#26 |
Update
I removed all the belts and could still feel the vibration although it was cut in half. I put the alternator belt back on and the vibration was back at full power
![]() THanks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
#27 |
72 C30 Trailer Queen
If the engine you have is a 2 piece rear main seal 350 (which your casting number indicates), you need a flexplate with no counterweights!
#28 |
Chris H
There are no weights on there those are the welds. Sorry about that.
#29 |
I think I may have this sucker figured out. I believe I have 2 vibrations happenning at once here. I feel the vibrations in the seat and in the steering wheel.
With all the belts removed the steering wheel vibration is almost totally gone and what is left matches the vibration that I feel in the seat. I cranked up the idel to 1300 and got under the truck. Dust cover has the same vibration that feel in the seat. I checked the waterpump pulley and I can see a small bend in it. I got another one on the way. I will get that installed and work that one from there. Now how do I deal with the vibration from the torque converter? Thanks
#30 |
I got my How to work on the turbo hydra-matic 400 transmission today and it says that the vibration I am feeling from the converter could be a mismatch to the flywheel. It says to losen the bolts and turn 120 degrees, retighten and check to see if the vibration is gone. Going to give that a try.
Thread Tools | |
Display Modes | |
