Old 09-23-2004, 04:01 PM   #1
oldraven
oldraven's Avatar
not really a 350?
I bought a 350 with a brand new propane system on it from Jimmie's boss for $500. I'm having it resealed and put in my Supertruck durring the body resto.
I went to get some brass o-rings from Jimmie (my brother) at the shop last night. (yeah, I practically live there) He said "btw, your motor's not a 350."
WTF?
He showed me the engine, all pulled apart. Brand new pistons, and set up for propane. He's guessing 1-10G Km since it was completely rebuilt, so it's pretty much a new lump. But that's not the cool part. Looking at the harmonic balancer (I believe) he said "This is way too big for a 350. And 350's don't have two piece mains. And see how they machined the block here?"
Turns out it's either a 383 stroker or a 400 small block. He'll pull numbers when they get the oil pan back on, and the lump flipped back over. If it's got 350 numbers, it's a 383, if not, it's a 400!
Boo-****in-YAH!!
500 bones for a rebuilt 400 is NOTHING!
'86 C10 regular cab, 383 on propane www.cardomain.com/id/doasa
'87 TurboCoupe 2.3Turbo intercooled 5-spd
www.cardomain.com/id/oldraven
'93 Jeep Grand Cherokee 4.0L
oldraven is offline   Reply With Quote
Old 09-23-2004, 04:37 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The size of the balancer doesn't dictate the engine size. I have a 350 with and 8" balancer and one with a 6" balancer. What indicates a 400 is the counterweight on the balancer. Your balancer looks like a 350 to me, does it have a counter weight?
400 will have siamesed cylinders with steam hole (as will the heads) and will have counter balanced flywheel/flexplate and balancer.
383 will have normal spacing on the cylinders, with water jackets and will have a counter balanced flywheel/flexplate and balancer.
And 350's don't have two piece mains...
As in two piece main seals? Yes they do, all small blocks up to '86 did.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-23-2004, 05:00 PM   #3
oldraven
oldraven's Avatar
Ok. What do you mean by siamesed? As in, there are no water jackets between cylinders?
I'm going by what he told me. I'm not sure what he meant by 2 pc main. I can't remember if it was the bracket itself, or the seal. Regardless, he's pulled apart and rebuilt many a 350 in his time, so I must simply be missing something in the translation. The part about the machining on the block made sense, to make room for a bigger crank.
Old 09-23-2004, 10:14 PM   #4
oldraven
oldraven's Avatar
ok. Jim ran the #'s with GM, and it turns out it's a 383 stroker. 350 with a 400 crank, or something to that effect.
Anyone know what kind of #'s these things put out?
Damn, I think this is the luckiest thing that's ever happened to me. With relation to cars, anyway.
Only problem, it's for a winter vehicle. Take my foot off the brake and do a donut on the ice. Oh well. Spring and fall should prove quite interesting.
I'll get to eat some F-150's
Old 09-23-2004, 10:26 PM   #5
1FaastC10
1FaastC10's Avatar
what makes you 100% positive that its a 383? are you just going by the bigger balancer? check your flexplate/flywheel and balancer for counterweights.
1FaastC10 is offline   Reply With Quote
Old 09-23-2004, 10:43 PM   #6
oldraven
oldraven's Avatar
I'm going by the machined block and bigger crank.
Old 09-23-2004, 11:48 PM   #7
Russell
Professional Grade
Russell's Avatar
Hehe, if that 383 is too big for ya, I'll trade you my 350 for it, even drive the 40 minutes into the city for it
lol
Congrats man! I plan to build a mild 383 myself eventually
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-24-2004, 01:43 AM   #8
oldraven
oldraven's Avatar
Like I said to one of the other mechanics at the shop (who wanted the motor the whole time, but was too slow) who offered me $500 for it yesterday. "Does that come with a blow job, because it's gonna take a lot more than $500." :P
Nah, I think I'll stick with what I've got, thanks.
Hey, next time you're coming into the city, give me a hollar. Do you know any other truck guys in E-town? (or around?) Fords, Mopars, what have you. I don't descriminate. I actually cruise with a bunch of Mustang guys twice a week.
Looks like it's had a mild bore too. .030 ish is about the base bore, right? I'd measure the bore, but It's a fresh rebuild, and there's no way I'm doing head gaskets if I don't have to.
As for the two piece main thing. Yes, it was the seal, and he said, that some 350's did come with two piece. Obviously I mucked that up.
Ok. He also said the Exhaust Valve Rotator was welded for the propane setup, so everything is brand new. (I may have called that the wrong thing too, so forgive the V8 noob. Not to mention Chevy noob. This is my first of both [including first truck and carbed vehicle] I know a fair amount about sizes and the sort, but once you get into the smaller pieces, I'm lost)
Old 09-24-2004, 02:36 AM   #9
Russell
Professional Grade
Russell's Avatar
I'll probally be in town tonight, but my truck isn't much to look at, pretty rusty, lol
Old 09-24-2004, 02:38 AM   #10
1FaastC10
1FaastC10's Avatar
as was stated before, the 8" balancer is not an indication of a 400 crank. hate to rain on your parade, but i have had a 305 with an 8" balancer on it.
Old 09-24-2004, 03:08 AM   #11
oldraven
oldraven's Avatar
As I stated before, the balancer isn't what I'm worried about. It's the 400 'crank', and the 350 block being machined to accomodate the bigger crank shaft. Forget I ever said anything about the balancer. That's simply what got Jim looking closer.
****, you guy's are nit-pickers. Am I going to have to get every part # for you to believe me?
Old 09-24-2004, 04:46 AM   #12
screwballl
Tonawanda 454
screwballl's Avatar
yes
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 09-24-2004, 06:18 AM   #13
1FaastC10
1FaastC10's Avatar
i'd still be a little bit sceptical, unless you either get a crank number or measure the stroke. the cranks arent visually bigger, and the blocks sometimes have "machined" spots in them.
Old 09-24-2004, 06:34 AM   #14
Russell
Professional Grade
Russell's Avatar
Aye, just give the guy the benefit of the doubt :P No reason to rain on his parade, lol
Old 09-24-2004, 07:56 AM   #15
kevinr1970
I'm not trying to say anything one way or another but I didn't know Chevy made a 383 as a production piece? I always thought it was a 350 block with a 400 crank. I've also heard that the 400's had notoriuosly weak bottom ends - wouldn't that mean weak cranks?
I'm not trying to bag on your buy, I'm just trying to educamate myself.
PS - when I was younger I went through quite a few Buicks and never actually got an engine to stop running, even by standing on the throttle for a few minutes. It sounded real bad but would not blow!
Now when the 400 went out in my Suburban, it was DONE!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 09-24-2004, 03:54 PM   #16
oldraven
oldraven's Avatar
It's not a factory 383 (not that I'm saying there ever has been). It's a 1980 350 block with a 400 crank. If I can catch them in time, I'll see if they can pull a crank part # off of it.
I mean, if the guy tells me it's not a 350 crank, I'm going to believe him. What reason does my brother have to BS me? Aside from that, if they can get a #, I'll be happy. I'd rather know beyond a shadow of a doubt too. But as it is, I have zero doubt he's right. I've got four different mechs telling me the same thing. And one very pissed that he missed out on it. (mind you, he's the import guy, so I doubt he'd know by looking at it. He's running an 85 Silverado with a 305 on propane though, so he still may have a clue) The only guys who are skeptical aren't the ones looking at the lump and bottom end first hand.
Old 09-24-2004, 06:09 PM   #17
loblazer
loblazer's Avatar
Ok now you got me going too. When I bought my 1980 Blazer a few years ago, the guy said it was a 350. My mechanic buddy said recently, no it is a 305, has a small balancer. It seems to have some go to it so I assumed it was a 350. Guess I better check my numbers with my parts buddy at GM. I don't really care one way or the other, maybe if it is a 305 I will stay with it as I don't want any worse gas milage then I get now! I have no plates on the glovebox or door to say what I have.
loblazer is offline   Reply With Quote
Old 09-24-2004, 07:48 PM   #18
oldraven
oldraven's Avatar
I don't know if all 350's and 305's are like this, but on mine, the 350 exhaust manifold tracks down from the ports, and back, below the plugs. (see the picture at the top) and my 305 manifold runs above the plugs and back. (complete PITA to do plugs on)
Old 09-24-2004, 09:13 PM   #19
cliffsta
Stepsides RULE
cliffsta's Avatar
no thats not a definate determiner. Some of each have manifolds that do that. Kinda a moot point this bickering over displacement. If its a 350, then its a 350. If its a 383, then its a 383. Your gonna have to use 350 parts on it since that's the base of the motor.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-24-2004, 09:32 PM   #20
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Its always nice to know what it actually is. Even if it is a 305 it was just rebuilt and everything looks good, got a really good price for it also. This is one reason I dont really care to buy built up blocks that the owner has no information about. To a point you are at there discretion to what it really has or not. Some just really dont know what they have just sent to the machine shop and got it back and installed it.
Its up to you if you really want to know what it is. We can help if you decide if you want do that.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-24-2004, 09:52 PM   #21
oldraven
oldraven's Avatar
Thanks man. I wasn't too sure that was a good way to tell either, since the manifold isn't actually part of the engine itself, and those can change with years. That's just the first thing that stood out to me when I got the 350.
I'd be happy with a 350. It's still a considerable upgrade from the ol 305. I don't really need any more proff than I was given that it's a 383 though. The only reason I'd get the crank # is to proove it to the nay sayers. (though I don't know why it's bugging me so much that you fullos don't believe me) If it's a 350, it's got 350 power, which is nice. If it's a 383, it's got wicked power, which is better.
Mylilbowtie, I do know for a fact that it's not a 305 though.
I came here to share cool news on my truck. Why are you guys picking it to death? I got confirmation a few days ago when a collection of journeymen techs gave me the good news. I trust these guys to know what they're talking about. I worded things poorly in my first post, and the topic has just been spiraling into frustration since.
I really don't want this awesome development in the restoration of my truck to turn into a reason to not want to come to this board.
Peace guys. Just, please be positive. My own thread is bringin me down.
Old 09-24-2004, 11:00 PM   #22
cliffsta
Stepsides RULE
cliffsta's Avatar
hey hey hey now lets not bust on the 305 its a good little boat motor as they say. Hasn't done me wrong yet, and the truck is older than me. Its older than my parents are married.
Old 09-25-2004, 02:10 AM   #23
oldraven
oldraven's Avatar
I can't complain about my ol 305. It still runs like a top, and starts every time. It only needs a few kicks in the go pedal and it fires up in the cold. Doesn't leak anywhere, is plenty torquey. It's just a dog, is all. There's too much truck to push around with so little motor.
I'm selling this one for $500 if I can. Or whatever someone offers me. It's a good old motor. Only 219K on it. (136K miles) Just had the carb rebuilt, about 1,000 km ago. I've got no use for it, and I can't move accross country with an old motor.
Old 09-25-2004, 06:45 AM   #24
MylilBowTie
Right turn Clyde
I wasn't trying to pick a part your engine. Just trying to help. My thinking is I would want to know what it really is just for piece of mind. It also helps when you need parts (ie crank, rods) to be able to get the correct part for it. Say its a 350 that has a been built for a stroker. I would want to know what pistons, rod length, gasket thickness and size of the crank they used to make it with. You didn't go wrong for 500.00 in a rebuilt engine. Im not knocking what it is or could be. It just to many variables to just go get parts for a sbc that could lead to damage of the engine.
Old 09-25-2004, 11:49 PM   #25
Russell
Professional Grade
Russell's Avatar
Hey dude... You say you have a rebuilt carb on that 305, is that a Q-Jet? And if it is, would you be willing to lend it to me for a couple of weeks till I get my EFI in? I'm gonna go and fix my intake gaskets again, but after I do that, I'm gonna be needing a carb that can actually be tuned again, I had to really royally mess my old one up to make it work...
