Old 01-12-2020, 08:53 PM   #1
Inverter
Inverter's Avatar
Anyone can buy an SWB...
Been away for a minute. Started my MTP a year ago, this truck is one of the goals along the way. Started as a bone stock BB/auto then i did a moderate resto-mod and enjoyed it for a few years. Ive been cutting and reworking a LWB chassis to get the perfect stance for this conversion.
Inverter is offline   Reply With Quote
Old 01-12-2020, 09:05 PM   #2
Inverter
Inverter's Avatar
Re: Anyone can buy an SWB...
Old 01-12-2020, 09:52 PM   #3
Inverter
Inverter's Avatar
Old 01-12-2020, 10:10 PM   #4
Inverter
Inverter's Avatar
Old 01-12-2020, 10:15 PM   #5
tinydb84
tinydb84's Avatar
Very nice truck. Clean work you are doing there as well!
David
Instagram: myfabguy
Old 01-12-2020, 10:27 PM   #6
Inverter
Inverter's Avatar
Old 01-12-2020, 10:29 PM   #7
Inverter
Inverter's Avatar
Thank you. Labor of Love...
Old 01-13-2020, 01:46 AM   #8
Inverter
Inverter's Avatar
Old 01-13-2020, 01:53 AM   #9
Inverter
Inverter's Avatar
Old 01-13-2020, 02:04 AM   #10
Inverter
Inverter's Avatar
Old 01-13-2020, 02:25 AM   #11
Inverter
Inverter's Avatar
Old 01-13-2020, 03:04 AM   #12
Inverter
Inverter's Avatar
Old 01-13-2020, 03:08 AM   #13
Inverter
Inverter's Avatar
Old 01-13-2020, 03:38 AM   #14
Inverter
Inverter's Avatar
Old 01-13-2020, 03:42 AM   #15
Inverter
Inverter's Avatar
Old 01-13-2020, 10:55 AM   #16
SCOTI
SCOTI's Avatar
Very nice. Suspension mods are clean.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-13-2020, 01:26 PM   #17
raggedjim
raggedjim's Avatar
Very nice work, how much did you section the front cross member? I like the frame mods to raise the steering box and centerlink.
Rg
raggedjim is offline   Reply With Quote
Old 01-13-2020, 01:33 PM   #18
CG
BlahBlahBlah
Very nice work ... What does MTB stand for?
Old 01-13-2020, 02:15 PM   #19
Inverter
Inverter's Avatar
Appreciate the words.
Rg
Cool... 1 and 1/16”. 🙂
Old 01-13-2020, 02:24 PM   #20
Inverter
Inverter's Avatar
Thanks. MTB is an acronym for mountain bike 😆. MTP is a massively transformative purpose. The short version: Changing your life and finding your real purpose in the time thats left. Living an examined life.
Old 01-13-2020, 03:16 PM   #21
Inverter
Inverter's Avatar
Old 01-13-2020, 03:39 PM   #22
Inverter
Inverter's Avatar
Motor/trans position is slightly higher, Output shaft is 2.8 degrees, carb surface is .1 degree off level at ride height of 5 3/8”. The BB CPP mounts were a terrible fit. Took reengineering to make them fit correctly. This and also needing the extra clearance between drag link n oil pan caused the z-bar position to change. Enjoy the Handsome bracket below !
Old 01-13-2020, 04:18 PM   #23
Inverter
Inverter's Avatar
Z-bar off a 6-cyl. Sectioned tube, made, moved & reclocked lower arm.
The throw is butter smooth and effortless. Upper pushrod is thin wall tube w/bolts welded at ends.
Old 01-13-2020, 04:29 PM   #24
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Totally awesome. Great work!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-13-2020, 05:29 PM   #25
Inverter
Inverter's Avatar
Thank you Josh.
My experience with an aftermarket panel bed: i see this often on even some high end builds where the bed caps are level w/ the cabs upper bodyline and the lower bed line is 1/2 or better too high... i fixed this by sectioning the front stands and rear rail ends. The other 2 cross sills were sectioned to match. Dont know how one could live w/such a poor off the boat fit.
