08-23-2018, 10:24 AM | #401 |
Re: Just another old truck.
That is what I call creative!!
Nice job Earl!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
08-24-2018, 03:10 AM | #402 |
CJ
Super creative, I'll be following. Keep on keepin on NC
Been there, wrecked that |
09-03-2018, 02:09 AM | #403 |
Hey Kees and Nut Case. Thanks you guys.
Its been awhile since I lasted posted anything on here but that doesn't mean I've not been busy. Been working on a bunch of things, some big and some small. First thing was my keyless ignition that I made. It turned out to be a prototype. I just over built it. I had to replace the old switch with a new one. Also had to take the switch apart and cut 3 coils off the spring because it was too hard to pull out. Also had to make a few other changes but its back on the dash and working good. #2 was the parking brake. Made a bunch of little parts and pieces so that all works now. #3 is the bed and bed steps. I did not have the 3 cross sills so I had to fab them up. Also the bed step supports were missing. I'm working on more pictures so I will post them later. Just gotta get them together. Earl
You have to have patiences or you'll be one. |
09-03-2018, 10:06 PM | #404 |
So creative and resourceful....excellent!
09-06-2018, 12:30 AM | #405 |
Hey Doug. Thank you.
Earl
09-06-2018, 12:34 AM | #406 |
I said it before but I love how detailed you make your pictures.
great improv on the mounts too!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
09-07-2018, 01:17 AM | #407 |
Hey joedoh. Thanks a lot. Right now I'm working on a bunch of pictures of the parking/emergency brake system for my truck. Lots of little parts and pieces had to be made.
Earl
09-08-2018, 03:34 AM | #408 |
The first thing I had to do was get the drums off so I could install the parking brake levers and cross links and cables.
Just a little story first. Years ago I had the same problem with the rear drum hanging up and not pulling off. All the same things happened. I pounded and pried, and beat the heck out of that drum but no go. I was going to get that drum off no matter what. Anyway, it was a bad time to have a set of torches laying around. I was just mad enough to get them out and so I used the torch to cut the drum off. It came off but now I was standing there with a worthless drum and all the springs and clips inside had to be replaced too. This time I put a little more thought into it. For now that's it. Earl
12-11-2018, 01:48 AM | #409 |
Well I finally go all my pictures together for the e-brake system. There is some but not much said about e-brakes on this forum so heres my two cents worth.
There was a bunch of stuff not correct or missing on CJ. I had to make or change a lot of the small pieces to make it all work together. All our trucks on this forum have some kind of history about them so heres mine.
12-11-2018, 01:57 AM | #410 |
More pics
12-11-2018, 02:05 AM | #411 |
Third set
12-11-2018, 02:12 AM | #412 |
And finally I have working E-brakes.
Earl
12-11-2018, 10:33 AM | #413 |
Earl, very nice and clear info on how to fix e-brakes. Many people will be glad to see this. You the man...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-11-2018, 11:29 AM | #414 |
nice work. very detailed pics.
I am lucky enough to have a parts washer with a pump in it. what I have done in the past to clear the park brake cables of dirt or rust or whatever that builds up inside the sheath is first get them freed up, then put a section of hose over top of one end of the cable sheath and clamp it on with a gear clamp. then hook the other end up to the washer hose so it pumps solvent through the cable sheath. the solvent should start squirting out the other end of the cable soon enough, depending on how dirty the cable was. you can speed things up some by moving the cable in and out from the solvent exit point where the inner part is accessible. when all done disconnect the hose from the washer and use compressed air to blow the solvent out, then dump some thin oil in the hose where it used to connect to the washer unit and blow the oil through the cable. bicycle shops sell some great synthetic cable lube if you're looking for something that will stick with it. all ready to go another few years. on a side note, if you find, while flushing the cable, that there are areas where the solvent is coming out the side of the cable sheath then you can mark that area and later, when the cable is allowed to dry-before lubing, you can use electrical shrink tube to seal off the cable in that spot. use the double wall shrink tube because it has glue on the inside that helps the tube stick to the cable sheath. shrink tube is available in long lengths so you could do the entire cable if you wanted to. |
12-11-2018, 12:33 PM | #415 |
Nice write up Earl!!
Very creative thinking here!
12-11-2018, 03:08 PM | #416 |
Hello Jim. Thanks for that. Most of these old trucks on this forum after may years and owners find that many of the old parts are lost or broken and its hard to find replacement pieces. We all like to share ideas back and forth. Maybe it will help someone some day. My short coming is in the electrical department.
Hey Dennis, thank you. I like the idea about the shrink tubing. Its an idea that I will try out in the future. Hello there Kees. Thank you very much. Earl
12-11-2018, 03:14 PM | #417 |
i love how clear you make you how-tos, nice work as usual!
12-11-2018, 04:01 PM | #418 |
Wow! Mad fab skills.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
12-12-2018, 03:59 PM | #419 |
joedoh thanks. I appreciate the comments.
Hello 8man, thank you. Earl
02-18-2019, 07:19 PM | #420 |
This past week I've been working on the passenger rear fender removing the old paint and making one small patch panel over the step. Got all the paint off the outside and one good coat of epoxy primer on. In this rainy weather it starts to flash rust in half a day or less. I'm off to get a new HF welding helmet so I can finish welding this patch panel in.
On a side note fabbing and welding these patch panels up is naturally getting easier and I'm not worried or afraid of doing them anymore. YAHOO. Still have a bunch more to do on the front clip. Earl
02-18-2019, 09:28 PM | #421 |
nice write up clarance, and great progress
02-19-2019, 12:22 AM | #422 |
Earl, doing a nice job on repairs...Jim
02-19-2019, 02:16 AM | #423 |
Hey Joedoh, thanks again.
Thanks Jim. I'm looking forward to finishing this fender so I can get paint on it. I want to do the paint like you showed us on your truck. I can only paint one piece at a time. This just seems like a good place to start. I anticipate good results. I've leaned a bunch from my past mistakes. So lets see what happens. Thanks again. Earl
02-19-2019, 08:33 PM | #424 |
Earl, looking forward to the paint work, you should do fine...Jim
05-06-2019, 12:13 AM | #425 |
Back to post something I did awhile back. I wanted to move the fuel filter out of this spot to a place that would help clean up the top of the motor. This only ate up an hour of my time. Gotta see what else I can change that I thought I was done with. Never ending.
Earl
Thread Tools | |
Display Modes | |
