due time, very happy for you and your wife.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 08-29-2020, 11:15 PM   #25
cornerstone
cornerstone's Avatar
Congratulations indeed! That is one beautiful baby and one loyal dog!
I like your mirror choice and the location you chose. Right on
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
