Old 06-07-2005, 01:22 PM   #26
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Building them. Most of the notches out there for sale are eight pieces which means you have to weld them together. It was just easier for me to buy some rectangular tubing and make my own.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-22-2005, 01:09 PM   #27
1low1967
1low1967's Avatar
Here's mine I made everything myself and will be running a 275/45/r20 all the way around. its about 30 overall dia.
1low1967 is offline   Reply With Quote
Old 06-22-2005, 01:14 PM   #28
fastbagged68
fastbagged68's Avatar
How much lift you get? Do your arms/links flex at all with the bags not being center on the arms/links? Mine did.
fastbagged68 is offline   Reply With Quote
Old 06-22-2005, 01:25 PM   #29
1low1967
1low1967's Avatar
with the bumper on measuring from the ground to the bottom of the bumper with about 85 psi i get around 24 in of lift,thats from bumper on the ground. They don't flex at all i renforced them on the insides with gussets
Old 06-22-2005, 02:05 PM   #30
fastbagged68
Mine did not flex the whole arm rolled like. Looks good! Watch out once you put weight on the frame and double check the mounts.
Old 06-23-2005, 07:40 AM   #31
1low1967
1low1967's Avatar
I will have to watch out for that, Did you do anything to fix it or just live with it.
Old 06-23-2005, 12:21 PM   #32
fastbagged68
Pulled the bags off and switched them out to F9000 in stock location. My top bag mount is in my c-notch.
Old 06-23-2005, 02:41 PM   #33
1low1967
1low1967's Avatar
How bad did they twist. And where you running poly bushings? A few friends of mine ran a simular setup on s10s with no problem but i know their lighter, I had a taco that laid on 19s with the bags on the axle but i wasnt happy with the lift thats why im tryn this. Thanks for looking out, once i get the cab and the bed on i'll have to see what happens
Old 06-23-2005, 02:57 PM   #34
fastbagged68
I have brand new poly bushings. My bags were mounted haft on the arm and haft off. The links when air was in the bags you could work the suspension and watch them the whole link roll like. Just watch them. You might be in good shape if most of the bag is on the link. If it does move you can move the bag to be centered on the link. and make a new upper bracket.
Old 06-24-2005, 07:46 AM   #35
1low1967
1low1967's Avatar
Cool Thanks.
Thread Tools
Display Modes
