#3376 |
Re: 67 cheby's Dropmember build thread
They look awesome.... Hopefully mine will be installed by the end of the week.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
#3377 |
BTW... Just saw your pics of the hard lines... You did good. Wish I would have thought about the clamps as spacers before I installed them. That was a good idea. Acuair should redesign those valves to be numbered 1-3-2-4 instead of 1-2-3-4. It would make more since because 1-3 are going to be on the sane side. It would make running the lines a lot easier and cleaner.
#3378 | |
67cheby
![]() Join Date: Sep 2008
#3379 |
67cheby
Summit 3/8 aluminum line
#3380 |
![]() Join Date: Dec 2006
Looks good Mike, Does anything have to be done to the Accuair Valve Block to run the Aluminum Line. I really like the way that looks.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#3381 |
The aluminum lines actually hold into the quick connects really well. I did the same thing on my build and was pretty pleased at how easy it was to bend the lines, mostly by hand, and it looks really good.
#3382 |
67cheby
that is right man they really stick in there !!
#3383 |
I ordered a few extra quick connect and a double sided quick connect from AVS and they are really nice. The connections are stainless instead of plastic. I got the double sided just in case I need to make a quick fix on the road.
#3384 |
couldnt you just make an male female adaptercable or resolder the connections on the controllboxside to rewire the valves so the coils are set up the right way ?
the bends on the hardlines look good , its too bad you cant get different radius benders that go up in the same distance as the spacers you used that prolly wouldve made it eazier as the bends then all start at the same point over all the lines (you dont have to measure the stagger or finangle it so the distance after the bend is correct to use the spacers again) , would make it look cleaner too
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#3385 |
67cheby
new pretty part !
#3386 |
Is that one of those semi smoke stack covers? Just kidding. nice looking gas cap.
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
#3387 |
67cheby
LOL, it's about the same size !! it's HUGE !
#3388 |
Did you get it from the place that has your gas hole covered? same as n2billits cap?
#3389 |
67cheby
Nope...i am to cheap to spend $300+ on a gas cap, this was pushing it for me $134 from SPEEDWAY ! but it is a very nice piece,they make a large one and they also make a small one i think it is about $90 for the small one, this one is over 5 inches wide, i am impressed with the quality !
#3390 |
![]() Join Date: Jan 2012
Man those tubs look killer .....
Stocker to Rocker http://67-72chevytrucks.com/vboard/s...=1#post5148380 "THE GRADUATE" http://67-72chevytrucks.com/vboard/s...08#post5763408 JohnnyC http://instagram.com/texpinstriper/ |
#3391 |
67cheby
thanks , i was pretty pumped it is the first set i have seen painted to match !
#3392 |
nice who needs a funnel just open it and dump a bucket out intoo the hole
it does look like a nicely made piece
#3393 |
67cheby
LOL, its big enough you could !!
#3394 |
Sofa King Crazy!!
A few excerpts from the last few posts.......
new pretty part ! LOL, it's about the same size !! it's HUGE ! Did you get it from the place that has your gas hole covered? they make a large one and they also make a small one.......this one is over 5 inches wide, i am impressed with the quality ! who needs a funnel just open it and dump a bucket out into the hole LOL, its big enough you could !! Let's keep it clean guys.......
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#3395 |
Sofa King Crazy!!
#3396 |
#3397 | |
67cheby
#3398 |
Sofa King Crazy!!
That's what I'm here for.......keep the seriousness to a minimum!!!
#3399 |
6>8 Plugless........
![]() Join Date: Sep 2007
LMAO!
![]() On a serious note, nice lines and plumbing!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#3400 | |
![]() Join Date: Mar 2010
Nice job on the tube also. |
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
Thread Tools | |
Display Modes | |
