Old 06-30-2019, 09:43 AM   #1
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 292 Questions
Originally Posted by May70 View Post
There is constant flow, no resistance when i blow in it.
Yup, it's toast!
~Steven
Simi Valley, CA
Old 06-30-2019, 01:38 AM   #2
Mike_The_Grad
Mike_The_Grad's Avatar
Re: 292 Questions
With those black nitrophil floats you dont submerge them in water to find a leak. That only works on the brass soldered type floats. The way to check the black foam type of floats is to remove it from the carb and let it sit on a paper towel until it dries out. Really depends on the fuel evaporating. Then you can either still see where fuel is wicking out of any cracks or dunk it quickly into some fuel and pay attention to it evaporating. It should look like its evaporating somewhat evenly and not like there is a crack with fuel evaporating more slowly than the surrounding area. Definitely check where the metal arms enter the foam. It may look just fine when its dry but it will show any voids in the foam by way of evaporation. Dont use anything other than fuel to check for leaks. Brake cleaner, carb cleaner, starter fluid, water, acetone, etc. Will all either degrade the foam or soak in and take forever to evaporate if at all. There is a common suggestion regarding carburetor floats. And it goes," if the carb originally came with brass floats, stick to brass floats, or if foam, stick with foam. Dont change from one to the other. Also, try and source american made BRASS floats. As the import brass floats seem to have issues with the soldering process." I went through 3 different brass fuel sender floats before I got fed up with the vendor sending me more import floats that I switched to a plastic float that is near identical to the brass one. So far it works.
Your vacuum canister is definitely a vacuum leak and is why you see no change in timing when you tried sucking/blowing through it.
The purpose of using vacuum gauge while adjusting your idle/air screw is to attain the highest possible vacuum at the lowest acceptable idle. Your results reflect this. A rise in idle rpms will increase vacuum up to a certain extent. I like your reading of 1.5 turns out with 680 RPMs and 21.5" Hg. That is damn near perfect as you're gonna get. Tells me you have no issues with piston rings, head gasket, intake gasket, valve guides, or base timing. All good things.
BUT.
You have a vacuum leak. Just not at idle. Because the vacuum canister is hooked up to a ported vacuum source. Meaning it is a vacuum source above the throttle blades. Which is why you can idle it, but as soon as you give it gas, you open up a vacuum leak along with a malfunctioning vacuum assisted advance of your ignition timing. Compounding issues which may or may not be your only issues. Hopefully it is because your vacuum gauge readings seem good. The other thing about vacuum gauge readings is the steadiness of the needle during the reading of the state of the needle. Ideally it should be like the arm of a clock and not wander at all. Some slight movement is acceptable(within 1"-2"Hg.) But any erratic or continuous behavior is not.
My suggestion is to replace the vac canister and check everything again. I mean EVERYTHING. Timing, dwell, idle mixture screw, fast idle screw and vacuum gauge readings. My guess is that something is gonna change from your current setup. Those numbers I quoted up there are what you want to shoot for.
Remember, ADJUST timing with the vac can disconnected and RPMs below 750. But CHECK your timing with it both connected and disconnected.
Adjust your carb and rpms with it CONNECTED.
Good luck, I think your close to fixing your problem with the can. Let us know how it goes.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 07-05-2019, 02:44 AM   #3
Mike_The_Grad
Re: 292 Questions
That port appears to be above the throttle blades, but I could be wrong. If so, then it would also explain why at idle you have good vacuum and response from your carb adjustments but as soon as the throttle is cracked you have issues. When you adjust your carburetor do you flick the throttle at all with either your hand or foot? I do. Why? I dunno. Just something I thought would help "reset" the idle position to make sure it wasnt wedged or something. Anyways, I ask because I'm wondering if you have the same reaction while you're trying to drive the truck as if you were to manually work the throttle with your hand while under the hood. or if the engine only acts up while in gear and in motion.
Old 07-05-2019, 10:46 PM   #4
May70
May70's Avatar
Re: 292 Questions
Also found this (see pics): I thought I saw a video from mikes carburetor parts where he said this was in trucks that have AC? but the carb diagram doesnt mention cases which some carbs wouldnt have that 'idle compensation assy' and my kit did come with #17 gasket. Mine also looks to be blocked off?
I put the old float back in it and re adjusted the float level, just to see if the brand new 30$ float is garbage. I also took the jet out and made sure it was perfect, same with the needle. Adjusted the metering rod to spec (5/64 from bowl top). I made sure that the accelerator pump is working, I also made sure the check ball is seating and it is (holds a pressure against accelerator pump when i hold it down and try and plunge the pump). Other than that i blew out every orifice with carb cleaner again.
I put the screws back in snug then tapped around the flange on each gasket, then tightened them up real good (as mikes carb parts mentions to do in his monojet videos).
I have it back together now. Waiting to hear back on the manifold to throttle body gasket question. If this doesn't solve it im gunna have to take it to someone.
May70 is offline   Reply With Quote
Old 07-06-2019, 12:11 AM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 292 Questions
OK, it's always run like crap since you bought it? I hate to ask you to take the carb back off, but let's have a look at the throttle body, the carb and the base gasket(s). It's clear now that that one port doesn't leak, so let's keep drilling for the answer.
~Steven
Simi Valley, CA
Old 07-06-2019, 07:57 AM   #6
May70
May70's Avatar
Re: 292 Questions
No it ran fine when I bought it in march and I could hop in and drive it when ever no worries. I had to feather the throttle when shifting or starting off to avoid a "neck breaker" (as someone who rode with me called it) but that was pretty much it. I figured it needed a carb cleaning at the time. Eventually it got harder to control the feathering good enough to make it enjoyable for anyone else to ride with me. A lot of rough starts(from stop).
Then I decided to change the oil because it looked like it had not been changed in a while and it was leaking from the valve cover/side covers a lot. So i knew I was either going to have to add oil or change it all. I changed the three gaskets then decided to change the oil a few weeks later. Shortly after I changed the oil it started the smoking, within a matter of a few short drives (~30 min ea). I would come to a stop and see/smell it come up by the cab. Eventually the smoke got worse to the point it is now.
The last time I actually drove it a few miles I was running 55 on the way home. All of a sudden it just lost power at high speed, but if I dropped it down to 35 or 40 maybe it was fine and I went straight home. That is when I started all of this and just decided I needed to go through everything.
I have the carb off now, Ill go out and snap some pics
Old 07-06-2019, 11:33 AM   #7
May70
May70's Avatar
Re: 292 Questions
As i said earlier I changed to the old float and cleaned everything out again. Wanted to see how it did after all that. No difference. I went ahead and went through the adjustments just to see.
Mix Screw Adjustment (Rotations out from seated), RPM, VAC (in Hg), Notes
4, 600, 20
3.5, 600, 20
3, 600, 20
2.5, 600, 20
2, 630, 20
1.5, 680, 21
~1, 750( corrected to 650 via fast idle screw), 22 **Returned here (best vac)
.5-.75, ---, --- (Vac and rpm dropped off, very rough idle)
Still boggs out trying to get it going. When I first started it up I sprayed a lot of carb cleaner and no change in idle. After it was hot, I did get a slight reaction to the throttle body gasket on the back side. Could heat/warpage be causing a vacuum leak? The throttle body flange isnt perfect but I would be surprised if thats the culprit of the bogg situation. I may take it off and get a real flat surface to wet sand it on. Just speculation at this point.
Old 07-06-2019, 09:17 PM   #8
May70
May70's Avatar
Re: 292 Questions
Had a friend come by to look at it. He thinks this is a lack of fuel problem. I sized up the jet/needle with the one that came in the kit (was slightly bigger than the one that was in it previously). No difference.
My in line fuel filter isnt emptying but its definitely not full at idle or even with a lot of throttle. Maybe half of the filter is full and when I put the throttle down I really dont see gas movement like I think I should. It has a slight pressure on it at idle because when i take the fuel line off after to remove the carb, some does squirt out. Is it possible that the mechanical fuel pump diaphragm has a crack in it or something and its not able to push enough gas to carb to keep up with rpm, resulting in the motor dying when I try and throttle it/start to go?
Old 07-06-2019, 10:27 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 292 Questions
Don't let the appearance of vapor in the filter fuel you. The engine can still be getting plenty of fuel, even when it looks like that. If it is under pressure, fuel is guaranteed to be getting to the carburetor. Any vapor that makes it to the carburetor will burp off immediately. I had a '66 Le Mans that turned high 13s in the quarter and the see-through filter always looked half-full. It may well be fuel delivery, but the appearance of that filter doesn't prove it.
Also, if when you remove the fuel line from the carburetor there is pressure, then the fuel pump diaphragm and poppet valve are not leaking. The more we see, the more culprits are eliminated.
I'll go back through this thread tomorrow and try to see if we're all missing something. Nothing I like better than making something work, though I'd rather have it in front of me instead of on the computer.
~Steven
Simi Valley, CA
Old 07-07-2019, 03:21 AM   #10
Mike_The_Grad
Re: 292 Questions
Well looking at your recent posts may have revealed something to my eye at least. It appears you have taper seat spark plugs. From what I understand these inline motors take the gasketed type spark plugs. I could totally be wrong but my parts guy informed me that the 250 cylinder head I had him go through for me takes the gasketed type. Does that mean all of them do? No, but it is something that could be contributing to your issues.
My buddy ran his 71 c10 from where he bought it to his place about 100 miles away. Well almost. The hei power wire fell off because it was wirenutted together. Anyways, he had taper seat plugs in his 041 head SBC, which takes the gasketed type of plugs. It ran sure, but not correctly.
Also, dont worry about the fuel filter being completely full or not. They usually aren't. But there is one thing you need to watch out for with the clear type of fuel filters. And that's to make sure the filter element inside doesnt come unglued from the base. Almost every clear one I've had has had this happen. The element ends up floating around inside and not doing its job. So I switched to the metal inline type. Yes, you cant see how much crap is inside. But that's why I made sure my fuel system was 100% clean to begin with. Tank, pickup tube, metal fuel lines from tank sender all the way to fuel pump, and to the carb, plus the carb. Filter between pump and carb. Use as minimal amount of rubber fuel line as possible. It dont hold up to long to today's ethanol fuel. Maintain same size line from tank to carb. In case this is all remedial stuff, I apologize. I figure information is information regardless of who is reading it.
Keep at it. Look at the positives. It starts, it runs, just not well. That's more than some people got going for them .
Old 07-07-2019, 05:52 PM   #11
May70
May70's Avatar
Re: 292 Questions
For $18 I went out and got a carquest 'premium' mechanical fuel pump. Might as well narrow it down. Started the uninstall before it started thunder storming here. Noted that I only have about a foot, it appears, of rubber hose to replace. I think its metal fuel line all the way back to the tank and it looks to be in good shape under the oily gunk its been covered in for a while. The fuel pump outlet goes into a metal line which stops short about 5 inches from the carb. Then I have a few inches of rubber line with the inline filter.
I had prepared a plug because I was expecting a seep/drain of fuel when I took the hose off between the metal line to the tank and the hose to the pump. I got about 3 drops of gas and then nothing. There is at least a few gallons of gas in the tank. Is this normal? Can someone school me if there is a metal mesh filter or something in the tank outlet? Can I remove the gas cap and blow it out with an air hose or is that a bad idea? Just to make sure no debris is clogging it? Anything else I should do at this point or just throw the new pump on? Thanks
Old 07-07-2019, 06:35 PM   #12
Fbks_Cruiser
Fbks_Cruiser's Avatar
Re: 292 Questions
You have definitely found a problem. Gas should be siphoning out of that fuel line aplenty. I would disconnect the line at the sending unit on the tank and while disconnected at the fuel pump blow some air to verify it is clear.
But, I suspect that the sock on the pickup is plugged with junk and the tank may also have sediment/rust in it. If you really only have a few gallons of gas in the tank, now is a good time to pull the sending unit and inspect the pickup screen and inside the tank.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 07-08-2019, 01:47 PM   #13
straight6chevyguy
straight6chevyguy's Avatar
Re: 292 Questions
I agree with Mike_The_Grad about the spark plugs.
My 292 takes the gasket type plugs.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 07-08-2019, 02:17 PM   #14
May70
May70's Avatar
Re: 292 Questions
Anyone got a number? Parts store has the 292 coming up as having the tapered plugs. When I go to summit I see both listed for a 292. I will do some research on the side if no one has that info off the top.
Old 07-08-2019, 02:23 PM   #15
Motorfist
Re: 292 Questions
I’ve got AC Delco R44XL in mine. I think the Autolite number is 404. That should be enough info to cross reference to whatever brand you prefer.
67 c30 Cab and Chassis (ex motorhome truck)
68 c10 LWB
70 c30 Cab and Chassis 133" converted to Longhorn
72 K10 LWB Rust Bucket Hunting Truck
Motorfist is offline   Reply With Quote
Old 07-09-2019, 04:58 PM   #16
straight6chevyguy
Re: 292 Questions
I am currently using NGK 4922's in my 292.
Old 07-08-2019, 02:48 PM   #17
May70
May70's Avatar
Re: 292 Questions
I blew out the line from the sending unit up to the fuel pump. I got a tiny spec or two and that was it. Sprayed about a half bottle of carb cleaner down it and blew it out for a good minute. Seems clean and clear for the most part. Decided to take the sending unit out of the tank to see how that sock was looking (see pic). The sock really didnt look bad but the tank is rough. I siphoned out a little less than 5 gallons which seemed to be almost all of it. I ran it all through a t shirt to transfer it and you can see in the pic what 5 gallons worth held. Guess this marks off the theory that the something was plugged up but gunna need to take care of this tank now and hope the new fuel pump does the trick.
I have read some shops offer services to bath these in something and clean them up. Not real certain anyone close to me does that. Ill have to check around and on the price. A repo tank is 200 shipped from lmc but I think I could do better cleaning it myself and sealing it. That red kote stuff I have seen mentioned several times.
Ive got a jar of BBs that I think I might shake around in there to start with, nuts and bolts. Suggestions are welcomed, ha ha.
Old 07-08-2019, 02:59 PM   #18
RichardJ
Re: 292 Questions
The only way you know for sure if your head uses tapered plugs or the gasket plugs is to look at the plug hole.
On a 50 year old engine, your head could be from a 230, a 250 or a 292. It could be from an earlier engine with gasket plugs or the later style. If you insist it's an all original, unmolested engine, you're a dreamer.
RichardJ is offline   Reply With Quote
Old 07-08-2019, 03:20 PM   #19
Motorfist
Re: 292 Questions
I've messed around with a lot of classic motorcycles over the years and have seen some coatings fail that were done by professionals. I will never use one again personally. Next time I run in to an issue I plan to try this stuff https://www.workshophero.com/products/metal-rescue/
If you're not interested in something like that, my advice would be to get as much of the loose crud out of there as possible and be diligent on replacing fuel filters. Avoid ethanol gas if possible and if not possible, never let the truck sit for extended periods of time without a full tank.
Or bite the bullet and replace the tank.
68 c10 LWB
Old 07-08-2019, 03:52 PM   #20
May70
May70's Avatar
Re: 292 Questions
Even with that what are you going to put on the metal to keep the rust from coming back? Im planning on picking up about 10 gallons of vinegar to put in there, doing a lot of shaking and sitting over at least a few days. Then maybe coming back with evaporust or that metal rescue stuff depending on how bad it is after the vinegar. Im still thinking that after that I will need to put some sort of seal/coating to prevent it from rusting back quickly.
Old 07-08-2019, 04:47 PM   #21
Motorfist
Re: 292 Questions
I personally would not put vinegar in there. It will loosen the rust which will need wiped off somehow and then the tank will be coated in a thin layer of rust again. I have been through that with bike parts. The acid in it will create flash rust because the acid etches the metal.
I have no affiliation with the Metal Rescue stuff and dont know if it works as well as they claim. But if it works even half as good as they claim, it should be awesome. They even compare it to vinegar on their website.
Supposedly, it doesn't create flash rust. To avoid rust build up again, I would defer to my statement about avoiding ethanol and also avoiding storing the truck without a full tank of (preferably treated) fuel.
My hang up with doing your gas tank with Metal Rescue is the cost. I bet you'd need to spend $150 on the stuff to effectively clean your tank. They claim it is reusable so unless you have other projects to use it on, it's not worth it.
I did a site search for Metal Rescue and it looks like other folks have used it with success. And you can buy it at Home Depot
68 c10 LWB
Old 07-08-2019, 06:51 PM   #22
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 292 Questions
Do you have access to a feed store? You can buy and dissolve some powdered molasses for way cheap and it will take the rust off, just like Evapo-Rust does. You will still have to seal the metal some way, though. I have yet to look back through you thread here. I've been slackin'.
~Steven
Simi Valley, CA
Old 07-08-2019, 11:33 PM   #23
Mike_The_Grad
Re: 292 Questions
Mav70, the issues you're running into remind me of what I'm going through with my dads truck. 64 c10 LWB 292 4 speed granny low. His gas tank looked like something out of cave diving documentary. Stuff growing out of the sides and bottom, yellow, varnished, nasty stuff. We had a spare gas tank we got in a craigslist purchase of a different 292. That block turned out to be cracked, but we got a lot of parts. Well the tank they gave us was practically spotless inside. Save for some "white rust" (yes, it's a thing google it.) Not wanting to risk clogging up the new sending unit sock I wanted to clean out the tank somehow. Here's the best advice I could glean from YouTube and the internet:theres quite a few different methods for cleaning a tank. Best solution obviously is to replace the tank and sending unit. If that's not in your budget then you have to get the bad stuff out and ideally prevent it from coming back also, neutralizing whatever method you decide on to prevent further damage. Being that the tank we have only had some white powdery stuff inside I didnt want to get to aggressive with it. Some type of media would be best for heavy sludge/rust/junk. Like:Nuts,Chain,BB's,Pea gravel, etc. What you want to ensure is that whatever you put in, comes back out. So count all of the pieces of whatever you use to ensure they are all accounted for when you dump them out. I ultimately went with apple cider vinegar for cleaning my tank. Picked up a gallon at the local supermarket for about $5. Dont get the organic stuff costs almost 4 times as much. I poured in about a half gallon and gave it a good shaking and swishing around. Then I played it on each different side as best I could for a few hours each. Then poured out the liquid. It looked ok maybe a little tinted. Then I washed it out with the garden hose. Then heated a gallon of distilled water on the stove in a big pot to almost boiling and added about half a box of baking soda and stirred it real good. Then poured that in about a quart at a time and shook it all around in the tank. Emptying the tank each time. One last rinse with a gallon of distilled water from the jug and put my air nozzle inside till it looked dry. Sealed it back up until I was ready to install it in the truck. When I unsealed it, it was still dry, no rust and no more white stuff.
Old 07-09-2019, 12:49 AM   #24
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 292 Questions
I've had good results [twice] from removing the tank completely and taking it to a good radiator shop, and having them hot tank it or steam-clean it. Once with the 22.5 gallon in-cab tank on my Stepside, and once with a 20.5 gallon belly tank from my '67 Suburban.
Some of these shadetree methods scare me. Molasses, really?! Don't vandals sabotage an enemy's engine by putting sugar in the gas tank?
Old 07-09-2019, 09:12 AM   #25
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 292 Questions
That's a myth. Sugar doesn't dissolve in gasoline. Molasses works, and of course if he used it, he'd flush it out afterwards.
~Steven
Simi Valley, CA
