Old 04-03-2019, 01:38 PM   #1
theastronaut
theastronaut's Avatar
1966 F100 Short Bed Styleside Metal/Body/Paint Work
I just started another '66 F100 short bed project at the shop, this time it'll be a mild custom. I'll only be doing the metal, body, and paint work instead of a full build like the last one ('66 F100 Stock Restoration).
I'll be fixing the rust, correcting the panel fit and gaps like the last truck, shaving some items on the dash, mocking up a Vintage Air evaporator, smoothing the firewall, adding spots for A/C vents, and painting the truck.
Here is the truck. It seems to be pretty solid overall other than the bed floor and door bottoms; definitely better than the other truck we restored.
theastronaut is offline   Reply With Quote
Old 04-03-2019, 01:46 PM   #3
theastronaut
Re: 1966 F100 Short Bed Styleside Metal/Body/Paint Work
Panel fitment and gaps.
Old 04-03-2019, 01:51 PM   #4
theastronaut
First update. I took everything apart that wasn't needed to make it run. All of the small parts were bagged and labeled so reassembly will be easier. I'll drive it around to one of the rear shop stalls tomorrow and finish dissasembly.
Old 04-03-2019, 04:02 PM   #5
mongocanfly
mongocanfly's Avatar
Looks like it'll be another good when you get done....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-03-2019, 07:21 PM   #6
Clyde65
Clyde65's Avatar
I am not a Ford guy in any stretch but....I prefer a truck like this one over the unibodies, they just look better imo!
FYI, favorite Ford truck is the 67 short bed
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-04-2019, 03:25 PM   #7
jhrusk
Looking forward to the perfection that's coming. 👍
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 04-05-2019, 04:57 PM   #8
theastronaut
Thanks!
These and '69 F100s are my favorite. Dad still has the black short bed '69 Ranger his dad bought new, its tucked away in the barn as a future project.
Thanks Jay!
Old 04-05-2019, 04:59 PM   #9
theastronaut
Teardown is finished. I'll finish removing the seam sealer and start blasting pieces next week.
Old 04-05-2019, 10:38 PM   #10
MP&C
MP&C's Avatar
That should keep you busy for a little bit.. Subscribed!
Robert
MP&C is offline   Reply With Quote
Old 04-06-2019, 01:02 PM   #11
Russell Ashley
Russell Ashley's Avatar
Your projects are always interesting, and beautiful. I've been waiting for you to start another one. I hope you document this one like you did the first 66 Ford.
Russell Ashley is offline   Reply With Quote
Old 04-06-2019, 04:02 PM   #12
CG
BlahBlahBlah
Cool truck. That's a great body style. I had a 62 Unibody.
Old 04-10-2019, 05:43 PM   #13
theastronaut
Thanks guys!
I have the bed floor and header panel out now, and have blasted around the peremeter to prepare for welding the new floor in. A 2008 Super Duty floor is the same dimensions so we ordered one to use, along with a new header panel and front sill from Carolina Classics. The rear sill isn't available so I'll have to repair and straighten it.
The seam sealer was difficut to remove by blasting so I used a dremel to cut it out.
New floor and header.
Edges blasted to prep for repair work and new panels.
Old 04-12-2019, 01:24 PM   #14
theastronaut
The four corner panels were all bent and sunk in so I started straightening those this morning. This was the driver side rear panel.
I started with the flange, then used a socket and hammer to shrink the panel back flat. The socket "traps" the metal and lets the hammer push the metal into itself, shrinking the panel. The socket has to be bigger than the hammer head and you have to keep the hammer in the dead center of the socket or else you'll hit against the edge of the socket and stretch the metal. MP&C has info on this in his '55 Wagon thread.
Old 04-12-2019, 01:27 PM   #15
theastronaut
Driver side front panel.
After:
I also made and fitted both front corners that were rusted.
Blasted and shot SPI epoxy on the two floor braces.
Old 04-12-2019, 02:04 PM   #16
MP&C
MP&C's Avatar
Awesome work John!
Robert
Old 04-12-2019, 05:34 PM   #17
mongocanfly
You make that look easy John....good work..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-18-2019, 10:52 AM   #18
theastronaut
Awesome work John!
Thanks guys!!
The inside of all the panels were shot with undercoating so I scraped all of it off to prep for blasting.
After:
The two center floor braces were bent so I used our tubing roller to straighten them.
They were also dented around the mounting bolt holes.
The truck was stripped and repainted at some time. The paint strips easily and quickly with a razor blade leaving a thin coat of primer and some spots of filler. I'll strip the primer/filler with a DA sander to avoid blasting and warping the bed sides.
I test fit the front header and cross brace, the filler panels I made, and the center braces.
Also cut out the rust that was on the flange that the bed floor spot welds to and welded in new metal.
Old 04-18-2019, 07:11 PM   #19
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Subbed......I like watching your projects.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-30-2019, 05:23 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
Yup, this is going to be awesome.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-02-2019, 04:18 PM   #21
theastronaut
Thanks for following!
I've been working on blasting the bed, inside and out and underneath, that's about 95% done. I'll work on straightening and repairing as much as I can while it's in bare metal before going back over the areas I missed with the blaster and then shooting epoxy.
The seam between the upper and lower passenger side bedsides was pretty rough so I spent extra time cleaning it out with the blaster.
The new F250 bed floor has stamping for a fifth wheel ball, and the owner wants to add a fuel tank under the bed with the filler cap in the bed floor. I'll cut out two sections and swap them to make the center smooth and have a stamped area around the filler cap.
The rear corners had back up lights added, so I straightened the area and welded up the holes.
The bedside is wavy and sunk in over the front of the wheelwell so I've started stretching the area by hammer-on dolly plannishing the area to raise the low spots.
The bottom driver side behind the wheel opening had a couple creases, dents, and a torn spot on the edge of the flange.
Old 05-02-2019, 04:22 PM   #22
mongocanfly
looking good with the rapairs...great idea for the fuel fill switcharoo...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-03-2019, 06:16 PM   #23
Russell Ashley
I always look forward to your updates. Always very interesting, and I like your before and after shots. I had a 65 Ford like this with the available trim, bright grill, bumpers, etc. Has the owner of this one indicated that he would like you to add this to this one? I think it's all available.
Old 05-09-2019, 11:16 AM   #24
theastronaut
Thanks!
Yes, we'll be adding the side trim and either the polished aluminum or chrome grill.
Old 05-09-2019, 11:25 AM   #25
theastronaut
I had seen people use Bronco wheel tubs to widen the factory tubs, and to use for trucks with raised bed floors but not for stock tub replacement so I wasn't sure that they'd work. They were only $70 shipped each so we bought one to try out and the stamping ended up being identical with only a couple details that needed attention.
The stock tubs were pretty rough so I cut them out with the plasma to get to the inner flange.
For Bronco applications they had a notch cut out for the shock mount. I welded that up since the bed floor will be welded to that area of the flange.
Test fit.
Trimming the bottom edge to match the original shape.
Couple of pinholes welded up.
There were dimples in the flange area from the original spot welds so I straightened those so the new tubs would fit flush.
