04-28-2020, 09:35 PM | #1 |
$1.00 60-63 C10 Cab Cuts
Just got this cab. Not sure if any of you guys may need some cab cuts. Everything is available except for the BBW.
$1.00 plus the cost of shipping to you. Last edited by 67see10; 04-29-2020 at 02:26 AM. |
04-28-2020, 11:14 PM | #2 |
One foot in front of the other
Re: $1.00 60-63 C10 Cab Cuts
Whats radio area look like?
04-29-2020, 01:44 AM | #3 |
Revitalizing a 6T C10
lower A pillar area, inside the cab about level with the dashboard
04-29-2020, 02:13 AM | #4 |
04-29-2020, 02:14 AM | #5 |
04-29-2020, 02:23 AM | #6 |
Here are some pictures
04-29-2020, 03:44 AM | #7 |
Hi 67 I'll take the transmission firewall section and the radio delete plate. Thanks.
04-29-2020, 09:40 PM | #8 |
Ill take this section right here please. Shipping to 37843. Let me know how you want paid.
04-29-2020, 09:49 PM | #9 |
04-29-2020, 09:53 PM | #10 |
Sounds good..
04-29-2020, 10:01 PM | #11 |
Speaker bracket happen to be still there? Defrost vents?
04-29-2020, 10:13 PM | #12 |
Not too familiar with the 1st gen c10s. Where would the factory bracket be?
04-29-2020, 10:16 PM | #13 |
04-29-2020, 10:30 PM | #14 |
It right under that grate. Held on with a bolt to the cab.
04-29-2020, 10:44 PM | #15 |
Looks something like this to the right.
04-30-2020, 04:01 PM | #16 |
Any rust through on the upper corners of the windshield area? I need both sides inside and out. Also, if it has the passenger side sun visor bracket, I could use that area as well
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 04-30-2020 at 06:00 PM. |
04-30-2020, 05:08 PM | #17 |
I would take a 3 of pieces of the stamped back of the cab highlighted, say about 1 inch on each side of the bends and about 6 inches up, so they can fit in a priority box like Small Box 8 11/16" x 5 7/16" x 1 3/4" $7.65
or Medium Boxes 11 1/4" x 8 3/4" x 6" or 14" x 12" x 3 1/2" $13.20 , thanks Joe |
04-30-2020, 07:52 PM | #18 |
No passenger side visor
04-30-2020, 08:15 PM | #19 |
That's ok. If the rust isn't completely through on either side, I need both of these circled sections. I have not cut into my truck yet to see the extent of the rust, but I know it looks pretty bad from the outside, especially on the passenger side. Just to be on the safe side, if you are willing to cut out the inside section with it, that would be great. I don't need the roof skin though. Seam sealer deteriorated and let water rust out the upper lip areas.
My zip is 30188 Thanks! *Edit* I will go check on my cab in a couple minutes to see if I need the inside part or not.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-30-2020, 09:27 PM | #20 |
I'll start working on the cab cuts tomorrow.
04-30-2020, 11:31 PM | #21 |
I checked my cab on the inside. It looks ok. It's the outside part that I know has some big holes in it
05-02-2020, 08:55 PM | #22 |
How much of the back window are you keeping? The whole panel, or are cuts along the bottom of the cab at the pinch weld available?
I need about two inches high, along the driver's side. It's been a while since I've seen the cab--if you're good with cutting that area, I'll go find out what I need exactly. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
05-03-2020, 06:58 AM | #23 |
I’d like to have one side of the dash, for the “hump” portion on top.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
05-03-2020, 07:01 AM | #24 |
Either side of the dash will be fine for my purposes, whichever is the straightest.
05-03-2020, 12:27 PM | #25 |
Can i get this section cut out please? let me know how much to 94513. Thanks
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors 2007 chevy 2500 hd 4x4 duramax |
