07-19-2011, 10:52 PM | #2801 |
Re: Daverods project 66
saving money and having women is like trying to hold lava with youre bare hands , it cant be done without excrusiating pain
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
07-25-2011, 09:46 PM | #2802 |
SSN 706
Is my reg. missing one wire? It seems like there is a spot for one more wire under it? My batt. has been going dead every sinse my crash. I put on a new alt. and a new reg. not sure I hooked it up right. Does the alt get a ground?
07-25-2011, 11:03 PM | #2803 |
i had that happen once couldnt find where the power whent untill i noticed the trunk light stayed on draining the battery
07-25-2011, 11:38 PM | #2804 |
HOW long until spring??
Something does not look right , That kinda looks like a internally regulated alternator...
See if you can find a wiring diagram in the Electrical FAQ section. Check the output with a DC meter to see if It is charging.
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
07-26-2011, 10:27 AM | #2805 |
Daring to be Different
3 Wire alternators need a charging warning light to excite the alternator and get it to charge. Without that light it won't charge correctly. Does it have a internal regulator? If so you don't need that external one.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
07-26-2011, 10:29 AM | #2806 |
BTW the alternator is grounded by the mount.
07-26-2011, 04:03 PM | #2807 |
Member of the longbed union.
Why haven't you used that harness that I gave you?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
07-26-2011, 07:50 PM | #2808 |
SSN 706
I'm going to use it on my 66 or maybe my 52.
07-26-2011, 07:51 PM | #2809 |
SSN 706
I was wondering because it had a ground screw but I did'nt have any wire to hook it to.
07-26-2011, 07:58 PM | #2810 |
SSN 706
It's external.
07-26-2011, 09:28 PM | #2811 |
Looks like the ground goes to the base of the regulator.
07-27-2011, 12:37 AM | #2812 |
SSN 706
I grounded the reg to the rad. support thats the way it was. What's confussing me is on the inside or bottom of the reg. (the side facing the rad support) there is a connection for a wire. I don't know if it's just extra or if somthing needs to be hooked up to it. I think it might just be normal?
07-27-2011, 09:58 AM | #2813 |
Have you put a volt meter in it to see if it's charging? You might have a different problem. Check the battery too and try to put some kind of load on it and see how much the voltage drops. Under load 9.6 is bad. The battery might not be excepting a charge. Also check all connections, and terminals, and grounds for good clean contacts.
07-27-2011, 02:51 PM | #2814 |
SSN 706
I think it was just a bad reg. I redid the wire going back to the batt. It's wedsday and I haven't had to charge it yet. Watch it will go dead this afternoon.
09-20-2011, 09:21 PM | #2815 |
1 thing at a time is progress.
Just a heads up of a problem i almost had. The clearance between the wiper motor and the radio was close.
Alan
Philippians 2:14-16 |
09-20-2011, 09:29 PM | #2816 |
SSN 706
I guess my x box is'nt going to fit?
09-25-2011, 10:14 PM | #2817 |
Happy birthday old timer!!! the big 50!!!
09-25-2011, 10:15 PM | #2818 |
X2
Alan
09-25-2011, 10:18 PM | #2819 |
Happy Birthday !!!!!!
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
09-26-2011, 12:53 AM | #2820 |
60-66 Nut
X4
09-26-2011, 10:13 AM | #2821 |
X 5
09-26-2011, 10:31 AM | #2822 |
x6 young man
ron |
10-02-2011, 03:47 PM | #2823 |
SSN 706
Thanks guys. I still have 50 to go.
10-02-2011, 09:10 PM | #2824 |
Keep living the good life, and you will.
10-04-2011, 11:01 PM | #2825 |
SSN 706
I have been living the good life for the last 40 years. Its only this last year thats sucked. haha I don't really want to last 50 more anyways.
Thread Tools | |
Display Modes | |
