Old 12-19-2015, 10:57 AM   #251
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: 1977 Silverado Crew Cab.
For myself the motivation behind not using factory parts is just that I wouldn't have to try to find them and cut them off another frame. I can just click the order now button and be done. So it's a few extra bucks for the sake of convenience. I have thought of using all factory parts for a more factory look but several things keep me from wanting to do that. First off, the area where the shackle hanger is is different between the 2wd and 4wd so I'll have to trim that area. And I want to do crossover steering which doesn't fit well with a factory crossmemeber.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 12-21-2015, 08:02 AM   #252
NastyBuzzard
NastyBuzzard's Avatar
Originally Posted by jott_06 View Post
I'm not sure what those crossmembers or spring mounts cost but I was able to use all factory parts on my swap. The factory 4x4 engine crossmember only took a little bit of tweeking to fit in the 2wd frame. The frames are very similar but not exactly the same. I found that the 2wd frame was around 3/8 of an inch shorter in height at the engine crossmember area.
Was that for 1500, 2500 or 3500 frame? I will have a spare 4x4 engine xmember from the 1 ton frame but the frame I am swapping to will be a 2500 frame. They are slightly different thicknesses.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 12-22-2015, 07:11 PM   #253
rgunlock
rgunlock's Avatar
Coming back to catch up on your thread and noticed that the reflections in your buffed out paint job are much crisper than mine. You probably did a better paint job to start with, but could you tell us what grits you sanded (cut) with?
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 12-23-2015, 10:51 AM   #254
y5mgisi
y5mgisi's Avatar
Looks better in pics than in real life! But, I ended up doing the whole 1000, 1500, 2000 routine. Ended up really not taking too long. Then I used maguires 105 on a wool harbor freight buff pad on my harbor freight buffer.
Old 12-23-2015, 10:53 AM   #255
y5mgisi
y5mgisi's Avatar
I'm at both an exciting point and bummer point with my build. It's exciting cause I can start driving it and using it as a truck again! But a bummer cause I have to put it on a hard hold until my kitchen remodel is done... Once I get back to it I'll be re doing the interior first off and then doing the 4x4 swap.
Old 12-23-2015, 11:45 AM   #256
rgunlock
rgunlock's Avatar
Well, looking forward to those jobs on the truck should motivate you to get through the kitchen rebuild and hopefully not let the little details drag out. Looking forward to seeing your next projects.
Rick
Old 12-23-2015, 06:44 PM   #257
y5mgisi
y5mgisi's Avatar
Thanks! Slapped the interior back in it and took it for a cruise!
Old 12-24-2015, 02:35 PM   #258
Matt Man
Matt Man's Avatar
Looks great! Nice to see you driving it after all that hard work.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-24-2015, 05:58 PM   #259
MTCK
MTCK's Avatar
Even in the rain! Good for you.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-22-2016, 09:28 PM   #260
y5mgisi
y5mgisi's Avatar
Put some late model wheels on the crew cab project today.
Old 05-22-2016, 09:40 PM   #261
COS399
COS399's Avatar
Looks good.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-22-2016, 09:44 PM   #262
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: 1977 Silverado Crew Cab.
oh yes
TrailerTrash is offline   Reply With Quote
Old 05-22-2016, 10:55 PM   #263
MTCK
MTCK's Avatar
Truck looks great! Happy to see you back on it.
-Marcus
Project Plow Truck
Old 05-23-2016, 05:38 AM   #264
y5mgisi
y5mgisi's Avatar
Thanks! I am absolutely dieing to get the trim back on!!
Old 05-23-2016, 07:57 AM   #265
rgunlock
rgunlock's Avatar
Wheels look very good on there. Trim is going to tie it all together - can't wait to see it!
Rick
Old 05-23-2016, 09:09 AM   #266
OutlawDrifter
wow that looks amazing!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 05-23-2016, 08:43 PM   #267
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It's looking great with those wheels!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-23-2016, 10:59 PM   #268
y5mgisi
y5mgisi's Avatar
Thanks fellas! Just trying to get through my insane honey do list so I can get back to it! I have done virtually nothing to it since freaking Christmas!
Old 05-24-2016, 09:10 AM   #269
54earl
54earl's Avatar
Honey do list gets me every time
54earl is offline   Reply With Quote
Old 05-30-2016, 06:56 PM   #270
justcuz
justcuz's Avatar
Wheels look good! You going to run those with the 4x4 conversion with some taller tires? Those wheels are only 6.5 inches wide, but woul be perfect for some 9.00x16's.
justcuz is offline   Reply With Quote
Old 06-02-2016, 12:29 AM   #271
deejaaa1
looks great. wheels look good too.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 06-15-2016, 09:46 AM   #272
y5mgisi
y5mgisi's Avatar
If things work out the way I think they will, I'll be ordering up the Fitech fuel injection next week. Seems like a pretty good setup!
http://fitechefi.com/default.asp.pg-GoEFI4
Also, just as an FYI, I have started a little (very little) side business and have started working on a website. If you want to check it out and tell me what you think that would be cool! It's at,
http://gisiautoandfab.com/
Old 06-15-2016, 09:55 AM   #273
68Timber
I know the pieces fit
68Timber's Avatar
I really like that set up and look forward to seeing how it works for you.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-15-2016, 09:58 AM   #274
OutlawDrifter
i've really been itching for a "new" project to try one of the fitechs. i have yet to read a bad review on that setup.
1991 Z/28, 6.0L/T56
Old 06-18-2016, 12:52 PM   #275
jott_06
Camaro Club
jott_06's Avatar
I am also interested in seeing how the FITECH system works for you. It was tempting me pretty bad earlier in the spring when Summit had it on sale.
jott_06 is offline   Reply With Quote
Thread Tools
Display Modes
