#1 | |
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
#2 | |
There are two styles of rims. One is hubcentric and some use the lug you pictures. Some are lug centric and lugcentric used the cone styl lug nuts he had. Where the problem here is that mag wheels sheld be retorqued after 50-100 miles. A seccond problem peopl have is when the swich to a different rim the fail to clean the hub and bolt the rim on a uneven surface that is often rust covered. WHen the rust breaks up then the wheel is loose. You loose a few lug nuts and the wheel starts to wobble and snaps off some of the wheel studs......JUST like what your pictures show. Check and make sure you rim isn't bent and if the lug holes are wollowed out you might not want to use that rim.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#3 | |
i love summertime
Lol John, Someone Finally Agrees!!!
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
I need another Barley Pop
Well, I hope dinnut got his problem resolved. cdowns, I agree with you to some degree (on a previous post) that oversized (wide) rims and major offset do put extra stress on the wheel studs but this is not the problem he is having. My rims are 14" wide and my truck is a daily driver. 2 1/2 years after installing my lift, wheels & tires, I have never had a wheel stud problem and as far as I know, the wheel studs on my truck are original 67. I don't mean to single anyone out about advise given, but let's think about what we are telling someone before we post. I don't always have the money to shop and replace parts by trial and error and I'm sure others don't either.
Overall, I think that all the advise was good and gave dinnut something to think about. I wouldn't be eager however, to suggest that he needs to run a narrower wheel to solve the problem.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
There is nothing like the human touch. I use my impact wrench to remove the the lugnuts, but I ALWAYS tighten then by hand.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
you people with the theiven loose lugnut theory have you really looked at the pictures?? to me i see he has 7/16 studs and the holes in the rims that the studs go thru appear to be at least 11/16inch maybe 3/4inch and by using the wrong lugnuts added to by the pressure of the severe offset of the rims THAT's THE PROBLEM and the cause of the stud failure and the possiblally destroyed rims
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Bummer !!!!! Gotta get the right lugnut's !!!!
The first thing I would do is be thankful It didn't happen while driving 55 down the highway. Then, I would probably take it to a local wheel/tire dealer and get a bit of expert advice on the situation. They probably wouldn't even charge you just to tell you what they think the problem/solution would be. Lots of good advice on the board, but you need to have someone that can look at it in person.
i think some of you guys saw the pics of dinnut's Benz...ever think that a little rougher than normal driving caused this? To me, seeing the pics of the Benz now this, I think that we are qualified to have a laugh at this situation.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
When I first bought my Cragar s/s wheels, the lug nuts that came with them were for a late model Chevy truck. They were for 14-mm studs. My '72 Cheyenne has 1/2"-20's. I couldn't find any tire shops in town that had anyone that had any idea what I needed. One custom wheel store sold me some nuts that were the proper size but the "shank" was too long. I even ruined a couple of the studs by using nuts that were too long and tightened them too tight and broke the studs right off. I even considered using two washers. Really bad idea. I thought I had made a big mistake even trying to use the Cragars. I was very discouraged at that point. So I turned to e-bay. That's right, e-bay. Sounds weird but I contacted this person and asked a few questions about the lug nuts they were selling. Turns out that the seller was a custom wheel shop in Oklahoma that really knew their stuff when it came to lug nuts. After several e-mails, they were able to tell me exactly what I had to have to make the wheels fit properly. I think it cost me about $ 40.00 for the proper lug nuts. And, I had to add 7/16" spacers behind the wheels because the nuts are all too long. They don't make the 1/2"-20 nuts in the correct length for the '72 Chevy studs. I would reccommend that you contact them. They were VERY helpful and extremely knowledgable. I know they sure knew alot more than I did!
Massey's Accessory Shop, 1319 S. Robinson, Okla. City, OK 73109. Phone--405-239-2010 By the way, the pictures look like you do need what is called a "Duplex" style lug nut. See, I actually learned something about wheels through my experience. So, in a way, I guess it turned out to be a good thing (in the end) Sorry so long, and good luck! Hang in there! TP ![]() |
Pennyless Fool
I don't get the problem here? Dinnut knows it's all n fun, just means we all like the guy. I've had to live down alot of things in life. Some will probably be remmembered long after I'm gone, that is if anyone cares. The problem, cure, and future prevention have all been addressed. How many times have we all had to live down things similar between our buds? They wouldnt be our friends if they didn't care enough to rib us like this, come on. Lighten up a little.
Hey Dinnut, Believe it or not, Pep Boys carries a line of Ralley/Rallie (sp?) lug nuts. I'm pretty sure they will have them.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
my observation is somebody posting 6responces in big capital letters without one suggestion on what to do to cure a serious problem
HOW DOES THIS HELP??
![]() Join Date: Dec 2001
http://67-72chevytrucks.com/vboard/s....php3?t=109736
I'm sure dinnut takes good care of all of his vehicles. How could any of you guys think differently? ![]()
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#15 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 07-15-2004 at 03:43 PM. |
#16 |
wow i forgot about this post and it turned into one big arguement... and i do take care of the truck... and the mercedes i dont really care about i got new tires and i take care of it now... im going to try to sell it to fix up the truck....
and about the rims. i didnt buy the rims or the lugnuts.. they were put on the previous owner and im going to try to find the correct lugnuts for them i want to correct this situation and im no hack like yall are trying to say i have to go but ill finish replying later
70 longbed 496/th400/Ford 9" |
#17 |
2 of the studs are bent so i cant get my custom rims back on because of the tight clearances w/ the lug nuts so im going to have to get 3 new studs but might as well get all 6 while were in there. till then im going to run it with the mini spare. hehe 205/65/15s do NOT look good on these trucks. the pics i took make it look a dragster with the big and the little....
and yes the truck was only driven in my yard.... we do not have insurance, and it is not inspected so if yall are trying so its because i drive hard. how fast can i drive in my driveway.... 10mph MAX? im goign to get the correct lug nuts all 24 of them...... and im going to fix the mismatched lugs the previous owner put on.... im no hack... and the mercedes im tryign to sell i completely replaced the stereo system and we fixed the a/c and put a new waterpump on it... oh yeah and i thought it was hilarious the way the wheel came off. i was laughing and very upset at the same time and i was really was just driving up and down the driveway.....
#18 | |
#19 |
![]() Join Date: Sep 2001
I'd bet money they were loose. Maybe forgot to tighten one wheel down after a tire rotation or something... if they WERE loose you'd definately snap the studs (happened to me too). If there were loose, the added offset would be a significant factor. If they were tightned down, I'm not sure it would be such a factor.
Nice truck, by the way! Last edited by guyryan100; 07-19-2004 at 08:53 PM. |
#20 |
i love summertime
john i still think its funny too
#21 |
fixed it today. put 6 new studs in the front just to be safe and i put 1 in the rear where one was broken off a while ago (previous owner was a crackhead) i drove it today and the valve seals have leaked so bad my expensive bosch 4 tip platinum plugs are BLACK as can be once again in going to have to clean them up and put them back in...
oh yeah i got new lug nuts for the whole right side of the truck. ineed to buy some more to finish up the left side....
