06-26-2020, 11:35 PM | #1 |
T-5 swap time
Last week my three speed decided it was time to retire. Instead of tying to rebuild it I am going to install a T-5. I have all the components except for a bell housing reducer ring ( on order ) Stay tuned!
RIP 3 Speed
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-27-2020, 10:48 PM | #2 |
60-66 Nut
Re: T-5 swap time
I think you will like the T5.
06-28-2020, 12:38 PM | #3 |
Re: T-5 swap time
Well I ran into my first snag.
The PO installed an aluminum "full" bell housing. I have removed all the bolts but am unable to get it off due to it not clearing the transmission crossmember. ANY ideas ? I am almost tempted cut the crossmember off and run a rear trans support on the t5
06-28-2020, 02:18 PM | #4 |
Re: T-5 swap time
Unbolt the engine and move it forward. I couldn't get my bell housing off ether when I was doing my clutch. I was able to unbolt the pressure plate and change it out without removing the bell housing. I was just throwing a temp clutch in until I pulled it and am now rebuilding everything
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-28-2020, 02:19 PM | #5 |
Re: T-5 swap time
Or you can just grind down the rivets and remove the cross member and bolt it back in if you need it.
06-28-2020, 03:16 PM | #6 |
Re: T-5 swap time
Thanks I'm not seeing any rivets..its a 60 so the frame and it looks to be welded on. I don't have a lift to move the motor
06-28-2020, 03:25 PM | #7 |
Re: T-5 swap time
06-28-2020, 09:40 PM | #8 |
60-66 Nut
Re: T-5 swap time
Just cut that bellhousing crossmember out of there. You aren't using it so as you have found out, it is in the way. You must already have a transmission crossmember then, so you won't have to build a new one.
06-29-2020, 10:43 AM | #9 |
Re: T-5 swap time
Thanks . The po had some L brackets to support the bellhousing to the
bell mount crossmember. I picked up an original automatic crossmember a while back and will use that instead. ....
06-29-2020, 07:06 PM | #10 |
Re: T-5 swap time
Hey - diefinitely following this - I may want to do this also.
What is the ratio of your rear differential?
1963 C20, small window, long bed 292, 4-speed |
06-29-2020, 07:50 PM | #11 |
Re: T-5 swap time
Though a little painful this go round considering you mentioned you don't have a hoist, but why not remove the bellhousing and replace it with a stock GM truck bell with the open bottom so you don't have to a) go thru this again every time you replace the clutch and/or b) hack up the original mounts? They work fine without an original bell housing and no rear trans support is required. Old bellhousings are a dime a dozen - but you would need to ensure you grab one with the correct index ring diameter (or also buy an index ring adapter, additional cost - but since you'd be shopping, you can choose wisely 1st time out). Just a thought.
Glad you are getting around to this upgrade, you'll be very happy with it - it's been a while since I posted this thread, but sharing in case you might learn from some of my mistakes! |
06-29-2020, 11:39 PM | #12 | |
Re: T-5 swap time
the trans has a 2.95 first with a .63 od and I am Running 3.73 out back so it should be a nice combo. Captain fab Thanks for the insite Jocko I have your T5 post saved great write up So I have to sit and think about my choices..... I can: A) Cut the Aluminum bell housing off and use the super rare( lol) 1960-62 V-8 1/2 bellhousing with the the slave cylinder on the passenger side , source a new starter fab up a new clutch hose and hope that bell mounts line up. B) Cut the whole crossmember off and keep the full aluminum bell that is on there now This would allow me to keep what I have .starter and hydraulic clutch set up on the driverside. I have two automatic crossmembers an original 60-62 and a custom made one. they both are about 4 inches short of where the T-5 tail mount is, and I would have to address the offset Camaro trans mount. C) Trim the crossmember ( sort of like pancaking a front crossmember) and follow the same steps as above
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 06-30-2020 at 12:26 AM. |
06-30-2020, 10:17 AM | #13 |
Re: T-5 swap time
If you put a jack under the oil pan of your engine (using a block of wood to protect the pan, of course) and leaving the engine bolted to the motor mounts, can you raise the rear of the engine enough (essentially tipping the engine forward) to give enough clearance to get that bellhousing out of there?
06-30-2020, 11:13 AM | #14 | |
Re: T-5 swap time
I was able to talk to the previous owner ( my old boss) and he said when he put the 250 he did it with the tranny installed.. sort of explains why it wont clear. The good thing is that I am in no big rush...
06-30-2020, 10:07 PM | #15 |
60-66 Nut
Re: T-5 swap time
So the trans crossmember that was under the rear of the 3 speed won't work? Can it be modified to work?
06-30-2020, 11:32 PM | #16 | |
Re: T-5 swap time
Question for you Captain: The 1/2 bell I have has threads on the mounting flanges.If I go that route do I just thread a bolt from the bottom of the crossmember into the bell? Thanks in advance
07-01-2020, 11:14 AM | #17 |
Re: T-5 swap time
Here is a recent discussion on the mounts in question
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-01-2020, 01:02 PM | #18 | |
Re: T-5 swap time
07-01-2020, 10:22 PM | #19 | |
60-66 Nut
Re: T-5 swap time
You mean to tell me that the PO did away with the original bellhousing which supports the rear of the engine and the trans, installed a standard bellhousing and did not install a transmission mount under the rear of the transmission? What was holding up the trans and the rear of the engine and keeping everything stable? Just from the look of the picture, if you do back to the original style bellhousing, you will have to move the engine back as well. You will need the correct mounts between the bellhousing and the cro9ssmember and also the rubber cushions up inside the crossmember which the bolts pass thru. Personally, I would cut the bellhousing crossmember out and put a rear trans mount in place. If you need help with the crossmember, let me know.
07-01-2020, 11:14 PM | #20 |
Re: T-5 swap time
Thanks Captain.... I will most likely be asking !!! Sorry .. there was no crossmember at the rear of the old 3 speed. The po used these brackets ( been on there for the last 15+years) mounted on the stock crossmember .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 07-01-2020 at 11:27 PM. |
07-01-2020, 11:23 PM | #21 |
Re: T-5 swap time
This is the " rare" 1960 bellhousing
07-02-2020, 09:58 PM | #22 |
60-66 Nut
Re: T-5 swap time
OK, so there was at least some sort of support back there.
07-03-2020, 06:32 PM | #23 |
Re: T-5 swap time
Well I got it off !!!
I removed the clutch with the bell on . I used the throw out fork hole rotating it to get the pressure plate bolts off. The disc slid out but not the P/plate. Out came the cut off wheel . I trimmed about an inch off of the bottom of the bell and out it came. I test fit the original bell and it will work Used my impact gun on the flywheel and then it happened big time bone head move. The fly wheel was stuck so I gave it a good tug and off it came smashing my fingers . Ahh the fun of working in your drive way!!
07-05-2020, 04:55 PM | #24 |
Hollister, CA.
Re: T-5 swap time
Whats up Sal !!!!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-05-2020, 07:28 PM | #25 |
Re: T-5 swap time
