12-16-2013, 03:25 PM | #226 | |
Re: 1970 SWB - Porterbuilt to the Extreme
Thanks. Lots more work to do. I really really hope to have it running again come spring time.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
12-17-2013, 11:18 PM | #227 |
Test fit the gas tank tonight so I can get some mounting brackets welded on at work tomorrow. I have made a template out of trusty cardboard.
12-17-2013, 11:21 PM | #228 |
This height will place my sump and fittings about 3.5" off the ground when layed out. This should be sufficient.
12-18-2013, 02:13 PM | #229 |
Nice build. Gotta love all them Porterbuilt parts! I'll follow along.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
12-19-2013, 11:45 AM | #230 |
Here are pictures of the tank completed. Hope to get this thing mounted up this weekend and some gas lines ran.
12-19-2013, 11:56 AM | #231 |
Sweet! TIG or MIG?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
12-19-2013, 12:03 PM | #232 |
I had our protoype cell at the shop weld this up. It is Tig welded, they do a great job due to welding pressure vessels on a daily basis.
12-26-2013, 09:32 AM | #233 |
Really nice work.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-26-2013, 09:40 PM | #234 |
Thanks Rob. Now that all the holiday stuff is done I hope to play in the barn finally. I need to get some stuff done.
12-28-2013, 08:35 PM | #235 |
Here is how I decided to run my gas line through the frame.
Used a 3/8" coupling and welded it into the side if the frame. Put a 3/8" npt 90 deg barb fitting. Connected a 3 ft stainless braided hose and ran it through the top of the notch. It seems like it will work out nicely.
12-28-2013, 08:39 PM | #236 |
My boy decided to come down in his Jammie's and snow boots for a couple rides on the frame as it goes up and down. It is just as fun for him as it is me.
01-02-2014, 11:04 PM | #237 |
I started to take my gauge cluster apart to clean it. I actually have two so I am going to try a couple different things. I already know what the stock look looks like so I am going to ask our label maker at work to make me some new lettering for the gauge window.
01-04-2014, 11:08 PM | #238 |
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
Got my driveshaft mocked up today, thanks for the measurements Keith/Bennett68C10. I hope to get it to the driveline shop for shortening, new bearings and joints this week.
I also cut off the horrible cab corner replacements someone put on before. Hope to get these welded in this week after the frigid cold is done. I know there are colder places but a high of like 2 is freakin ridiculous.
01-04-2014, 11:43 PM | #239 | |
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-05-2014, 12:18 AM | #240 |
Yes I hate cold weather and I even have a furnace in my barn lol. I'm gonna have to invest in some insulation next year though.
01-07-2014, 10:37 PM | #241 |
I just signed up for he goodguy nationals in Columbus, Ohio in mid July. This will give me some need push to get this darn thing road worthy, not that I needed any more motivation.
01-08-2014, 12:17 PM | #242 |
Nice! It is looking like we will be there exhibiting, and look forward to seeing the truck. You are making some good progress.
01-08-2014, 01:04 PM | #243 |
That is good to hear Travis. It will be nice to meet you in person.
01-08-2014, 01:23 PM | #244 |
- My short term goals are to have the driveshaft shortened and installed by next week.
- The cab on in the next two weeks, this depends on if I want to patch the upper cab while laying on the back which sounds like the best option considering the stories ive heard from doing it over head. If I decide to flip it over then it may be 3 weeks or so before I can get the cab mounted. - Get the gas lines finalized within the same timeframe.
01-08-2014, 02:02 PM | #245 |
Still Learning
Awesome progress.! Good to see your boy getting pleasure out your truck too. It looks great from where I'm sitting. Too bad about the cab corners.
01-08-2014, 10:56 PM | #246 |
Thanks Mike. It never seems to move as fast as you want.
01-08-2014, 11:04 PM | #247 |
Nice goal you have set for yourself, I hope u make it. What are your plans for paint.
01-08-2014, 11:28 PM | #248 |
I went out to check some measurements before taking the drive shaft to the drive train shop tomorrow. At a ride height around 5" the transmission is between 5* and 6 * down. The rear end is around 10* to 11* down. with the rough dimensions that Bennett68C10 gave me and my mock up dims I should have a new driveshaft by next week. I only wish the carrier bearing mount for the center brace was between the ladder bar perches. In order to use the two piece drive shaft I have I will have to weld a brace in.
01-08-2014, 11:36 PM | #249 |
I also took a few pictures of my new gas tank sitting in place as well as the start of my fuel lines. I am going to change the fuel line that runs through the frame to a 6AN connected hose rather than a barbed fitting with a hose clamp. A little too vital a connection inside a frame rail to rely on a hose clamp.
01-08-2014, 11:42 PM | #250 |
Well Keith that is a good question. I want this road worthy by late spring at the latest. If that means bolting on multi-colored panels to do so that is what I am going to do. All that crap just bolts on anyway. So I figure It can be torn down. I am in the same boat with you and Russ and in that I want to drive this thing as much as possible so I dont want an $8000 paint job. My initial thought was the black and bright red frame along with a bright red interior but a matte red exterior. I am still debating on if I want color matched bumpers or chrome. That one red blazer (i think it was N2Billets) that was on here before is pretty close to what I want.
Thread Tools | |
Display Modes | |
