08-05-2014, 01:15 PM | #251 |
Re: Roadkill's 58 Chevy Stepside
Here are some of the ones I thought were worthy of posting.
08-05-2014, 01:22 PM | #252 |
08-05-2014, 01:30 PM | #253 |
My brother scored some tickets to the Barrett-Jackson auction.
Thought you might like these. The lighting made it tough to get good pictures. . |
08-05-2014, 01:47 PM | #254 |
I like the oldschool look on this truck.
08-05-2014, 03:48 PM | #255 |
I would be afraid to take this truck out of the garage.
08-05-2014, 04:44 PM | #256 |
Cool pics thanks for sharing.
Kim |
08-05-2014, 06:08 PM | #257 |
Love that Orange..I think its similar to my 56 and who would of thought Purple scallops would of worked...i was in Reno the weekend before and spent some time at Summit Racing taking advantage of their Hot August Nights sales...
08-05-2014, 08:33 PM | #258 |
A320 Pilot/USAF Retired
The Vette wheels look nice on the white one!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-05-2014, 08:43 PM | #259 |
You are welcome Kim.
Joe Pass and ChuckDriver I agree. |
08-29-2014, 04:49 AM | #260 |
Making progress on the chassis.
Will cut in a drive line loop soon. Need to mock up engine and transmission to locate transmission mount (again). Lots of welding to do. . |
08-29-2014, 08:23 AM | #261 |
Nice, looks strong
08-29-2014, 09:55 AM | #262 |
Looks real good.
Kim |
08-30-2014, 06:09 PM | #263 |
boxed frame and the cross members look good, roadkill
i like the added support to the front cab mounts
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-02-2014, 11:41 AM | #264 |
Thanks guys.
09-11-2014, 10:37 PM | #265 |
Rear axel back in for more mock up.
Marked where drive line loop will be cut in. Thinking I might take some metal to a fab shop and let them bend the drive line loop. Also torque arm mounting at the other crossmember. Nothing too complicated. . |
09-19-2014, 12:28 PM | #266 |
I separated the pedal from the brake mc/booster mounting bracket.
This was neccessary because of the bracing location. The first pic is where I first mounted it. After checking where it would be when cab was on it didn't leave a lot of room for access. I moved it back where resevouir would be under the front of the bed (bed floor will be raised 3 1/2 inches minimum). The rod length will be about 30" from pedal assembly to mc booster. It's only tacked in at the moment. Made sure I could R&R the mc without any issues. Next is mounting the end of the torque arm. I was thinking about a big heim joint. What do you think Ogre? It needs up, down, and a little roll action movement. . |
09-19-2014, 01:19 PM | #267 |
Looking good.
Kim |
09-19-2014, 05:15 PM | #268 |
Thanks Kim. Keep sanding your is looking good too! . |
09-23-2014, 08:06 PM | #269 |
Still fabricating and doing mock up.
Need to make trans crossmember for the muncie. Brake line transition tabs need welding. Torque arm needs to be finished once pinion angle is set. Trans crossmember for 700r4 is finished. . |
09-23-2014, 08:33 PM | #270 |
Looking good.
Kim |
09-23-2014, 09:00 PM | #271 |
09-24-2014, 01:35 PM | #272 |
Looks strong!
09-24-2014, 02:27 PM | #273 |
Thanks ChuckDriver.
I decided that a strong chassis was a must. It should handle any drive train. . |
10-06-2014, 12:03 AM | #274 |
I'm still working on the chassis, but getting close.
Welded brake line transition tabs (is that what they are called?) on. Ordered another set of stainless braided lines for rear disc brakes. Did some thermal adjustments to exhaust pipes. Working on drive line loop. Finding it difficult to get two bends to look alike. I'll post some pics tomorrow. . |
10-06-2014, 04:26 PM | #275 |
i cut the front of the torque arm off and used a trailer spring shackle up to the stock x-member
no grease zerks on the trailer shackle and after 25,000 miles it is starting to rattle not sure a heim joint would work to keep the side to side movement out i think i'll replace my trailer shackle with something that has poly bushings in it with all the poly bushings laying around the shop i'll probably make something to hold the poly with the current shackle one thing i noticed is your torque arm is real low up front it will not be that low when the truck is together well actually your torque arm will be at the same height, your frame will be a lot lower unless your truck is stock height the torque arm should follow the drive shaft once you get the truck together it will sit 6'' lower, be sure to figure that in when you make the torque arm pivot
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 10-06-2014 at 04:38 PM. |
Thread Tools | |
Display Modes | |
