08-26-2020, 09:23 PM | #1 |
Stock tires
anyone know stock tire size for a 86 c10 .... rlms are 15 x 7 ?
85 Silverado LWB Fleetside 383 Stroker 86 Custom Deluxe SWB, Pro Street LSX |
08-26-2020, 10:15 PM | #2 |
Re: Stock tires
08-26-2020, 11:02 PM | #3 |
Re: Stock tires
Cool thanks
08-27-2020, 04:42 PM | #4 |
Re: Stock tires
I don't know exactly what came on them in 1986, but it seems like my 1980 K/10 had something like H78-15.
So those tire rack options could be replacement tire sizes. I had P225/70R15 on my Jeep and when I ruined one this year they couldn't get a replacement. So they "gave" me four LT235/75R15 under warranty, but I had to pay for a new spare along with mounting and new warranty. Nice upgrade except they rub on the lower control arms on a tight turn.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
08-27-2020, 10:54 PM | #5 |
Re: Stock tires
I ordered 2 235/75R15 tires now I need 4 15x8 rims. I could only find a 15x7 at the junk yard for 85 bucks and it was White. No one has inexpensive wheel on line.
08-28-2020, 08:11 AM | #6 |
Re: Stock tires
You don’t need 8 inch rims for 235 tires.
I assume that’s what you’re thinking. |
08-28-2020, 08:54 AM | #7 |
Re: Stock tires
I removed the spare that's been under my 85 silverado for 30 years and the rim was 8" and it looks like the stock rim, But the rim was rusted too bad from water getting inside because it was Flat for years I guess.
Is there a Off Set for square body trucks?
08-28-2020, 10:20 AM | #8 |
Re: Stock tires
The stock 15x7’s on my 84 were 4 inch backspacing. No offset.
15x8’s are usually same backspace but would have an offset of 1 inch. I used some newer ss454 rims on my 84. They were 15x7 with 4 inch bs. |
08-29-2020, 04:26 AM | #9 |
Re: Stock tires
My 86 came with 15x7 with 225/75 x15, bought it brand new in 86
08-29-2020, 08:28 AM | #10 |
Re: Stock tires
15 X 6 on my 87 R10
Desert |
08-29-2020, 11:30 AM | #11 |
Re: Stock tires
I talked to the original owned he said the spare is one of the original wheels They sure look alot bigger than the 7" rim.
08-29-2020, 11:54 AM | #12 |
Re: Stock tires
15x8's where around as well.
08-29-2020, 12:19 PM | #13 |
Re: Stock tires
Those are Factory 15x8 5x5 bolt space Rally. I be leave they make reproduction rims that was few yr back now. 15x7 where mostly the norm as 15x8 was a option up grade. Unless dealer order that that way to sell. Try board members or locals car & truck club e-bay or other local parts in your area. Spare were Black, but must of wheel set where gray or sliver the Rally's. There starting to be had to find good OEM set now. A lot set now pretty rusty need to sand blasted a lot to clean them lots time/work to them looking good again. There is marking on the rim on the face near the valve or the back not to far away valve if the rust is not thick or there not to much paint on the rims say 15x8 or 15x7 or 15x6 some time there under the tire tread.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
08-30-2020, 07:56 AM | #14 |
Re: Stock tires
Most with factory steel wheels, which I think were 6 or 6.5 inch wide came with FR78 for the size. Depending on who's scale you look at, it is normally a 205/78x15 for the size. Most folks run the 225 or 235 in 75 series which is just a hair taller, which is about the size when they used the 8" wide rally wheels.( GR78 I believe for back then)
08-30-2020, 09:08 AM | #15 |
Re: Stock tires
The spare is a rally wheel . I bought a set from Specialk for my burban ,sold the burban same day I picked up the rims . Staggered set 15x7 and 15x8 most likely going on my 68 when I convert to disc and 5 lug
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-30-2020, 10:09 AM | #16 |
Re: Stock tires
Found a photo from when I bought the truck. Wish I still had the wheels.
08-31-2020, 07:17 PM | #17 |
Re: Stock tires
A break downhttps://tireguides.com/TireTips/TireDocument/4
08-31-2020, 07:49 PM | #18 |
Just here to tinker
Re: Stock tires
My '86 suburban came with factory 8" rally's and P235/75R15XL tires. I assume that XL back in the day is the predecessor to LT tires today.
SPID attached showing the option.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
09-01-2020, 11:16 AM | #19 |
I'm just glad to be here!
Re: Stock tires
The 86 I just bought shows a P195/75R15 as the stock tire size on the SPID. Pretty sure the stock rims for these where 15"x5.5" with a 10.125" hub cap. Those are missing now from the truck. But I have a full set I can put on if I decide to go that way.
The truck has either 225 or 235 75R15's on it now with '88 up style truck rally wheels also missing the center caps and trim rings..
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-01-2020, 01:58 PM | #20 | |
Re: Stock tires
We were running 7.00-15 6 ply truck tires on our half ton way back in the 1960s (after the piss poor passenger tires that it came with blew out).
09-01-2020, 03:15 PM | #21 |
Re: Stock tires
09-01-2020, 03:19 PM | #22 |
Re: Stock tires
GM did not make 8" wide wheel after 87....widest 15 are the 7" alloys. Steels I believe were all 6.5 (on the 1500 models)
09-01-2020, 04:34 PM | #23 |
Re: Stock tires
i have only seen 7" or 8" wide on the trucks my self up here in the north east . i have prob 2 full sets of decent 15x8" GM rims .
i just started doing up rims for my c-10 short bed build . i did 2 6.5" from a G-series van for the front with 235/70/15 and 255/70/15 rear on 8" wide and it gives it a nice staggered look . here is the look i have going and last pic of the center cap and lug cover combo i picked . and fyi my whole truck is down 2.5" from stock height . just to give you a size reference .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-02-2020, 01:54 AM | #24 | |
Re: Stock tires
09-02-2020, 08:02 AM | #25 |
Moderator
Re: Stock tires
I always ran 235/75R15's on the 1/2 tons and 265/75R16 on the 3/4 tons.
Most of my 1/2 tons came with 215/75R15's and 245/75R16's on the 3/4 tons. IIRC I ran 235's on my 1968 IH Scout 800 back in the 80's with no issues.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
