#3051 |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Saturday Night Picture Time
I scavenged jute padding from some of my 2002 part out trucks and today I was gluing it down to the floor. I also crammed the rear window panel surrounds full. The rear carpet set seems to fit fine. Since I had to order a Burb carpet kit, I will use the rearmost suburban carpets to make a rear panel carpet cover (below the glass), but between the carpet and jute padding I am installing some plywood to mount my air ride box and wires out of the way and off the floor. Man this thing ought to be quiet!!!
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#3052 |
67cheby
![]() Join Date: Sep 2008
Looks very nice
Posted via Mobile Device |
#3053 |
And now its looking nicer!
The rear panel got Dynamat, then jute padding, then 3/4 plywood, and then carpet. I made some clamps to attach the plywood to the old gas tank mounts. With the plywood there I can mount my air ride stuff out of reach. I hope I don't need to mess with it.
#3054 |
Looks like I ended up with plenty of room in the back seat. This is with the front seat pushed all the way back, which won't be how I need it to drive.
I hired a boy model to test out the legroom.
#3055 |
Your truck is looking really good. Are there any other reasons that you added the plywood other than mounting the Air ride stuff? Any advantages having it back there?
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
#3056 |
Still Learning
Interior looks great Drew! So close now....
#3057 |
Boy Meets Truck
For sure a boy... Let me know if you need a man model.
PS - Thanks for keeping the southern truck theme going shirtless. Please leave the rebel flags and lower back tats off. |
#3058 |
67cheby
Looks great
#3059 |
It also makes for a really flat smooth looking surface. I hot glued the carpet to it which helps it hang smooth and tight.
#3060 |
![]() Join Date: Jul 2010
I love the color on that carpet..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#3061 |
I'm not sure what's up with ACC. I work in the same town they are located in (Anniston, Alabama) and visited them on numerous occassions and they are not very helpful. You'll probably have better luck getting help from the distributor you got the carpet from if you are trying to get it swapped.
66 Chevy 305 /350 auto, ![]() |
#3062 |
Very nice build, I just looked at the whole thing in one sitting, very informative.
Since you are using the stock rear seat and I saw you mount the hooks to your back wall and saw that you carpeted the rear and mounted some of you air ride back there .. I wanted to see if you knew about the mod to not only make your rear seat flip up but also fold down. All you have to do is take a little off the hook on the seat. The seat works exactly like it did stock when down, it does not flip forward. To flip it forward you lift the bottom slightly and then the back of the seat will fold down. Keep up the good work! ![]() ![]() |
#3063 |
That's a great trick, I'll have to try it!
#3064 |
VA72C10
![]() Join Date: Mar 2008
Looking great! Any update on the front carpet fiasco?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#3065 |
ACC was no help. They said I had to call the place I bought it from. I did and they want to measure one at their shop and compare to mine tomorrow.
#3066 |
Today I got my headliner material samples and we are going with dark charcoal. It is called Alcantara, an Italian product used by Porsche, BMW and Mercedes on their exclusive models. Only one importer in the US, Gulf Fabrics. It is some fine stuff!!!
#3067 |
VA72C10
That is nice material...I've seen it mixed with leather and it's really sharp!
Stinks about the carpet. Guessing you won't have it now by the show...
#3068 | |
The real focus though is on the Hot Rod Power Tour!!!! I got the ok tonight from the wifey. I'll probably do St Louis to Texas. Who's in????
#3069 | |
![]() Join Date: Aug 2010
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#3070 |
Chevy Enthusiast
Id love to see this truck in person! How far into Texas would yall go?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#3071 |
^ I've been waiting for a west coast Power Tour. Ive come to the conclusion it will never happen......Freiburger are you listening.
#3072 |
![]() Join Date: Mar 2007
I love the way that the factory black leather seats look in your truck.
Keep up the good work. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#3073 |
Check the Hot Rod Website for dates and locations.
#3074 |
Thanks, they're super comfy, heated, and free since I parted out the rest of the truck and got my original investment back.
#3075 | |
I have been on the 2010 and 2011 Power Tours but this one is a little too far away..double bummer..LOL
Eric 1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509 2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq 2016 Camaro SS - Satin Pearl Nero wrap My 2010 Camaro SS Magazine feature (SOLD) http://www.superchevy.com/features/g...of-perfection/ |
Thread Tools | |
Display Modes | |
