Old 01-19-2021, 03:51 PM   #1
Asshat
Asshat's Avatar
Re: Front suspension and steering questions
Do those springs look too collapsed with the truck just sitting on the ground?
And, will 1/2 ton springs work on a 3/4 ton truck? I am not planning on carrying heavy loads, just normal driving around town.
The Truck and Car Shop in Orange only lists springs for 1/2 ton pickups.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 01-19-2021, 04:03 PM   #2
SCOTI
SCOTI's Avatar
Originally Posted by Asshat View Post
1) Do those springs look too collapsed with the truck just sitting on the ground?
2)And, will 1/2 ton springs work on a 3/4 ton truck? I am not planning on carrying heavy loads, just normal driving around town.
1) Yes, they do.
2) Yes, they do.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-19-2021, 05:41 PM   #3
bigmoe
bigmoe's Avatar
Those springs do look pretty collapsed. I'd be worried it would sit too high if you bought new stock springs. A lot of guys (including me) use 97-06 Jeep TJ rear coils as drop coils on 1/2 tons. (ACDelco 45H2104)
bigmoe is offline   Reply With Quote
Old 01-19-2021, 06:03 PM   #4
Asshat
Asshat's Avatar
What drop do these provide for a C10 pickup?
2” maybe??
292, 4-speed
Old 01-19-2021, 06:22 PM   #5
bigmoe
bigmoe's Avatar
4" I believe. And I see in my notes the ACDelco 45H2104 is a 653lb variable spring.
Old 01-19-2021, 08:21 PM   #6
Asshat
Asshat's Avatar
I think I’m just going to go down to the Truck Shop and see if they have the 2” or 3” drop springs for the rear. At least those will fit and all I have to do is get the right drop. The Jeep springs are not a sure thing, and if they are 4” drop that’s probably too much for what I want.
292, 4-speed
Old 01-22-2021, 10:42 PM   #7
Asshat
Asshat's Avatar
I installed stock height, new coil springs in the back and got a new track arm (pan hard bar). I think it sits more level than before. Rides a lot better too. Next step is to replace the front springs and ball joints.
Also going to list some 2” drop springs; these did not work out for me. Couldn’t get the wheels mounted, tires a bit too wide.
292, 4-speed
Old 01-23-2021, 12:54 PM   #8
bigmoe
bigmoe's Avatar
I have a similar problem (made even worse because the short box has a smaller wheel opening). Solved it by jacking the truck up by the frame so the suspension is in full droop. That gives room to remove/replace the tire.
Old 01-23-2021, 12:23 AM   #9
cwcarpenter98
cwcarpenter98's Avatar
How's your cab and core support mounts lookin? If they are blown out, that could also make it look like it's leaning
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-29-2021, 07:27 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
Looking at the a-arm space when seeing the front of the truck, that's what I'd look at also.
Old 07-28-2021, 10:54 PM   #11
Asshat
Asshat's Avatar
Well, the truck is still leaning to the driver side. Measured at the rear bumper it is 1-1/2" lower on the driver side. I may need to jack it up at the frame and loosen the springs and see if I can rotate them to get it to sit evenly.
Maybe that will work.
292, 4-speed
