01-30-2022, 09:56 PM | #1 |
Dummy Filler Neck/Tank Delete for 67-72 Trucks with Removed In-Cab Tank
12/14/2024 Update - I have dummy filler necks in stock.
I can be reached at dummyfillernecks@gmail.com or send me a PM. *******PRICING******* Standard Unit $120 + $10.40 USPS Flat Rate Shipping Accepted payment methods: Zelle, CashApp or Money Order ******************** Here's a video that shows the filler neck on my truck. This is a blank filler neck that fills the hole left behind in the cab when the stock tank is eliminated, allowing you to retain the original look, and avoids the need to patch and repaint the cab. The parts have been sprayed with two-part epoxy satin black paint. Included in the kit: -Filler neck, shortened, 2-1/4" diameter -Clamping Plate -Cab grommet, 67-70 style (fits 71-72 cabs as well), made in USA -Pan-head screws for clamping plate -Pan-head screws for increased clamping (not usually necessary) Installation instructions can be found here. Note: you will need to provide your own 67-70 non-EEC gas cap, such as Stant 10623 available at O'Reilly for $9. I got my cap from GMCPauls. EDIT - Member D.B successfully used an OE 71-72 grommet with his dummy filler neck. EDIT2 - 71-72 caps do work after all. As an option, the clamping plate is designed to have an AC power outlet connected to it for people who have an inverter in their truck and want a convenient way to plug external items into it. It's designed to work with Journeyman Pro HJP-5279 (not included). In order to install the outlet, a blanking plug must be removed from the clamping plate (drilling required), and the two mounting holes must be tapped to #8-32. Also, the four clamping plate screw holes must have 100° countersinks added so that 100° flat head screws can be used (not provided). Instructions can be found here. Overall, I am pleased with the way these dummy filler necks turned out, and I am picky. Please note though that there are some minor cosmetic flaws such as small lumps from the brazing done on the original filler necks I purchased. Some of the welds inside the filler neck are not as clean as others, but the welds are completely hidden inside and are fully functional. There are a few very minor thin spots in the paint as well as the occasional slight orange peel, but the portion that shows from the outside of the truck is very nice. It isn't possible to get complete paint coverage on the inside of the filler neck due to the shape of the opening. Also, please note that I tested the design on my truck, and it fit quite well. There could be variations from one truck to the next that might influence how snugly the dummy filler neck fits in the grommet. Included are four jacking screws that will allow the fit to be tightened up, if necessary. Photos of latest dummy filler necks, 11/18/24 Last edited by pjmoreland; 12-14-2024 at 11:08 PM. |
01-30-2022, 10:22 PM | #2 |
Re: Dummy Filler Neck for 67-72 Trucks with Removed In-Cab Tank
I will get my payment out via USPS cashiers money order.
01-30-2022, 10:24 PM | #3 |
01-30-2022, 10:42 PM | #4 |
At the body shop.
What's your paypal address?
Might get me motivated on removing the cab tank.
" That didnt make it any newer " " Dont antique the equipment " |
01-30-2022, 10:56 PM | #5 |
01-30-2022, 11:58 PM | #6 |
I’m in, send me your payment info
Posted via Mobile Device |
01-31-2022, 04:34 AM | #7 |
Hi Patrick.They look fantastic. I’m in for one. I’ll send you payment through PayPal later today. Dan
01-31-2022, 08:51 AM | #8 |
Yep, I'm in.
01-31-2022, 09:03 AM | #9 |
I'll get a USPS Money order out to you when i get your address. Thank you .
01-31-2022, 09:24 AM | #10 |
Sign Me Up!!!!!
PM me your Paypal info. Thanks
The older I get the less BS I have to put up with...…. |
01-31-2022, 11:08 AM | #11 |
01-31-2022, 11:52 AM | #12 |
01-31-2022, 12:03 PM | #13 |
I'm in. Perfect timing.
I recently pulled the in cab tank and just got my Boyd remote tank mounted. Please send PM. PayPal, Venmo or Zelle?
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
01-31-2022, 12:04 PM | #14 |
I'm in send me your PayPal please and I'll have it right over.
01-31-2022, 12:23 PM | #15 |
Not sure where I sit in line. Please send me Venmo or PayPal payment info if I'm on the current list.
Thank you!! Deron
1970 Stock SWB C10 without A/C 1970 Stock LWB C10 CST with Factory A/C |
01-31-2022, 12:24 PM | #16 |
Payment Sent!
I may have missed it above, but can you tell me which 110v outlet will fit the knock out opening?
01-31-2022, 12:26 PM | #17 |
01-31-2022, 12:26 PM | #18 |
Disregard my last, I actually can read. I see I'm number 5. Let me know where to send PayPal payment and I'll do it ASAP.
Thanks again!
01-31-2022, 02:30 PM | #19 |
I still want it. Please send me paypal address and I will get you money ASAP.
01-31-2022, 05:35 PM | #20 |
Junior Member
I'm in at #20. Also, I'll take the handmade if no others are interested.
01-31-2022, 05:36 PM | #21 |
Hey Patrick,Payment has been sent.Thanks for making these. They are really trick. ( I haven’t used that word in awhile, but it really fits.) Dan
01-31-2022, 05:40 PM | #22 |
01-31-2022, 09:50 PM | #23 |
Super! Let me send you a PM on info.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
01-31-2022, 11:28 PM | #24 |
Patrick looks like another 15 wouldn't hurt. I had to push you for the first run I will motivate you for the second run. The list for a second go around looks good now and it will grow before they are finished. If your only making 11 can you serialize them in case they become collector piece in the future? I think I was lucky number #01 and would like it sent in a nicely hand crafted silk lined box. Lol
Thanks for taking on the project. Chad |
02-01-2022, 08:25 AM | #25 |
GM Addicted
I would like one
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
