#376 |
Re: my 80 build
my bezels are the same too lol. I thought about painting them body color, but just painted them silver instead.
#377 |
6.0 powered square
Re: my 80 build
new wheel
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#378 |
Re: my 80 build
nice
#379 |
Re: my 80 build
Looking good Aaron!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#380 | |
6.0 powered square
Re: my 80 build
no problem
thanks Thanks Dennis
#381 |
Re: my 80 build
That looks good man!
#382 |
6.0 powered square
Re: my 80 build
thanks John
#383 |
6.0 powered square
Re: my 80 build
few parts I 'll be ordering shortly
http://www.classicparts.com/1987-Gas...ctinfo/23-953/ http://www.classicparts.com/1987-91-...ctinfo/23-555/ and I maybe getting a 6.0
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 05-09-2010 at 11:49 AM. |
#384 |
Re: my 80 build
You may check the shipping on those. I got my tank and unit from O'Reilly, and wasn't much more than that. Just something to check out.
#385 |
6.0 powered square
Re: my 80 build
thanks john Oriellys will be a little cheaper but the sender is a lot more though
#386 |
Re: my 80 build
I have noticed the parts places are like that sometimes. When I was looking for the Edelbrock fuel line piece on the carb. Summit has it for like $18, and O'Reilly was $39. Then on something else O'Reilly was half the price of Summit. Never hurts to check around on stuff.
#387 | |
Sunburst C10!!!
Re: my 80 build
awesome build
Gage 1967 C10 Shortbed Stepside |
#388 |
6.0 powered square
Re: my 80 build
I give them a look,
the rear end in my tuck starting go so a total rebuild is in order all new bearings and seals, with a 3.73 ring and pinion, with posi track, also maybe rear disc and a deeper diff pan
#389 |
6.0 powered square
Re: my 80 build
today I went to go some lunch trough the drive through and something caught my eye and I scrapped the curb got back to work and noticed a little scrape so when I got home jacked the truck up and looked at the tank it was fine then I noticed my frame where it was welded where it became a short bed it looks to be cracked so I plan on adding more welds and a gusset
#390 |
Re: my 80 build
Your truck was a longbed?
#391 |
6.0 powered square
Re: my 80 build
yes it was a long bed way before I got, I looked at the welds again and didn't notice any cracks but I still beef the area up though
#392 |
Re: my 80 build
i wanna turn mine into a shortbed.
#393 |
6.0 powered square
Re: my 80 build
the sway bar rivets were getting loose so I drilled out the rivets and installed new grade 8 bolts and new bushings
#394 |
6.0 powered square
Re: my 80 build
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-24-2010 at 12:35 AM. |
#395 |
6.0 powered square
Re: my 80 build
summer06
![]() summer 07 ![]() summer 08 ![]() summer 09 ![]() summer 10 ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 07-12-2010 at 01:01 AM. |
#396 |
6.0 powered square
Re: my 80 build
made my truck a little better driver friendly. At times it would be real hard to start in the mooring or not even start at all so I added new rotor in the distributor and now it fires right up every time, and wile the truck was running you could wiggle the coil cap and the truck would die, so I took it off and noticed were the ground wire goes the plastic was all burnt so added new one and no more problems. While driving my truck 2 years slammed I was tired of it bottom out ever where in the front so added some stubie bump stops I found at pet boys and what a difference ride much better no more banging noise. the my throttle was real had to push down you would have to punch to go, so added a new throttle bracket what difference and looks 100% better, also some led tail lights from lmc there much brighter, there were fairley easy to install
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 07-10-2010 at 03:07 PM. |
#397 |
Sunburst C10!!!
Re: my 80 build
awesome
any pics?
#398 |
Re: my 80 build
*didnt look bad into the thread*
How the rig going ive missed out on alot here
Roman "LCPL" Planter The Few The Proud The Marines |
#399 |
6.0 powered square
Re: my 80 build
![]() ![]() ![]() ![]() ![]() and rome the rigs going good it get driven every day to work
#400 |
Sunburst C10!!!
Re: my 80 build
awesome
Thread Tools | |
Display Modes | |
