Re: 53 Surburban "Family Truckster"
Slick! Frame looks great.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
![]() Join Date: Jul 2012
Looks very nice. Was the CAD file off or is there variation in the frames?
A320 Pilot/USAF Retired
Frame is looking good! Do you think it would be beneficial to add a gusset to the body mounts?
My PB parts have a nice brown "patina" to them now due to the awesome humidity here in the south! Are you planning to paint the frame or powder coat it?
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#4 | |
![]() Join Date: Mar 2007
Yes, I hit my parts with a wire wheel on my grinder and the parts look nice. I will rub some oil on them to preserve them until I get primer on them. I plan to paint the frame. I like powder coat but I like the idea of being able to repaint if I make a repair or change. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#5 | |
Marc
![]() Join Date: Mar 2010
Looks good... You said you were painting the frame so you could touch it up. What about the PB parts? Powder coat or paint?
#7 | |
Marc
Are you going to remove the cab and running board mounts to get better paint coverage?
#9 | |
Marc
Good call! I removed all mine and is was not fun!!!
They can be made really clean looking. Be interesting to see which way you go as I am kicking around ideas for mine with a couple friends. I really like the look Superflysteiney did on Cheap Tricks.
Clean look! I like the black out on accessory drive. Man, I've spent too much time on accessory drives lately.... Will you be using the F car accessory drive Marc?
#13 | |
Marc
#14 |
Well I picked up the metal on Wednesday from the stripper (inset joke here). It turned out great. The old frame cleaned up nicely. I took the frame and various pieces to the my painter so that I could use his booth to get all of the pieces covered with epoxy primer. This way I can finish mocking up the frame without it rusting. The bare metal has a coating on it that needs to be rinsed off before you can prim or paint. Good thing for me it is still 40 degrees in Michigan.
On with the pics...
#15 |
My painter Jim is working on some pretty cool projects. A 60's bronco II. Another one is this Chevelle. It has a 2012 Camaro drivetrain and interior. It also sports a custom rear independent suspension. There is also a cool 48 Fo$d sedan. It has a mild tasteful chop. There where too many parts stacked around it to get any pics.
if we don't get the ice storm that the area is suppose to get I will go pick up all of there pieces tomorrow. Marc
#16 | |
#17 |
I got hit with ice tonight. Hey marc, been in your shoes with the welder. I bought a 90amp craftsman years ago (things pretty good for small stuff) needed a bigger welder and looked on CL, every time a good deal came up I had no money or someone bought it. I finally just put a Eastwood 175 on my CC which you can't beat the price. I used it for a bit, had problems with the gas solenoid a few times, but other than that it works great. I bought a used Hobart and I use that the most. For me, I need back up welders for 1. I have several working locations, so tools spread way out, and 2. if one goes down its nice to not ruin your whole work day bc you need a welder. I'v had a tig on my radar for a while, that's next. but then you need another tank and more space and the list goes on.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#18 |
I need to buy a welder......I always borrow one from work.
Leaning towards a Hobart 140 since it is rated for 1/4", but a bigger 220vac machine would be nice. Those stripped parts look great!! |
#19 |
I found this setup on ebay for $800 and I am really happy with it all so far. Its does all the work for anything going on with these trucks.
I am welding 3/8" with it and not even at full blast! it works well. http://www.eastwood.com/mig175-and-v...FQErHwodE1QNEw
My Build: 57 Chevy Pro-Street |
#20 | |||
Thanks Marc
#21 |
I got out in the garage today. Worked on welding shut the inner and outer gas fill hole. I also followed Advanced Design's lead on removing a broken exhaust manifold bolt. I drilled out a nut and slid it over the broken exhaust bolt. I welded it up when I was able to spin it out.
I also started welding closed some of the various holes in the frame. Marc
#22 |
Good deal on the broken bolt Marc. That is one I learned from my Dad and relearned from a good friend. Yeah, I had forgotten. Glad it helped you.
Think of your welder as a lifetime use purchase so get a good one. 10 or 12 years ago I bought my Miller for @ $1,500 or so. A non car guy friend of mine asked what I paid for it. "Wow" he said, "will you get that much use out of it? ". Well Chuck, I responded, how much did you spend on golf last year? Oh, about $1,500.....and I still have my welder. Gotta do something with my gas fill too. I don't remember, did you figure out your tank? |
#23 |
Marc where is the gas filler going to be located?
#24 |
Sorry Marc, I checked and don't have any extras.
#25 |
Thanks for checking Doug. Back a few years ago I always found all sorts of them at swap meets to $20, but not when you need one. I hate to spend $40.00 on something that I will cut up and only use a little piece.
Marc
Thread Tools | |
Display Modes | |
