Old 07-20-2020, 09:23 PM   #1
Old Radio Tech
beads and seals
65 Suburban
inner fender to firewall seal - the slot in the seal is thicker on one side. Thicker toward the engine compartment or the wheel well?
Body to fender Bead (inner to outer fender seal) - bead up and between the mating overlaps (inside) or down and to the outside (wheel well) ?
Pictures for both questions?
Paul
Old Radio Tech is offline   Reply With Quote
Old 07-21-2020, 07:50 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: beads and seals
Here's a really good thread with pictures: http://67-72chevytrucks.com/vboard/s...d.php?t=512162
Old 07-21-2020, 10:27 AM   #3
Old Radio Tech
Re: beads and seals
Lots of pics of closing panels, but not much on inner fender to firewall or inner fender to outer fender. Saw a mention of a seal between the inner fender and the radiator support. Anyone have any info on that?
Old 07-21-2020, 10:33 AM   #4
The Rocknrod
Moderator
Re: beads and seals
Inner fender to firewall seal - http://www.usa1industries.com/1960-6...set.html?&cat=
Picture #3 - http://67-72chevytrucks.com/vboard/s...67&postcount=2
On the dust seals in front Post #19 - http://67-72chevytrucks.com/vboard/s...d.php?t=623201
Old 07-21-2020, 10:56 AM   #5
roll_the_dice
roll_the_dice's Avatar
Re: beads and seals
Originally Posted by The Rocknrod View Post
Good info! Thanks, I am about ready to install my inner fenders and needed these as well to double check my own memory. I have all the rubber I think!
roll_the_dice is offline   Reply With Quote
Old 07-21-2020, 11:38 AM   #6
Old Radio Tech
Re: beads and seals
I have all the seals. I'm looking for info on installation. Those pics show the closing panel and the rear fender support. The only pic that shows any of the inner fender to firewall seal is the one that shows the steering boot. In that pic you can see the slot and loop in the seal. The rubber in the slot is thicker on one side than the other. Trying to find out whether the thicker side goes toward the engine compartment or the wheel well. No pics yet of the seal between the inner and outer fender. It has a bead in it. Trying to find out whether the bead goes on the engine compartment side or the wheel well side.
Old 07-21-2020, 11:49 AM   #7
roll_the_dice
Re: beads and seals
I just looked at my inner fender seal and it is the same thickness on both sides of the split.
Here is a picture I just took.
Old 07-21-2020, 11:59 AM   #8
Old Radio Tech
Re: beads and seals
Thanks Roll the Dice. Must be a manufacturing thing. Any info on inner to outer fender seal/bead?
Old 07-21-2020, 12:32 PM   #9
roll_the_dice
Re: beads and seals
I can't find any information on inner fender to outer fender bead. I haven't seen anything other than what has been shown in the other threads. When I was looking at my inner fender, I only saw staple holes near the firewall on the inner fender. So in my mind, the only other seals are on the outer fender. Except where does #6 go?
Old 07-21-2020, 12:35 PM   #10
roll_the_dice
Re: beads and seals
I just found this post...says #6 is "as needed" Whatever that means. I don't remember seeing anything like that on my truck.
http://67-72chevytrucks.com/vboard/s...80&postcount=3
Old 07-21-2020, 12:37 PM   #11
Old Radio Tech
Re: beads and seals
That's the one. Goes along the outer lip of the inner fender where the outer and inner fender lips meet and overlap My truck had many seals missing so I had nothing to go on.
Old 07-21-2020, 12:41 PM   #12
roll_the_dice
Re: beads and seals
And the bolts on top that hold the fender on holds the seal on?
Old 07-21-2020, 03:10 PM   #13
roll_the_dice
Re: beads and seals
Paul...I found some pictures that I think will be helpful to both of us. I was searching another project and saw this post...You can see the inner fender to firewall gasket and you can also see the gasket from inner fender to outer fender in the 2nd picture bottom right...makes more sense now!
http://67-72chevytrucks.com/vboard/s...67&postcount=9
Old 07-21-2020, 04:50 PM   #14
Old Radio Tech
Re: beads and seals
Thank You. That answers the question on the bead. It looks as though the
bead will need to round the corner of the inner fender lip so the last little upturn of the outer fender rests on the bottom edge of the bead. It doesn't appear to be compressed at all between the two. I think I'll put a little RTV along there and alone the edge of the two in the wheel well.
Old 07-21-2020, 04:53 PM   #15
Old Radio Tech
Re: beads and seals
yes on the bolts.
Old 07-21-2020, 04:55 PM   #16
roll_the_dice
Re: beads and seals
Great! Now, I was looking closer...does gasket go here also where the red arrow is against the radiator support? I don't think so, but not sure.
Old 07-21-2020, 05:52 PM   #17
cwcarpenter98
cwcarpenter98's Avatar
Re: beads and seals
I have seen replacement seals for sale for there, but I didn't end up buying them for my truck since I was trying to get it back together quickly
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-21-2020, 09:29 PM   #18
roll_the_dice
Re: beads and seals
Do you remember where you saw them?
Old 07-21-2020, 09:41 PM   #19
cwcarpenter98
Re: beads and seals
There's a complete set of inner fender to outer fender seals on page 94 of the truckandcarshop catalogue. Also saw the same kit at Classic Parts.
Classic Industries has the pieces for the inner to outer fender and inner to core support without having to buy the outer fender to cab seals if you already have those
Christian Carpenter
Old 07-21-2020, 10:35 PM   #20
roll_the_dice
Re: beads and seals
Thanks Christian...got some stuff ordered from Classic Industries. I already had some of the seals, so I got the front inner fender gaskets and a few other odds and ends. Much appreciated!
Old 07-22-2020, 02:38 AM   #21
Old Radio Tech
Re: beads and seals
So what's the consensus. Is there a seal between the inner fender and the radiator support(core support) and what does it look like? The inner to outer fender bead type seal? Seems like all of these seals will affect the shims needed to make things fit right.
Old 07-22-2020, 08:32 AM   #22
The Rocknrod
Moderator
Re: beads and seals
Old 07-22-2020, 09:02 AM   #23
roll_the_dice
Re: beads and seals
I couldn't find much on them and didn't see anyone sell them separately, but I ended up buying these. I am not sure most people use them. They were not on my truck when I disassembled, but neither were several seals/gaskets.
https://www.classicindustries.com/pr...rts/ct146.html
Old 07-22-2020, 09:21 AM   #24
cwcarpenter98
Re: beads and seals
Sure thing! I ended up not using them on mine, but when I do my full restoration, I will.
Yes, I believe there was. When I took my front end apart, I noticed a heavily deteriorated seal-like material where the inner fender bolts to the core support. I ended up not putting a seal back, so if you don't want to, you don't have to, but apparently, the factory did it
Christian Carpenter
Old 07-22-2020, 09:37 AM   #25
Old Radio Tech
Re: beads and seals
The bead seal came in a 25' roll, much more than is needed along the top of the fenders. Bead in or bead out?
