Old 01-14-2022, 11:09 AM   #1
Braunschweiger
A '62 has to get back on the road
Hello, I bought this '62 C10 with 350/350,
it has power steering and power brake.
Unfortunately, the sheet metal is in very poor condition
and needs attention. I've been reading this great forum
for a long time and I want to take this opportunity
to thank everyone who helped me with their reports.
I'll start:
There it is my new truck, the usual disassembly and all
for sandblasting
Braunschweiger is offline   Reply With Quote
Old 01-14-2022, 11:13 AM   #2
Braunschweiger
Re: A '62 has to get back on the road
After sandblasting, all the holes showed up.
Old 01-14-2022, 11:25 AM   #3
Braunschweiger
Let's move on, the corner of the roof
is the beginning.
And it was made out of 4 parts.
Roof, Gutterwall and Gutterfloor.
I hope the technical terms are correct.
The front edge of the roof also had to give way.
Old 01-14-2022, 11:37 AM   #4
Braunschweiger
New sheet metal must be installed inside and outside above
the windscreen and on the passenger side above the door.
Recreating the inner post corner was very complicated,
I don't want to do it again
Old 01-14-2022, 01:01 PM   #5
Braunschweiger
The outer panel fitted, unfortunately it is
almost 1/2" too short, so adjust it.
A little Bondo is necessary.
That looks better.
Old 01-14-2022, 01:04 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Wow, your definitely putting your time in on that unit.
Old 01-14-2022, 01:26 PM   #7
Braunschweiger
I've been retired for a while.
I didn't want to just look out the window
and am now rebuilding this beautiful
piece of American history.
Old 01-14-2022, 05:28 PM   #8
cwcarpenter98
cwcarpenter98's Avatar
I like the stance before you tore it down. Will you be keeping it that way?
Great job on the repairs too. That rust was extensive
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-15-2022, 03:22 AM   #9
Braunschweiger
Yes, the truck gets a 63 front axle with 2.5" drop spindles
and 2" dropped springs, the torsion keys have already hit hard.
Closed a hole on the right side of the post,
opened the airvents to close the holes
Old 01-15-2022, 03:26 AM   #10
Braunschweiger
Airvent closed again, that was necessary
on both sides.
Old 01-15-2022, 11:06 AM   #11
Braunschweiger
The floor has to be completely renewed,
first build a support and cut out the rusty part,
not much is left.
Old 01-15-2022, 11:10 AM   #12
Braunschweiger
On the other Side, same Play
Old 01-15-2022, 11:19 AM   #13
Braunschweiger
The supports came out again,
the floor is okay now.
Old 01-15-2022, 03:48 PM   #14
plainred65
plainred65's Avatar
Following along, love the stance of your truck. I always enjoy watching sheet metal work done well.
plainred65 is offline   Reply With Quote
Old 01-16-2022, 03:54 AM   #15
Braunschweiger
Thank you, I'll do my best.
Old 01-16-2022, 06:38 AM   #16
Braunschweiger
The frame above the driver's door also had to be replaced,
as did the corner of the roof, and patches were also put in on
the rear window.
Reinforcements for the belts have been placed
Old 01-16-2022, 06:48 AM   #17
Braunschweiger
Grind the welds on the floor and make a deflector plate
for the DeLuxe heater.
Eliminate dents on the back wall.
Old 01-16-2022, 07:00 AM   #18
Braunschweiger
The holder closed with a patch, more belt reinforcements set,
the cabin is patched, now we continue with the doors
Old 01-16-2022, 08:39 AM   #19
Grizz1963
Grizz1963's Avatar
That is an awesome job you are doing.
Very brave in places.
Well done.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-16-2022, 10:40 AM   #20
Braunschweiger
Thanks for the encouragement.
Old 01-17-2022, 12:55 AM   #21
TxCajun
TxCajun's Avatar
Very nice work on the rust and dent repairs!
I've been working a lot of the same issues for the past two years. Hope to finally start bodywork and paint soon.
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 01-17-2022, 02:23 AM   #22
Braunschweiger
Thanks for your words, I've been following your project build
as have many here, you've shown me the way.
Old 01-17-2022, 02:42 AM   #23
Braunschweiger
After disassembling the doors, they were sandblasted,
the door bottoms and the outer skin were already badly damaged,
the truck must have had a hard life,
so first a new door bottom was put in,
then the outer skin was removed and the inside
(The second picture shows the passenger side, which was also added)
was painted with epoxy, the new outer skin got the door handle
reinforcement from the old outer skin,
installed and aligned the whole thing as a test.
Old 01-17-2022, 03:00 AM   #24
Braunschweiger
The outer panel was held in position with self-tapping screws
and spot welds and reinstalled to check the gaps and
then flanged the edges and reinstalled to check everything
after that the long weld, step by step welded.
What else did I do..... the rearview mirror mounting holes
were wrong, too far forward and have been corrected.
Old 01-17-2022, 11:15 AM   #25
DPowers
One foot in front of the other
DPowers's Avatar
Very nice work.
DPowers is offline   Reply With Quote
