Old 10-25-2023, 08:39 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Roller Lifter ?
While I have an LS in my truck I’m more old school and not really up on them
When looking at Cams they don’t offer cam and lifters like a flat tappet cam. I’ve hear it doesn’t matter cam to cam or order of Roller Lifters due to them being 1 Roller and 2 Hardened Can someone enlighten me a bit. Looking at new Cams and want to know if I can use my old lifters. Not having any problems with them just want more Cam
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-25-2023, 08:50 PM   #2
LS short box
Re: Roller Lifter ?
In regards to lifters I've reused the stock lifters on my LS swaps. But and it's a big but on my LS swap engines have always been low mileage engines. 25K or less.
Trouble is the LS7 lifters have gotten a bit pricey. I wouldn't run anything else.
If you are going with a cam bigger than stock get better valve springs and lifters.
Old 10-25-2023, 09:54 PM   #3
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
Looking at Trick Flow Cam and Head Combo. It comes with Roller Rockers but no lifters. My LS1 only has ~50,000 original miles. New Cam lift is 585/585 so while not Hugh its up there and matched to the heads. Being Old School I always go with new lifters with new cam. They do offer Stock replacement lifters for under $300
You mentioned LS7 lifters, are they supposed to be better and be used in LS1?.
I don’t mind the $ if it’s worth it
Pittsburg Ca
94565
Old 10-25-2023, 11:26 PM   #4
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
LS7 Roller Lifter part # 12499225 on Amazon for less than $100. WOW
Is this the right Part # LOL looks like it
Pittsburg Ca
94565
Old 10-26-2023, 09:36 AM   #5
Joyridin
Re: Roller Lifter ?
Use what you want, but unless you can verify the LS7 lifter is a good brand, I would not touch them anymore. Too many fakes and junk out there masquerading as LS7 lifters.
Buy a set of Johnson or Morel lifters. They are probably going to set you back $300-$700, but they are not junk and considering you bought heads, cam, and all the other stuff, you might as well do it correctly.
Joyridin is offline   Reply With Quote
Old 10-26-2023, 10:57 AM   #6
IIGW
Re: Roller Lifter ?
thats becuase after about 1990 EVERYTHING moved to roller lifters.
i would reuse yours
too much risk going for cheap lifters currently
dont forget the need to have the ECM tuned after the cam is installed
IIGW is offline   Reply With Quote
Old 10-26-2023, 11:07 AM   #7
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
I have NO Intention of buying Lifters from Amazon. Someone said you can get anything at Amazon so I looked for laughs. No doubt they are Taiwan Junk- Not in my Engine Thank You Very Much
Pittsburg Ca
94565
Old 10-26-2023, 11:55 AM   #8
Accelo
Accelo's Avatar
Re: Roller Lifter ?
A full set of real GM lifters is a nominal $400.
Lots of fakes out there.
I would re-use my originals.
Accelo is offline   Reply With Quote
Old 10-26-2023, 12:09 PM   #9
indymachinist
Re: Roller Lifter ?
For anyone else looking, please don’t buy LS7 lifters from amazon. Buy them from a known, reputable parts house.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 10-26-2023, 03:36 PM   #10
Joyridin
Re: Roller Lifter ?
It isn't just Amazon. It is many places anymore that are selling the fake LS7 lifters. You think you are buying a set of LS7 lifters for $300 then 2 months after you put them in, half the lifters are collapsed or the rollers fall out.
Old 10-26-2023, 04:56 PM   #11
LS short box
Re: Roller Lifter ?
No chance I would buy LS7 lifters on Amazon. Since you are going to have the heads off you can inspect the stock lifters. If they look worn replace them. Maybe replace the lifter trays with GM trays.
Old 10-27-2023, 07:08 PM   #12
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
Anybody know anything about Morel brand name lifters. They say made in USA
Pittsburg Ca
94565
Old 10-27-2023, 07:21 PM   #13
Joyridin
Re: Roller Lifter ?
Morel is a customer of mine. All their lifters are made in Cleveland, Ohio. I visit their facility on a regular basis. They make lifters for Lunati, Howards, Comp and a few others.
I have a set of short travel link bar lifters in my LS engine. No problems so far.
Johnson lifters are also good lifters. I have those in my LT engine.
Old 10-27-2023, 09:21 PM   #14
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
That’s what I needed to know. Thanks for the info. I appreciate it
Pittsburg Ca
94565
Old 10-28-2023, 07:57 AM   #15
Accelo
Accelo's Avatar
Re: Roller Lifter ?
I noticed the Morel lifters go for a nominal $210.
The real LS7 GM CHEVROLET PERFORMANCE LIFTERS - 12499225 are nominally $415.
Old 10-28-2023, 12:47 PM   #16
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
Anybody know what the difference would be other than price????
Pittsburg Ca
94565
Old 10-28-2023, 01:32 PM   #17
Accelo
Accelo's Avatar
Re: Roller Lifter ?
I would feel comfortable with either of the USA made products.
Their are nothing but horror stories about China lifter failures that take the motor with them. Many are marketed as GM LS7 lifters but are nothing but Chinese knockoffs.
LS7 lifters for $120 don't exist.
Old 10-28-2023, 10:22 PM   #18
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
The company that I’m buying the head and can combo offers Morel lifters for $249 on sale for $219. Probably will go with them
Thanks All for the Input. I appreciate it
Pittsburg Ca
94565
Old 10-29-2023, 08:25 AM   #19
Joyridin
Re: Roller Lifter ?
Morel makes a cheaper lifter and a more expensive version. The cheaper is made from 12L15 or 1215 material. The higher end lifters are 8620. How much that matters, I am not sure.
You may want to check the RPM limit though. I seem to recall the lower end lifters having a 5500 RPM max versus 7000 or something for the higher end version. I am not sure how much you go to redline, but almost any LS/LT engine will easily go beyond that 5500 RPM limit if that is accurate.
Old 10-31-2023, 12:14 PM   #20
Willie Makeit
Willie Makeit's Avatar
Re: Roller Lifter ?
I have really good luck with the BTR (Brian Tooley Racing) branded Delphi LS7 lifter packages. Their website shows out of stock but Summit carries them as well for $179.99, same price as BTR
https://briantooleyracing.com/delphi...499225-16.html
https://www.summitracing.com/parts/btc-x12499225-16
Willie Makeit is offline   Reply With Quote
Old 11-01-2023, 07:45 AM   #21
AussieinNC
Moderator
AussieinNC's Avatar
Re: Roller Lifter ?
It is very concerning to me that the BTR site shows these lifters as having NO WARRANTY !
The BTR site also lists these items as being "like 12499225" telling me they are not genuine OEM.
DELPHI LS7 HYDRAULIC ROLLER LIFTERS - LIKE 12499225
I dont use these or any other lifters not actually equivalent to OEM.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-01-2023, 09:35 AM   #22
Willie Makeit
Re: Roller Lifter ?
The guy ask for suggestions. I gave mine based on my experience and no where in my post did I ever say they were OEM GM lifters. I've never bought a lifter based on whether it had a warranty or not. If one goes bad, it's not the lifter I'm worried about and NO ONE is gonna warranty the rest of you engine based on their lifter warranty. BTR is very very well known in the LS performance world, if there has ever been a problem with these lifters then word would already be out.
Use what you want, no one here is going to argue with you.
P.S.Delphi & Eaton are the OEM manufacture for GM LS7 lifters.
Last edited by Willie Makeit; 11-01-2023 at 09:41 AM. Reason: spelling & clarification
Old 11-01-2023, 12:13 PM   #23
1970 CST Short Wide
Senior Moment
Re: Roller Lifter ?
Seems I’ve opened a can of worms here. I do appreciate everyone’s input. Unfortunately it has me asking more questions. I know there’s knock off Crap out there, problem is how do you know if a reputable Dealer isn’t selling it. I have lots of home work to do now. My engine only has ~50,000 so I might just use what I have
Again, Thanks for ALL the good info
Pittsburg Ca
94565
Old 11-10-2023, 02:54 PM   #24
cj847
cj847's Avatar
Re: Roller Lifter ?
While you are sorting thru fakes.....I'm assuming your cam is going to require new springs. Everyone sells PAC springs. However, do not buy them unless you can confirm they are made by Peterson America Corp.
cj847 is offline   Reply With Quote
Old 11-10-2023, 03:36 PM   #25
Accelo
Accelo's Avatar
Re: Roller Lifter ?
A few year ago I purchased a set of LS6 springs through Ebay.
After hearing horror stories I purchased another set of springs through GM.
All the Ebay springs had lower spring pressures than the OEM's.
I measured them all and the ebay springs averaged 21 pounds less at the same compression length.
Caveat Emptor (Buyer Beware)
