#226 |
Re: Project Platinum C10
Wait, did you do a flip kit in the back? I thought those kits were a 5" drop...
86 Short Bed Build I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment! |
#227 |
![]() Join Date: May 2013
$650ish with some minor patches and a few other things thrown in the bill. He's going to paint dash, kick panels, floor, roof etc. (Basicly complete interior paint). If you're free one of the days I'm gutting it swing by and have a beer. I'd like to see your truck
Posted via Mobile Device |
#228 |
#229 |
I did the 5" flip kit but it only measured out to 4.25". Not sure why that is though.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
#230 | |
#231 |
What shocks are you using in the back?
#232 |
DJM shocks that they recommended for the kit. I think they are Part# 2100
#233 |
After you asked me this question I got to looking at the kit that I ordered and realized that the shocks for the front were not the correct shocks that I installed. They sent me a Part# 1409 and DJM website says that I need a Part#1309. It shows that the 1309 has approx. 11/16" more travel than the 1409. Does this mean the front end will lower 11/16" more with the correct shock?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" Last edited by Claytona08; 06-25-2013 at 12:17 PM. Reason: Edited Text |
#234 | |
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#235 |
using the calmax shocks?
I'm curious to see how she rides with the calmax/djm component set up...
#236 |
That's what I am hoping.
#237 |
I haven't driven the truck much but it seems to ride good with the combo.
#238 |
#239 |
Here is a picture after I had the truck aligned. The distance between the bump stops now are the same but my truck is still leaning to the driver side 1/2". I bought a 1/2" coil spring spacer to even it out and should be getting it by the weekend. Another member said that they had their frame checked and it was tweaked causing the "Chevy Lean". They said it cost approx. 400$ to have it fixed. The reason is the frame doesn't have connecting supports on the front and the read but only near the center (If I understood correctly). I climbed under my truck and low and behold this is what I found.
#240 |
Okay, so now educate me if you don't mind. That looks like a "support" piece that looks like its bent is that, what that is or am I wrong?
#241 |
That is the frame underneath the drivers side door.
#242 |
Ahhhh yeah I have to admit that doesn't look good. Which I know that's stating the obvious, what could have caused that?
#243 |
Oh lordy! How did that happen?!
#244 |
It's normal.
Don't freak out. Chevy put it there to clear the massive cat back in the day. There are threads on here specifically regarding that part of the frame. It is normal. I know I freaked out when I first saw mine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#245 | |
#246 |
I was halfway about to run to the parking lot and check mine! haha
#247 |
Glad you got it fugured out and the frame is normal so you can breath again
![]() You gonna be in the truck today? Posted via Mobile Device |
#248 | |
#249 | |
#250 |
The PO took out a leaf spring and it sat about 1" lower, and I would have had to replace the springs to do a flip kit. I just installed a set of 2" shackles. I think I still need a bit more so I am going to get a set of hangers, I think it needs another inch or two. What do you think?
[IMG] ![]()
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
Thread Tools | |
Display Modes | |
