Old 11-12-2015, 10:47 AM   #276
reaper71
reaper71's Avatar
Re: Blake's 67 GMC stepside build
Pic#1. Inner fender needs some TLC
Pic#2. 2nd view
Pic#3. After the repairs were done.
Pic#4. backside will need to be cleaned up from the undercoating.
reaper71 is offline   Reply With Quote
Old 11-14-2015, 10:39 AM   #277
reaper71
reaper71's Avatar
Pic #1. All ready foe Epoxy and High build primers.
Pic #2. Ready for blocking.
Pic #3. This is my makeshift booth so I could wire wheel and sandblast.
Pic #4. Hood is in pretty nice condition, A dent in the front peak will need some attention and some rot on the backside as well.
Pic #5. The underside of hood after paint stripper was used and will need to be blasted and wheeled.
Mark...
Old 11-14-2015, 10:50 AM   #278
Advanced Design
Advanced Design's Avatar
Nice repair on the inner fender Mark. That spray booth has to be handy.
Advanced Design is offline   Reply With Quote
Old 11-14-2015, 09:33 PM   #279
yj4000
yj4000's Avatar
That's a good idea to use the garage door rails. I will have the same amount of work on both my inner fenders.
Ryan.
yj4000 is offline   Reply With Quote
Old 11-16-2015, 10:35 AM   #280
reaper71
reaper71's Avatar
Thanks guys...
The booth came in really handy for keeping the Nasty stuff from flying around the shop and the sand as well.
Old 11-16-2015, 10:50 AM   #281
reaper71
reaper71's Avatar
Pic #1. Is the backside inner structure of the hood. This was removed so I could fix a dent in the peak in the lower portion that you can't get to.
Pic #2. This was after Hammer/Dolly,welding and metal finish.
Pic#3. This is what was found after I used the wire wheel.
Pic#4. The spot welds drilled out and the top section will be re used.
Pic#5. The bad section removed.
Mark...
Old 11-18-2015, 11:23 AM   #282
reaper71
reaper71's Avatar
Pic #1. This is the new patch I made up.
Pic #2. Jumping forward, all welded in place.
Pic #3. The stock piece ready to be welded back in.
Pic #4. Welded and metal finished.
Pic #5. This was after the hood was blasted and is now ready for Epoxy and High Build primers.
Mark...
Old 11-18-2015, 03:10 PM   #283
RockinKees
RockinKees's Avatar
Very nice work Mark!
That's how you save original parts
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-18-2015, 09:36 PM   #284
Advanced Design
Nice save Mark. Has the owner been suprised by the needed rust repairs?
Old 11-19-2015, 10:26 AM   #285
reaper71
reaper71's Avatar
Thank's Guys..
Yes and no, he lives out of town so I send E-mails with pics. There have been several times he was a bit shocked but has taken it pretty well.
Old 11-19-2015, 10:39 AM   #286
reaper71
reaper71's Avatar
Pic #1. More hood updates...some spot filler
Pic #2. The backside of hood was shot with rust encapsulator.
Pic #3. Then the entire hood shot with Epoxy primer.
Pic #4. Then followed by High Build primer..
Pic #5. Guide coat applied and ready for blocking.
Old 11-20-2015, 10:10 AM   #287
reaper71
reaper71's Avatar
Pic #1. As you can see here the front lip needs some love.
Pic #2. A thin coat of filler was applied.
Pic #3. Shot some more H.B. ready for blocking.
Pic #4. The hood had a couple spots I was not happy with so some filler was applied to smooth them out. Will spray more H.B. and block again and be ready for final primer.
Mark...
Old 11-21-2015, 09:58 AM   #288
yj4000
yj4000's Avatar
Lots of flat surface on a hood. Lookin' good.
Ryan.
Old 11-21-2015, 10:00 AM   #289
reaper71
reaper71's Avatar
Yes there is! and it tends to "tin can" sometimes
Old 11-24-2015, 10:14 AM   #290
reaper71
reaper71's Avatar
Pic #1. Masking off the back of hood so it can be sprayed with satin black.
Pic #2. This was just after shooting so didn't flatten yet.
Pic #3. The Inner fenders were shot as well as will the core support so it all matches.
Mark...
Old 11-24-2015, 03:05 PM   #291
RockinKees
RockinKees's Avatar
Looks nice Mark!
Cheers!! Kees.
Kool Guyz CC
Old 11-24-2015, 04:44 PM   #292
Advanced Design
Mark, really like the look of the inners. What did you shoot them with?
Old 11-28-2015, 04:45 PM   #293
reaper71
reaper71's Avatar
Kees, Doug Thanks again guys..
The paint was a shopline satin black. Lays down really nice and flashes in about 30 min.
Old 11-28-2015, 08:58 PM   #294
zicc1835
zicc1835's Avatar
wow ...just went thru it all remarkable
zicc1835 is offline   Reply With Quote
Old 11-30-2015, 10:16 AM   #295
reaper71
reaper71's Avatar
zicc1835 Thank You!!
Old 11-30-2015, 10:29 AM   #296
reaper71
reaper71's Avatar
[FONT="Comic Sans MS"]Hope everyone had a great Thanksgiving!
Onto the next project...The Core support
Pic #1. The core support before blasting.
Pic #2. A closer look of the rot found that will need to be fixed.
Pic #3. This was taken after blasting, alot of swiss cheese!!
Pic #4. 2nd view.
So as you can see this will take a fair amount of work and planning to fix all this but I'm up for the task in saving yet another piece!
Mark.../FONT]
Old 11-30-2015, 03:19 PM   #297
RockinKees
RockinKees's Avatar
That's a lot of work....
Cheers!! Kees.
Kool Guyz CC
Old 12-01-2015, 04:46 PM   #298
reaper71
reaper71's Avatar
Yes it is, but I like doing this kinda stuff!
It's in my wheelhouse..
Old 12-01-2015, 05:16 PM   #299
reaper71
reaper71's Avatar
Pic #1. This was after I cut things apart to see what I was dealing with.
Pic #2. This was the mock up of the new lower section that was removed.
Pic #3. Then transferred to steel.
Pic #4. Drilled holes and now ready to make the bends.
Mark...
Old 12-01-2015, 05:46 PM   #300
RockinKees
RockinKees's Avatar
That's gonna be better than new!
You're not afraid of anything, a true craftsman!
Cheers!! Kees.
Kool Guyz CC
Thread Tools
Display Modes
