05-16-2020, 06:17 PM | #1 |
Glue on or push on door rubber
Getting ready to order a rubber kit from GMC Pauls. Wondering which door rubber is better for shutting the door. I have now push on rubber and and wondering if glue on might be a little thinner and easier to close the door
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-16-2020, 07:48 PM | #2 |
Re: Glue on or push on door rubber
Push on,I got mine fron GMC Pauls,love them,they will be a little tight at first,but will relax,or you could loosen up your strikers,no glue is the way to go!
05-16-2020, 08:01 PM | #3 |
I have the glue on they dont fit well and the glue is a pain im going to try the push on
05-16-2020, 08:32 PM | #4 |
I tried glue on but as firedemon said, total PITA... i went with a set from the junkyard from a van, cut to size... had the same tightness issue for a year but after sitting for a while they aren't too bad.
05-16-2020, 10:36 PM | #5 |
Roto Reuter thats the name...
I will not use the glue on door seals any more. Some people use the new style push on door seals. Others use Dakota or Honda door seals. I tried the push on door style from Brothers, but I had to slam my doors to get them to shut properly. I bought the Honda Civic seals and my doors shut much better. There's info on this thread link.
http://67-72chevytrucks.com/vboard/s...d.php?t=801388
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-16-2020, 10:42 PM | #6 |
2010 honda civic fit perfect, spent a whole 5.25 for the set from Pick n Pull
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
05-16-2020, 10:54 PM | #7 |
Moderator
I’ve used all kinds; push on, glue on, Dodge Dakota seals, and the civic seals. The civic seals win out in my book. Put them on three different trucks and they all shut perfectly without slamming.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-17-2020, 12:11 AM | #8 |
All about them K’s
I put precision push ons on my K20 last week. I’m happy with them. The mitre at the front upper corner is a nice touch. I don’t have to slam the doors but you do have to push on the handles firmly as you close the door to get them to latch if that makes sense.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
05-17-2020, 02:13 AM | #9 |
At the body shop.
The glue on was a disaster for me.
Push on are nice, but my passenger side is always off by the latch.
" That didnt make it any newer " " Dont antique the equipment " |
05-17-2020, 06:59 AM | #10 |
I got my push on from steel rubber have no issue with them at all
https://www.steelerubber.com/door-se...yle-70-3881-72
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US Last edited by DA71Grande; 05-17-2020 at 07:00 AM. Reason: . |
05-17-2020, 12:09 PM | #11 |
05-17-2020, 04:55 PM | #12 |
I bought mine from JEGS,
Precision Door Weatherstrip Seal Kit 1967-1972 Chevy & GMC Truck 757-DWP 1112 67 1 $39.59
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
05-18-2020, 09:12 AM | #13 |
Push on, with the seam under the sill plate.
05-18-2020, 09:37 AM | #14 |
Also don't forget to put a v notch in the ends of the rubbers to let some aie escape when you shut the door,I have seen so many that were glued at the ends with no relief for air escape,so the air trapped inside will pressurize the rubber and won!t let you shut the door without slamming it,just my 3 cents
05-18-2020, 06:47 PM | #15 | |
05-19-2020, 05:06 AM | #16 |
I like my Sofseals, but a major pain to glue on..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-05-2024, 02:48 PM | #17 |
Just put press on door seal on left side, seems great except it came out 3/4 inch short. Was expecting too long if anything, got em from LMC, so don't know brand, wondering if anyone else has run into this. (probably get same thing back if I returned them, will most likely cut piece off old seal and glue it in since sill plate covers it.)
08-05-2024, 09:58 PM | #18 |
Push on. They give you the ability to remove them and make adjustments.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
08-05-2024, 10:16 PM | #19 |
Has anyone sourced “new” civic seals - and, if so, where and what was closing the door like? (I’m kinda assuming the used civic seals are worn and that is part of why the doors shut easily). I’m skeptical they are even available new but just curious. I’ve used the push on seals and the doors were so hard to shut I took em back off and just reinstalled the old ones on a previous truck. Tried all the fitting tricks, notch for air escape, moving striker etc and they still sucked. Had to slam the door so hard it just wasn’t worth it.
08-06-2024, 11:15 AM | #20 |
Two weeks ago I sourced 2010 Honda seals and they fit perfect. No slamming.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
08-08-2024, 06:40 PM | #21 | |
https://67-72chevytrucks.com/vboard/...d.php?t=741910 My modification to remove the extra "lip" is in post #155. New Honda seals worked well, no need to get used ones from the junkyard if you don't want to. I tried the Precision seals and had the same hard closing issues as most. Honda seals felt factory correct.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 |
08-08-2024, 06:48 PM | #22 |
Subscribed!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
08-08-2024, 08:04 PM | #23 | |
08-12-2024, 08:59 PM | #24 |
I bought the push on from LMC. They kept falling off. I pinched them to get them to fit tighter and they still fall off. Also, they are too short. Your supposed to push them on in kind of a tight bunched up way but if you do that with the LMC ones, you'll end up 6 inches short of making it all the way around the door. But the more you stretch them out to cover the whole door, they easier they fall off. So I went ahead and glued them on. Also, I now have to slam my doors to get them to close. I need a better solution. Maybe I'll try some of the recommended ones in this thread.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
08-13-2024, 08:32 AM | #25 | |
